As i know there are lots of method to send/receive integers but i could not figure out how to send multiple data?
In my project i'am using two arduinos one attached to accelerometer sensor and my sensor gives me 2 angle values as outputs like "30" and "-22". (angle values around x and y axis)
I would like to use them as inputs for my other arduino using serial communication.
According to my forum search i found this article very useful but as i said, i need to send two integers.
Use Serial.print as many times as you need to output as many things as you need:-
int val1 = 30;
int val2 = -20;
Serial.print("first value ");
Serial.print(val1);
Serial.print(" second value ");
Serial.println(val2); // print and start a new line.
Look at the code examples in serial input basics. One of the three options should do what you need. See also the section about parsing the received data.
You need to combine that parsing example with the code examples above which actually read the serial input.
The basic algorithm is to:
Set up a buffer to hold the received data (specify how much space you expect to use)
Place received characters into that buffer (without going past the end of the buffer)
Parse for start/end markers and the data you want
Skip over any data you don't want
Step 4 can get complex, mostly if you need to keep working on the buffer and receiving new data at the same time. The "several characters" example doesn't attempt to do this - it processes all of the buffer before it looks to Serial.available() again. Always think about what happens if any character is missed or garbled: how can the receiver re-synchronise to the incoming data and find the correct values.
Do you have an exact/actual example of the data that is sent from the sensor? Is the data sent have some end of data marker/delimiter? This is important in evaluating the receiving/parsing methods to use.
Nsitu:
I read it and have a small question if you can help me.
Parsing code is starting with;
char receivedChars[] = "This is a test, 1234, 45.3" ; (when data are "This is a test,1234,45.3")
If you look at the other examples they place the received data into an array called receivedChars
This is just an example of the sort of thing that might be in that array. The important thing is that you know the order of the data items and the type of data. The actual values can vary. I used 3 different types of data just for illustration.
I tried to combine receiving code and parsing code below, it is half working i dont know why, when i enter <12,5> it gives me just integer1=12 and integer2=0(always equal to 0). It is probably about that i am a newcomer. Is it easy to fix it? If yes how can i do? Thank you very much again.
const byte numChars = 32;
char receivedChars[numChars];
int integerFromPC1 = 0;
int integerFromPC2 = 0;
char recvChar;
char endMarker = '>';
boolean newData = false;
Serial.println("<Arduino is ready>");
recvWithStartEndMarkers();
showNewData();
parseData();
showParsedData();
void recvWithStartEndMarkers() {
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '<';
char rc;
if (Serial.available() > 0) {
rc = Serial.read();
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
else if (rc == startMarker) {
recvInProgress = true;
void showNewData() {
if (newData == true) {
Serial.print("This just in ... ");
Serial.println((char*)receivedChars);
newData = false;
void parseData() {
// split the data into its parts
char * strtokIndx; // this is used by strtok() as an index
strtokIndx = strtok((char*)receivedChars,",");
integerFromPC1 = atoi(strtokIndx);
strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
integerFromPC2 = atoi(strtokIndx); // convert this part to an integer
void showParsedData() {
Serial.print("Integer1 ");
Serial.println(integerFromPC1);
Serial.print("Integer2 ");
Serial.println(integerFromPC2);
Nsitu:
Can you please post all the output from your program as it appears in the Serial Monitor?
Given that it is not 12,5 the rest of the output is what you would expect.
You think some more about that and so will I.
... a little later ...
If you look at the function showNewData() you will see that it only works if newData is true AND when it is finished it sets newData to false.
The two functions you added parseData(); and showParsedData(); work even when there is no new data. The simplest way to make them work only when there is new data is to remove them from loop() and call them from showNewData() like this ...
newData = false;
parseData();
showParsedData();
This is probably not the ideal overall design, but it works.
By the way, because the new functions were not waiting for newData to be true they were working on partial data - hence the 12 on its own and the 0s when nothing had been received.
See the stuff I added to my earlier post which overlapped with yours.
Also, (and just for information, and certainly not for criticism) you seem to have missed an important debugging signal - the code with your additions behaved very differently from my original code. In my code it only produced output if you gave it some input whereas with your additions the code produced output continuously. That was the main thing that pointed me to the solution. However you did not mention this changed behaviour in Reply #9
Robin2:
...R
Robin thank you very much, it is now working perfectly.BTW i have an alternative code i cant decide which is more elegant way maybe you can decide.
const int NUMBER_OF_FIELDS = 2; // how many comma separated fields we expect
int fieldIndex = 0; // the current field being received
int values[NUMBER_OF_FIELDS]; // array holding values for all the fields
int sign=1;
Serial.begin(9600); // Initialize serial port to send and receive at 9600 baud
if( Serial.available())
char ch = Serial.read();
if(ch >= '0' && ch <= '9') // is this an ascii digit between 0 and 9?
// yes, accumulate the value
values[fieldIndex] = (values[fieldIndex] * 10) + (ch - '0');
else if (ch == ',') // comma is our separator, so move on to the next field
if(fieldIndex < NUMBER_OF_FIELDS-1)
fieldIndex++; // increment field index
else if(ch == '-')
sign = -1;
// any character not a digit or comma ends the acquisition of fields
// in this example it's the newline character sent by the Serial Monitor
Serial.print( fieldIndex +1);
Serial.println(" fields received:");
//for(int i=0; i <= fieldIndex; i++)
//Serial.println(values[i]);
values[0]=values[0]*sign;
values[1]=values[1]*sign;
Serial.println(values[0]);
Serial.println(values[1]);
//values[i] = 0; // set the values to zero, ready for the next message
fieldIndex = 0; // ready to start over
values[0]=0;
values[1]=0;
sign=1;
This code waiting inputs like "156,24" only one problem for this code when i set "sign" variable as "-1" (this happens when "-" sign received) all outputs become minus.
For example
when i enter 154,52
output
154
52
When i enter 154,-52
output
-154
-52
Note: Original code works for only 1 number(learned from arduino cookbook), i changed it for 2 numbers this is why minus sign is not working properly.
Nsitu:
Hey, Gimme a break here ...
I gave you some code that works with all the values you have mentioned in Reply #16. Don't expect me to write another version of the same thing.
...R
Thank you for your all support.
No, actually i am not expecting from you to write another version of same thing. I'am just writing another version in this topic because maybe other forum reader can choose according to their desire. i just asked to you maybe it is very easy to fix or maybe not.(I can not decide because of my lack of experince)
#include <TextFinder.h>
TextFinder finder(Serial);
const int NUMBER_OF_FIELDS = 2; // how many comma-separated fields we expect
for(fieldIndex = 0; fieldIndex < 2; fieldIndex ++)
values[fieldIndex] = finder.getValue(); // get a numeric value
Serial.print( fieldIndex);
//for(int i=0; i < fieldIndex; i++)
// Serial.println(values[i]);
