Hello, recently i wrote this code which every time you press the button, the pin state will be ON or OF, here's the code:
if ( Fstat == LOW ) //If F key pressed
digitalWrite(Fan, !digitalRead(Fan)); //Invert the Fan relay State
The problem is when you press the button, if you keep pushing it, it will toggle the pin state as fast as Arduino can read the code, I cant describe it good but you know what I mean.
What I want is to toggle the pin state only once after I pressed the button and then toggle again when I released the button, and pressed it again.
How should I do it?
(sorry I still feel I didn't said what I wanted good, but ask me where you didn't understand)
