I looking guidance and sample code that store the serial received string to EEPROM using EEPROM Put and read it back later. The current code store the string to EEPROM but the return from EEPROM Get does not display the string stored.
Code below is store string to EEPROM
#include <EEPROM.h>
#define StatusPin 13
String User_String;
String ComData;
pinMode(StatusPin,OUTPUT);
digitalWrite(StatusPin,LOW);
Serial.println("Initialize complete...");
Serial.println("Please input command: ");
Status_Done();
while(Serial.available() == 0)
delay(100);
if(Serial.available()> 0)
ComData = "";
while(Serial.available() > 0)
ComData = Serial.readStringUntil('\r');
delay(2);
Serial.println(ComData);
if (ComData == "EEPROM Clear")
EEPROM_Clear();
Serial.println("\nPlease input command:");
else if (ComData == "EEPROM Put")
Serial.println("\nPlease input the string:");
User_String = "";
User_String = Serial.readStringUntil('\r');
delay(2);
Serial.print("User String: ");
Serial.println(User_String);
EEPROM_Put();
Serial.println("Invalid input!!!");
void EEPROM_Clear()
// Clear all bytes in EEPROM to 0
Serial.println("Clear the EEPORM...");
for (int i = 0 ; i < EEPROM.length() ; i++)
EEPROM.write(i, 0);
Serial.println("EEPORM Clear Done...");
Status_Done();
delay(100);
void EEPROM_Put()
int eeAddress = 0;
EEPROM.put(eeAddress, User_String);
Serial.println("Written string to EEPROM...");
Status_Done();
void Status_Done()
for (int Done = 0; Done < 5; Done++)
digitalWrite(StatusPin,HIGH);
delay(200);
delay(200);
Code below read the string from EEPROM
#include <EEPROM.h>
String ComData;
Serial.println("Please input command:");
Status_Done();
delay(100);
ComData = "";
delay(2);
EEPROM_Clear();
Status_Done();
else if (ComData == "EEPROM Get")
EEPROM_Get();
Status_Done();
void EEPROM_Clear()
EEPROM.write(i, 0);
Status_Done();
delay(100);
void EEPROM_Get()
String User_String;
int eeAddress = 0;
// Get the Arduino Serial Number from the EEPROM at position 'eeAddress'
Serial.print("Read User String from EEPROM: ");
EEPROM.get(eeAddress, User_String);
void Status_Done()
delay(150);
delay(150);
@eekhaytan
You cant directly store the String variable with put(), because EEPROM library does not support String class. Convert it to the char array first.
Repeat to yourself. I will never, ever, name my function the same as a library function. Ever. It is simply not necessary to add this layer of obfuscation.
Others may have a different opinion. Confusion will reign supreme. It just isn't necessary at the beginner, intermediate, or senior level. Let the geeks play with that, it's what they get paid for.
C
And yes, before anyone screams, I do get the difference between the dot and the underscore. But this makes code much more difficult to read.
Sorry for the confusion, I will change it as soon as my problem has a fix.
By the way, How do we convert the string received from the serial to char array?
For example the string received from serial probably like FD98D84F2BC6C0C6A145 (no fix length).
Have your tried your code with a power cycle to see what you think is saved to the eeprom is indeed there.
As previously said, you can not save a String object to eeprom.
Without the power cycle, the saved pointer to the String objects address will still point at the underlying String and it will look like it is being read from EEPROM when it is not.
This code has two section, one is write to EEPROM and another one is read from EEPROM.
I load the Write code to the Arduino, the code will save the string received from Serial to EEPROM.
After that I load the read code to the Arduino again, and use to read the string store before from EEPROM.
Might be simpler to write one code, and use an #ifdef or a flag variable to incorporate writing or reading. That allows you to see the two portions of the code within one context. Admittedly, either approach will work.
C
I think you should be very careful. As @cattledog has said... EEPROM.put/get are not intended to be used with Strings... you may get some very odd results.
Try the following simple example... the result might surprise you.
#include <EEPROM.h>
String str1 = "abcde";
String str2 = "fghij";
EEPROM.put(0, str1);
str1 = "12345"; // This should not impact the value stored in the EEPROM ... should it ???
EEPROM.get(0, str2);
Serial.println(str2);
I certainly don't confirm your results with a power cycle between the two pieces of code.
save_strings
User String: Does this String object get stored in EEPROM
read_strings
Read User String from EEPROM: ⸮⸮_T⸮se⸮+⸮}/⸮ϟ⸮⸮⸮⸮}⸮⸮⸮⸮⸮Mu⸮⸮⸮⸮⸮f羥⸮[⸮⸮⸮⸮
