Hello Forum Member,
I am trying to learn how to control servo motor using irremote.
first code below working as per expected.
#include <IRremote.h>
#include <Servo.h>
int IRpin = 4;
String kodeKu;
struct kode
uint32_t kodeValue;
const char * ku;
} KodeList[] =
{0xE916FF00, "zero"},
{0xE619FF00, "RPT"},
{0xF20DFF00, "U/SD"},
{0xF30CFF00, "one"},
{0xA15EFF00, "three"},
const char * GetKodeKu(uint32_t kode)
size_t kuCount = sizeof KodeList / sizeof KodeList[0];
for (size_t i = 0; i < kuCount; i++)
if (KodeList[i].kodeValue == kode)
Serial.print("Recognized as ");
Serial.println(KodeList[i].ku);
return KodeList[i].ku;
Serial.println("Kode Not Recognized");
return "";
Servo servo1;
const int SERVO1_PIN = 7;
int servo1_angle = 90;
int servo1_angleStep = 1;
const int servo1_ANGLE_CENTRE = 90;
bool button_servo1State_on , button_servo1State_off;
delay(200);
Serial.println("TEST OF RCSERVO CONTROL USING IRREMOTE");
IrReceiver.begin(IRpin);
servo1.attach(SERVO1_PIN);
IrReceiver.enableIRIn();
while (IrReceiver.decode() == 0);
unsigned long value = (IrReceiver.decodedIRData.decodedRawData);
Serial.print("Received: ");
IrReceiver.resume();
kodeKu = GetKodeKu(value);
switch (value) {
case 0xE916FF00 :
Serial.println("zero");
servo1.write(servo1_ANGLE_CENTRE);
Serial.println(servo1_ANGLE_CENTRE);
case 0xE619FF00:
Serial.println("RPT");
if (servo1_angle > 50 && servo1_angle <= 130) {
servo1_angle = servo1_angle - servo1_angleStep;
if (servo1_angle <= 50) {
servo1_angle = servo1_angle;
servo1.write(servo1_angle); // move the servo to desired angle
Serial.print("Moved to: ");
Serial.print(servo1_angle); // print the angle
Serial.println(" degree");
delay(100);
case 0xF20DFF00:
Serial.println("U/SD");
if (servo1_angle >= 50 && servo1_angle <= 130) {
servo1_angle = servo1_angle + 1;
if (servo1_angle >= 130) {
delay(100);
then i want to control servo sweep using another irremote button, in this case using button "three". I put code as below:
case 0xA15EFF00 :
Serial.println("three");
button_servo1State_off = !button_servo1State_off;
button_servo1State_on = false ;
while (button_servo1State_off = true) {
for (servo1_angle = 50; servo1_angle <= 130; servo1_angle++) { // goes from 50 degrees to 130 degrees
// in steps of 1 degree
servo1.write(servo1_angle); // tell servo to go to position in variable 'pos'
Serial.println(servo1_angle);
delay(15); // waits 15 ms for the servo to reach the position
for (servo1_angle = 130; servo1_angle >= 50; servo1_angle-- ) { // goes from 130 degrees to 50 degrees
it was working and servo start sweep.
after this i have no clue how to stop servo sweep at any angle and position using button "one" then return to normal condition before start any irremote button.
i put the code below but doesn't response. what should i do next? please guide me. thank you
case 0xF30CFF00 :
Serial.println("one");
if("play" == false) break;
for (servo1_angle = 50; servo1_angle <= 130; servo1_angle+0) { // goes from 0 degrees to 180 degrees
for (servo1_angle = 130; servo1_angle >= 50; servo1_angle-0 ) { // goes from 180 degrees to 0 degrees
