How to split a char array?
Hi Everyone!
I am relatively new to programming and was wondering if someone could provide some input.
I'm working on an EMG project where I have 8 channels of data, and each channel is comprised of 24 bits for a total of 216 bits (24-bit * 8 + 24-bit header) which is sent out through SPI.
The 216-bits are encoded into hex and stored into a char myarray[], where the serial output is the following
(Only one active channel at the moment)
The output is the following: [3 bytes header] [3 bytes CH1] [3 bytes CH2] ... [3 Bytes CH8]
I am trying to split each channel into their own char array, but I am not sure what's the best way to proceed?
I'd appreciate any help you could provide, and please let me know if you need more information!
What does that mean, and why did you do THAT?
Since the header and channel data are the same size, copying the data from a 1D array to a 2D array would be trivial. The % operator applied to the index of the for loop would tell you which column. The / operator applied to the index of the for loop would tell you the row.
But, there is no real reason to do that. The data for channel n starts at position 3*n in the array (if you number the channels from 1 to 8. The data starts at position 3 * (n+1) if you number the channels from 0 to 7. Just access the three bytes starting from the proper position, for each channel.
Thanks for your reply, I appreciate it!
Your suggestion makes complete sense and I think it's the correct answer, but I'm having issues understanding the syntax (pretty new to arrays) and was wondering if you could provide a quick example.
ericord:
Does an 'array element (member)' is represented by 'Natural Binary/Hex' or 'ASCII'.
A channel contains 24-bit (3-byte) data. A byte is of 8-bit long. Is this 8-bit a 'natural binary number' or 'ASCII Code'? The confusion has arisen from the declaration of your 'character type array (char myarray[])' and the phrase 'encoded into hex'. Please, clarify with an 'example data' and then we may help you in taking out the data of a particular channel. For example:
Ch-0 data : 00110001 00111000 00110111 (24-bit, 31 38 37) in ASCII for 1 8 7
Ch-0 data : 00000001 00001000 00000111 (24-bit, 01 08 07) in Binary (aka natural binary) for 1 8 7
The data comes from readSerial command.
Here is the code relating to the 27-byte hex encoded array:
char hexDigits[] = "0123456789ABCDEF";
uint8_t serialBytes[200];
char sampleBuffer[1000];
inline void sendSample(void) {
  digitalWrite(PIN_CS, LOW);
  register int numSerialBytes = (3 * (maxChannels+1)); //24-bits header plus 24-bits per channel  (3 *
  numActiveChannels(+1)) This will only display the active channels
  uint8_t returnCode = spiRec(serialBytes, numSerialBytes);
  digitalWrite(PIN_CS, HIGH);
  register unsigned int count = 0;
  encodeHex(sampleBuffer, (char *)serialBytes, numSerialBytes);
  //split(sampleBuffer);
void encodeHex(char* output, char* input, int inputLen) {
  register int count = 0;
  for (register int i=0; i < inputLen; i++) {
    register uint8_t lowNybble = input[i] & 0x0f; //Nyblble = 4 bits
    register uint8_t highNybble = input[i] >> 4;
    output[count++] = hexDigits[highNybble];
    output[count++] = hexDigits[lowNybble];
  output[count] = 0;
printing sampleBuffer with one active channel Imgur: The magic of the Internet
The data format for each channel is two's complement and MSB first
@OP
These are my tested codes (brute force codes) which have manipulated 27-bytes data (of 2's complement form) of your array named uint8_t serialBytes[] to find the decimal value of Ch-1.
  uint8_t serialBytes[] =
    0xC0, 0x00, 0x00,  //header 3-byte
    0xFF, 0x60, 0xAD,   //Ch-1 (arbitray data in 2's complement form)
    0x12, 0x34, 0x56,   //Ch-2
    0x78, 0x9A, 0xAB,   //Ch=3
    0xCD, 0xEF, 0xF0,   //Ch-4
    0x80, 0x83, 0x98,   //Ch-5
    0xCC, 0xBD, 0x1C,   //Ch-6
    0x3B, 0xEF, 0xFE,   //Ch-7
    0x45, 0xDC, 0x57    //Ch-7
  uint32_t myData[8];
  for (int i = 1, j = 0; i <= 8, j < 8; i++, j++)
    myData[j] = ((uint32_t)serialBytes[3 * i] << 16) |
                (uint32_t)(serialBytes[3 * i + 1] << 8) |
                (uint32_t)(serialBytes[3 * i + 2]);
  for(int j=0; j<8; j++)
    Serial.println(myData[j]&0x00FFFFFF, HEX);//FF60AD, 123456, FF9AAB, FFEFF0, FF8398, FFBD1C, ...
  //decimal value of Ch-1 = myData[0] = (00)FF60AD = -1*2^23+(0x7F60AD) = -8388608 + 8347821 = - 40787
  for (int i = 23; i >= 0; i--)
    Serial.print((bitRead(myData[0], i)), BIN); //shows: 1111 1111 0110 0000 1010 1101 = FF60AD in 2's comple.
  float x1 = -1 * pow(2, 23); //getting: -1*2^23
  Serial.println(x1, 2);  //-8388608.00
  uint32_t x2 = myData[0] & 0x007FFFFF;
  float x3 = (float)x2;
  Serial.println(x3, 2); //+8347821.00 = 7F60AD
  Serial.println((x1 + x3), 2); //-40787.00 = FF60AD (2's complement form)
Thank you very much- this is exactly what I was looking for! :slight_smile:
GolamMostafa:
@OP
uint32_t myData[8];
  //decimal value of Ch-1 = myData[0] = (00)FF60AD = -12^23+(0x7F60AD) = -8388608 + 8347821 = - 40787
2^23
Hi GolamMostafa,
Thank you for your help, this worked perfectly and I was able to convert the decimal values to voltage levels. I'm still new to programming and this has been a new learning curve.
void newBytes () {
  uint32_t myData[8];
if (x > 8388607){
     rawVoltageValue = ((x - 16777216) * 2.4) / (pow(2,23)-1);
     if (filter_flag == true){
        High_Pass_Filter(rawVoltageValue*1000.0);
      else {
        Serial.println(rawVoltageValue*1000.0, 5); // print voltage with 5 decimal points
    rawVoltageValue = (x * 2.4) / (pow(2,23)-1);
      else {
You were the only one who was able to help me, and I was wondering if you could answer one more question.
What would be the best way to store the voltage values for each channel in array?
e.g array[] = {voltagech1, voltagech2, voltagech3, ...}
The reason I need the array is because I need to send the data of all 8 channels to an SD card for post data processing.
Again I truly appreciate your help!
Probably, you are looking for something like:
The Codes:
uint8_t serialBytes[] = //arbitrary data in 2's complement form
  0xFF, 0x60, 0xAD,   //Ch-1  //FF60AD = -40787.00
  0x12, 0x34, 0x56,   //Ch-2  //123456 = 1193046.00
  0x78, 0x9A, 0xAB,   //Ch-3  //789AAB = 7903915.00
  0xCD, 0xEF, 0xF0,   //Ch-4  //CDEFF0 = -3280912.00
  0x80, 0x83, 0x98,   //Ch-5  //808398 = -8354920.00
  0xCC, 0xBD, 0x1C,   //Ch-6  //CCBD1C = -3359460.00
  0x3B, 0xEF, 0xFE,   //Ch-7  //3BEFFE = 3928062.00
  0x45, 0xDC, 0x57    //Ch-7  //45DC57 = 4578391.00
float storeVoltage[8];  //save Ch0-Ch7 values as decimal numbers
uint32_t myData[8] = {0};  //save 8-Channel data as bits
  for (int i = 1, j = 0; i <= 8, j < 8; i++, j++)  //form binary bits
    myData[j] = (uint32_t)(serialBytes[3 * i]) << 16 |
                (uint32_t)(serialBytes[3 * i + 1]) << 8 |
  Serial.print("Arbitrary Channel Data in 2's Complenet Form:");
  for (int j = 0; j < 8; j++)
    Serial.print((myData[j]& 0x00FFFFFF), HEX); Serial.print("  ");
  Serial.println("-------------------------------------------------------");
  findVoltage();  //save above binary bits as decimal values (Ch0-Ch7)
  delay(5000);
  Serial.println("============================================================================");
void findVoltage()
  for (int i = 0; i < 8; i++)
    bool n = bitRead(myData[i], 23);  //reading bit-27 for 0 (+ve) or 1(-ve)
    float x1 = -n * pow(2, 23); //getting: -1*2^23
    Serial.print("Ch-"); Serial.print(i);
    Serial.print(":Magnitude of MSB: ");
    Serial.print(x1, 2);  //-8388608.00
    Serial.print("\t");
    uint32_t x2 = myData[i] & 0x007FFFFF;
    // Serial.println(x3, 2); //+8347821.00 = 7F60AD
    storeVoltage[i] = (x1 + x3);
    Serial.print("Final Value of Channel Volatge: ");
    Serial.println(storeVoltage[i], 2);//(x1 + x3), 2); //-40787.00 = FF60AD (2's complement form)
GolamMostafa:
The Codes:
 delay(5000);
void findVoltage()
   Serial.print("\t");
Thank you so much GolamMostafa, this works perfect!
Your help has taught me a lot, and now I can actually move on from this roadblock.
I wish I could show you my gratitude, you're the best. :slight_smile:
