How to stop whatever Arduino is doing and restart the loop
Hi!
I have a loop moving x stepmotor and then y stepmotor.
Each motor is moved using a function move_x and move_y
The moving is done by triggering one pin from high to low with a delay in between that set the speed. It increment a counter in a FOR loop from 0 to wherever I wish to go.
The fonction moves the motors and it returns the position so I can move back to origin if required.
I am looking for the possibility that if during a movement, I press a pushbutton, it would return to origin and stop.
I just thought while writing this, I could add in the FOR loop of each function an if button is pressed call the function back_to_origin, but then how should restart from the top of main loop, just like if I had reset the arduino?
Many thanks for your help... pretty new in Arduino.. cool stuff!
Ghislain
We can't see your code.
If I understand well the Return function will go back to the next instruction.
I wish to get back to the start, almost like a hard reset.. in fact hard reset be put in software?
Thank you Delta_G for your answer.
I just tried it :
Loop is calling a function
In this function I add Return
It stop the function and go back to the next instruction in loop.
I wish to go back to top of the loop, or even run the setup again it that's what it takes.
Ghis
ghis123:
This is probably an indication that your code (which you did not post) is poorly structured.
Thank you all for your suggestion, I am open to make adjustment. Below is the code.
Loop converts my const into pulses for my steppers.
Then it calls the function depl_x to move the motor x direction
Then it calls the function depl_y to move the motor in y direction
it repeats these two several amount of times
Then move back to starting point
Note that x direction is changing everytime.
see next post with code tags...
// Révision 0 - mouvement et faire les passes x et y avec convertion des longueurs
// Révision 1 - Retour des positions actuels du curseurs afin de programmer le retour à zéro
// Configuration:
const int travelx_mm = 100; // Distance X  MAX 1647
const int travely_mm = 300; // Distance Y  MAX 757
const int hauteur_debut_mm = -150; // Hauteur du début de peinture
const int overlap_y_mm = 20; // overlap de peinture sur la hauteur
const int largeur_fan_mm = 300; // largeur du jet de peinture
const int spdx = 500; // Vitesse X (190 est le plus vite, 1000 est lent) MAX 365
const int spdy = 1500; // Vitesse Y (190 est le plus vite, 1000 est lent)
const int prepaint = 20; // Temps que la peinture met pour atteindre la cible (mS)
const int delais = 0; // Délais entre les mouvements (mS) (La valeur prepaint affecte aussi)
// NE RIEN CHANGER EN DESSOUS DE CETTE LIGNE
const int xstepPin = 9;
const int xdirPin = 8;
const int ystepPin = 7;
const int ydirPin = 6;
const int gunpin = 10;
const int pinbouton = 12;
 pinMode(xstepPin, OUTPUT);
 pinMode(xdirPin, OUTPUT);
 pinMode(ystepPin, OUTPUT);
 pinMode(ydirPin, OUTPUT);
 //  pinMode(motenable,OUTPUT);
 pinMode(gunpin, OUTPUT);
 pinMode(pinbouton, INPUT);
 //  digitalWrite(motenable,LOW);
 digitalWrite(gunpin, LOW);
 int nb_y_max;
 int direction_x;
 int direction_y;
 float increment_y;
 float depl_initial_y;
 float travelx ;
 float travely ;
 float hauteur_debut;
 float overlap_y;
 float largeur_fan;
 float position_y;
 float position_x;
 travelx = conv_unit(travelx_mm); // Distance X
 travely = conv_unit(travely_mm); // Distance Y
 hauteur_debut = conv_unit(hauteur_debut_mm); // Hauteur du début de peinture
 overlap_y = conv_unit(overlap_y_mm); // overlap de peinture sur la hauteur
 largeur_fan = conv_unit(largeur_fan_mm); // largeur du jet de peinture
 direction_x = 1;
 direction_y = 1;
 position_x = 0;
 position_y = 0;
 depl_initial_y = hauteur_debut + (largeur_fan / 2);
 nb_y_max = (travely - depl_initial_y) / (largeur_fan - overlap_y);
 increment_y = largeur_fan - overlap_y;
 boolean etatBouton = digitalRead(pinbouton);
 //test des conditions
 if (etatBouton == HIGH) { //test si bouton appuyé
   depl_y(depl_initial_y, direction_y); //positionnement au niveau du début de peinture
   for (int nb_y = 0; nb_y < nb_y_max; nb_y++) { // Boucle qui effectue le déplacement +x +y -x +y ...
     position_x = position_x + depl_x(travelx, direction_x);
     position_y = position_y + depl_y(increment_y, direction_y);
     direction_x = direction_x * -1;
   }  /// fin de la boucle for du déplacement;
   // Return to origin (point 0,0)
   position_x = depl_x(position_x, direction_x);
   position_y = depl_y(position_y + depl_initial_y, -direction_y);
//End of main loop
// Function to move the x motor and return the position
float depl_x(int distance_x, int dir_x) {
 float x_pos;
 if (dir_x == 1) {
   digitalWrite(xdirPin, HIGH);
   digitalWrite(xdirPin, LOW);
 digitalWrite(gunpin, HIGH);
 delay(prepaint);
 for (int x = 0; x < distance_x; x++) {
   digitalWrite(xstepPin, HIGH);
   delayMicroseconds(spdx);
   digitalWrite(xstepPin, LOW);
   x_pos = x;
 delay(delais);
 return (x_pos * dir_x);
// Function to move the y motor and return the position
float depl_y(float distance_y, int dir_y) {
 float y_pos;
 if (dir_y == 1) {
   digitalWrite(ydirPin, HIGH) ;
   digitalWrite(ydirPin, LOW);
 for (int y = 0; y < distance_y; y++) {
   digitalWrite(ystepPin, HIGH);
   delayMicroseconds(spdy);
   digitalWrite(ystepPin, LOW);
   y_pos = y;
 delay(delais);
 return (y_pos * dir_y);
// Function to convert mm to pulse
float conv_unit(float chiffre) { // convertir les entrées mm en unité de pulse  - 176mm = 1000 pulse
 return ( chiffre * 1000 / 176);
I suspect it will be easier to get the program to do what you want if you move most of the code from loop() into one or more functions. Then a RETURN from a function pretty much gets back to the start.
Have a look at Planning and Implementing a Program
...R
