I have a very big problem, I'm making a puck collect with an arduino mega, and I'm using a remote control of 6 channels. I did my code for motors and it works perfectly, I used 2 channels, but I have to control a servomotor with another channel, and when I put that chanel in my code, one channel doesn't work. HELP ME PLEASE!!!
CODE:
#include <Servo.h>
#include <AFMotor.h>
#define CH2 2 //Se definen pines para los canales del receptor
#define CH3 10
#define CH4 13
int led1=24;//led metal
int led2=25;//led plastico
Servo servo1;
int est1=22;//sensor 1
int est2=23;//sensor 2
int lect1;
int lect2;
int lect3;
int valor; //variables para la lógica
int valor2;
AF_DCMotor motor1(1);
AF_DCMotor motor2(2);
AF_DCMotor motor3(3);
AF_DCMotor motor4(4);
void setup(){
pinMode(CH2,INPUT);
pinMode(CH3,INPUT);
pinMode(CH4,INPUT);
pinMode(est1,INPUT);
pinMode(est2,INPUT);
pinMode(led1,OUTPUT);
pinMode(led2,OUTPUT);
servo1.attach(9);
servo1.write(0);
// Prender el motor #1
motor1.setSpeed(255);
motor1.run(RELEASE);
// Prender el motor #2
motor2.setSpeed(255);
motor2.run(RELEASE);
// Prender el motor #3
motor3.setSpeed(255);
motor3.run(RELEASE);
// Prender el motor #4
motor4.setSpeed(255);
motor4.run(RELEASE);
void loop(){
{valor=pulseIn(CH2,HIGH,4000);
Serial.print("CH2: ");Serial.println(valor);
delay(10);
valor2=pulseIn(CH4,HIGH,4000);
Serial.print("CH4: ");Serial.print(valor2);
motor1 motor3
motor2 motor4
if (valor2>1600)
Serial.println("Giro Derecha");
motor1.run(FORWARD);
motor2.run(FORWARD);
motor3.run(BACKWARD);
motor4.run(BACKWARD);
else if(valor>1600)
motor3.run(FORWARD);
motor4.run(FORWARD);
Serial.println("Adelante");}
else if((valor<1600)&&(valor>1400))
Serial.println("Pausa");}
else if((800<valor) && (1460>valor))
motor1.run(BACKWARD);
motor2.run(BACKWARD);
Serial.println("Atras");
else if ((valor2<1400)&&(valor2>1000))
Serial.println("Giro Izquierda");
motor4.run(FORWARD);}
else if ((valor2>1400)&&(valor2<1600))
Serial.println("DETENIDO");
motor4.run(RELEASE);}}
lect3=pulseIn(CH3,HIGH,4000);
Serial.print("CH3: ");Serial.println(lect3);
delay(20);
lect1=digitalRead(est1);
lect2=digitalRead(est2);
if(lect3>1000&&lect3<1480){
servo1.write(90);
if(lect1==0||lect2==0){
digitalWrite(led1,HIGH);
digitalWrite(led2,LOW); }
if(lect1==1&&lect2==1){
digitalWrite(led1,LOW);
digitalWrite(led2,HIGH); } }
else{
if(lect3<1000){
servo1.write(0);
digitalWrite(led2,LOW);}}
