i have 6 serial objects here. Im coding for the raspberry pi pico using Earl E . Philhower's core.
Serial1 (hardware)
Serial2 (hardware)
Serial3 (SerialPIO)
Serial4 (SerialPIO)
Serial5 (SerialPIO)
Serial6 (SerialPIO)
and have a function
void myFunc(int deviceNumber, int x, int y) {
switch (deviceNumber) {
case 1:
Serial1.println(x);
Serial1.println(y);
//some more codes that uses Serial 1
Serial1.println(x + y);
case 2:
Serial2.println(x);
Serial2.println(y);
//some more codes that uses Serial 2
Serial2.println(x + y);
case 3:
Serial3.println(x);
Serial3.println(y);
//some more codes that uses Serial 3
Serial3.println(x + y);
case 4:
Serial4.println(x);
Serial4.println(y);
//some more codes that uses Serial 4
Serial4.println(x + y);
case 5:
Serial5.println(x);
Serial5.println(y);
//some more codes that uses Serial 5
Serial5.println(x + y);
case 6:
Serial6.println(x);
Serial6.println(y);
//some more codes that uses Serial 6
Serial6.println(x + y);
default:
Each case statement is identical the only difference is which serial object i am using. I find this to be cluttered as if i need to edit 1 case statement i have to edit them all, which will leads me to sometimes miss a case. There has to be a better way of writing this that is more clean.
I would like to get something like this, its much more cleaner and not confusing to the eyes as there is no repeating lines of codes
case 1:
HardwareSerial* ptr = Serial1;
case 2:
HardwareSerial* ptr = Serial2;
case 3:
SerialPIO* ptr = Serial3;
case 4:
SerialPIO* ptr = Serial4;
case 5:
SerialPIO* ptr = Serial5;
case 6:
SerialPIO* ptr = Serial6;
ptr -> println(x);
ptr -> Serial1.println(y);
//some more codes that uses SerialX
ptr -> Serial1.println(x + y);
How can i do this?
