shanren
February 2, 2023, 12:39am
1
Hi all.
the sketch below run well, it signed a start time:
rtc.setTime(30, 24, 15, 17, 1, 2021); // 17th Jan 2021 15:24:30
how to give rtc.setTime() a new time got from NTP?
Thanks
Adam
#include <ESP32Time.h>
//ESP32Time rtc;
ESP32Time rtc(3600); // offset in seconds GMT+1
//rtc.setTime(1609459200); // 1st Jan 2021 00:00:00
//rtc.offset = 7200; // change offset value
/*---------set with NTP---------------*/
// configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
// struct tm timeinfo;
// if (getLocalTime(&timeinfo)){
// rtc.setTimeStruct(timeinfo);
// Serial.println(rtc.getTime()); // (String) 15:24:38
// Serial.println(rtc.getDate()); // (String) Sun, Jan 17 2021
// Serial.println(rtc.getDate(true)); // (String) Sunday, January 17 2021
// Serial.println(rtc.getDateTime()); // (String) Sun, Jan 17 2021 15:24:38
// Serial.println(rtc.getDateTime(true)); // (String) Sunday, January 17 2021 15:24:38
// Serial.println(rtc.getTimeDate()); // (String) 15:24:38 Sun, Jan 17 2021
// Serial.println(rtc.getTimeDate(true)); // (String) 15:24:38 Sunday, January 17 2021
// Serial.println(rtc.getMicros()); // (long) 723546
// Serial.println(rtc.getMillis()); // (long) 723
// Serial.println(rtc.getEpoch()); // (long) 1609459200
// Serial.println(rtc.getSecond()); // (int) 38 (0-59)
// Serial.println(rtc.getMinute()); // (int) 24 (0-59)
// Serial.println(rtc.getHour()); // (int) 3 (0-12)
// Serial.println(rtc.getHour(true)); // (int) 15 (0-23)
// Serial.println(rtc.getAmPm()); // (String) pm
// Serial.println(rtc.getAmPm(true)); // (String) PM
// Serial.println(rtc.getDay()); // (int) 17 (1-31)
// Serial.println(rtc.getDayofWeek()); // (int) 0 (0-6)
// Serial.println(rtc.getDayofYear()); // (int) 16 (0-365)
// Serial.println(rtc.getMonth()); // (int) 0 (0-11)
// Serial.println(rtc.getYear()); // (int) 2021
// Serial.println(rtc.getLocalEpoch()); // (long) 1609459200 epoch without offset
Serial.println(rtc.getTime("%A, %B %d %Y %H:%M:%S")); // (String) returns time with specified format
// formating options http://www.cplusplus.com/reference/ctime/strftime/
struct tm timeinfo = rtc.getTimeStruct();
//Serial.println(&timeinfo, "%A, %B %d %Y %H:%M:%S"); // (tm struct) Sunday, January 17 2021 07:24:38
terwal
February 2, 2023, 1:12am
4
You must define a WIFI connection that have access to internet and uncomment your NTP section.
something like this
Thanks.
is it possible to get current time by NTP and then sign to rtc like:
rtc.setTime( current time );
I synch the ESP32's internal RTC to NTP using the code below (put it after the WiFi connection code)
#include "esp_sntp.h"
const char ntpServer[] = "pool.ntp.org";
const long gmtOffsetSec = -5 * 3600L;
const int daylightOffsetSec = 3600;
timeval tv;
time_t now;
tm *timeinfo;
char timeString[100];
//****************************** After WiFi is Connected ******************************
sntp_set_sync_mode(SNTP_SYNC_MODE_SMOOTH);
configTime(gmtOffsetSec, daylightOffsetSec, ntpServer);
sntp_sync_time(&tv);
log_i("Waiting for Time Sync");
while (true) { // Wait for NTP sync to take effect
now = time(nullptr);
timeinfo = localtime(&now);
if (timeinfo->tm_year >= (2022 - 1900)) {
vTaskDelay(500);
sntp_sync_status_t syncStatus = sntp_get_sync_status();
switch (syncStatus) {
case SNTP_SYNC_STATUS_RESET:
log_i("SNTP_SYNC_STATUS_RESET");
case SNTP_SYNC_STATUS_COMPLETED:
log_i("SNTP_SYNC_STATUS_COMPLETED");
case SNTP_SYNC_STATUS_IN_PROGRESS:
log_i("SNTP_SYNC_STATUS_IN_PROGRESS");
default:
log_e("Unknown Sync Status");
sntp_sync_mode_t mode = sntp_get_sync_mode();
switch (mode) {
case SNTP_SYNC_MODE_IMMED:
log_i("SNTP_SYNC_MODE_IMMED");
case SNTP_SYNC_MODE_SMOOTH:
log_i("SNTP_SYNC_MODE_SMOOTH");
default:
log_e("Unknown Sync Mode");
uint32_t interval = sntp_get_sync_interval();
log_i("NTP Sync Interval = %d", interval);
strftime(timeString, 100, "%A, %B %d %Y %H:%M:%S", timeinfo);
log_i("Local Time: %s", timeString);
Set the core debug level to 'Info' to see the print outs.
Thank you gfvalvo .
I did test, and got correct current time output.
still which variable should I put into: rtc.setTime(variable);
the reason I like to do so is this is the only way I got better result when used rtc time later on with other functions.
this one?
rtc.setTime("Local Time: %s", timeString);
What you want to do makes not sense. The 'ESP32Time' library is just a wrapper interface for the functions available in 'esp_sntp.h'. Those are the functions used in the code I posted. There's no need for ESP32Time.h.
Also as long as WiFi is connected, the ESP32's internal RTC will be periodically synched to NTP. The synch interval is reported by the code I posted and can be changed.
So, once synching periodically, just get the time using:
system
Closed
August 2, 2023, 12:07am
11
