How to transmit and receive current time using RF 433Hz
I was doing a project using RF 433Hz to transmit and receive the current time, but i am unable to receive the minute and second at the receiver side. I am using two Arduinos, each of them has their own transmitter and receiver.
Here is my code for the first Arduino to transmit hour, minute and second
#include <DS3231.h>//Memanggil RTC3231 Library
#include <Wire.h>  // i2C Conection Library
#include <LiquidCrystal.h> //Libraries
#include <EEPROM.h>
#include <VirtualWire.h>
LiquidCrystal lcd(12, 11, 6, 5, 4, 3); //Arduino pins to lcd
#define bt_time   A0
#define bt_up     A1
#define bt_down   A2
#define bt_alarm  A3
#define buzzer 8
//rf variables
char *controller;
char *temp;
DS3231  rtc(SDA, SCL);
// Init a Time-data structure
Time  t; //pencacah string time()
int hh = 0, mm = 0, ss = 0, dd = 0, bb = 0, set_day;
int yy = 0;
String Day = "  ";
int AlarmHH  = 21, AlarmMM  = 22, AlarmSS  = 23, setMode = 0, setAlarm = 0, alarmMode=0;
int stop =0, mode=0, flag=0;
//Eeprom Store Variable
uint8_t HH;
uint8_t MM;
 byte bell_symbol[8] = {
        B00100,
        B01110,
        B01110,
        B01110,
        B01110,
        B11111,
        B01000,
        B00100};
byte thermometer_symbol[8] = {
        B00100,
        B01010,
        B01010,
        B01110,
        B01110,
        B11111,
        B11111,
        B01110};
void setup(){
// Setup Serial connection
  rtc.begin(); // memulai koneksi i2c dengan RTC
 pinMode(bt_time,  INPUT_PULLUP);
 pinMode(bt_up,    INPUT_PULLUP);
 pinMode(bt_down,  INPUT_PULLUP);
 pinMode(bt_alarm, INPUT_PULLUP);
 pinMode(buzzer, OUTPUT);
  lcd.createChar(1, thermometer_symbol);
  lcd.createChar(2, bell_symbol);
  lcd.begin(16, 2); // Configura lcd numero columnas y filas
  lcd.setCursor(0,0);  //Show "TIME" on the LCD
  lcd.setCursor (0,0);
  lcd.print(" RF-Based Clock ");
  lcd.setCursor (0,1);
  lcd.print("   With Alarm ");
  delay (2000);
  lcd.clear();
stop=EEPROM.read(50);
if(stop==0){
}else{WriteEeprom ();}
EEPROM.write(50,0);
ReadEeprom();
vw_set_ptt_inverted(true); // Required for DR3100
vw_set_rx_pin(7);
vw_set_tx_pin(9);
vw_setup(4000); // Bits per sec
pinMode(13, OUTPUT);
pinMode(2, OUTPUT);
vw_rx_start(); // Start the receiver PLL running
void loop(){
t = rtc.getTime();
Day = rtc.getDOWStr(1);
if (setMode == 0){
hh = t.hour,DEC;
mm = t.min,DEC;
ss = t.sec,DEC;
dd = t.date,DEC;
bb = t.mon,DEC;
yy = t.year,DEC;
  if(setAlarm==0){
  lcd.setCursor(0,0);
  lcd.print((hh/10)%10);
  lcd.print(hh % 10);
  lcd.print(":");
  lcd.print((mm/10)%10);
  lcd.print(mm % 10);
  lcd.print(":");
  lcd.print((ss/10)%10);
  lcd.print(ss % 10);
  lcd.print(" ");
  if(mode==1){lcd.write(2);}
  else{lcd.print(" ");}
  lcd.print(" ");
  lcd.write(1);
  lcd.print(rtc.getTemp(),0);
  lcd.write(223);
  lcd.print("C");
  lcd.print("  ");
  lcd.setCursor(1,1);
  lcd.print(Day);
  lcd.print(" ");
  lcd.print((dd/10)%10);
  lcd.print(dd % 10);
  lcd.print("/");
  lcd.print((bb/10)%10);
  lcd.print(bb % 10);
  lcd.print("/");
  lcd.print((yy/1000)%10);
  lcd.print((yy/100)%10);
  lcd.print((yy/10)%10);
  lcd.print(yy % 10);
setupClock();
setTimer();
delay (100);
blinking();
//Alarm
if (alarmMode==1 && mode==1 && hh==AlarmHH && mm==AlarmMM && ss>=AlarmSS) {
digitalWrite(buzzer, HIGH);
delay (300);
digitalWrite(buzzer, LOW);
}else{digitalWrite(buzzer, LOW);}
delay (100);
Received ();
void blinking (){
//BLINKING SCREEN
if (setAlarm <2 && setMode == 1){lcd.setCursor(0,0);  lcd.print("  ");}
if (setAlarm <2 && setMode == 2){lcd.setCursor(3,0);  lcd.print("  ");}
if (setAlarm <2 && setMode == 3){lcd.setCursor(6,0);  lcd.print("  ");}
if (setAlarm <2 && setMode == 4){lcd.setCursor(1,1);  lcd.print("   ");}
if (setAlarm <2 && setMode == 5){lcd.setCursor(5,1);  lcd.print("  ");}
if (setAlarm <2 && setMode == 6){lcd.setCursor(8,1);  lcd.print("  ");}
if (setAlarm <2 && setMode == 7){lcd.setCursor(11,1); lcd.print("    "); }
//Alarm
if (setMode == 0 && setAlarm == 1){lcd.setCursor(6,0); lcd.print("           "); }
if (setMode == 0 && setAlarm == 2){lcd.setCursor(4,1); lcd.print("  "); }
if (setMode == 0 && setAlarm == 3){lcd.setCursor(7,1); lcd.print("  "); }
if (setMode == 0 && setAlarm == 4){lcd.setCursor(10,1);lcd.print("  "); }
//Seting Jam ,Tanggal,Alarm/Timer
void setupClock (void) {
    if (setMode == 8){
    lcd.print (F("Set Date Finish "));
    lcd.print (F("Set Time Finish "));
    delay (1000);
    rtc.setTime (hh, mm, ss);
    rtc.setDate (dd, bb, yy);
    lcd.clear();
    setMode = 0;
    if (setAlarm == 5){
    lcd.print (F("Set Alarm Finish"));
    lcd.print (F("-EEPROM Updated-"));
    WriteEeprom();
    delay (2000);
    lcd.clear();
    setAlarm=0;
    alarmMode=1;
 if (setAlarm >0){ alarmMode=0;}
 if(digitalRead (bt_time) == 0 && flag==0) {flag=1;
 if(setAlarm>0){setAlarm=5;}
 else{setMode = setMode+1;}
 if(digitalRead (bt_alarm) == 0 && flag==0){flag=1;
 if(setMode>0){setMode=8;}
  else{setAlarm = setAlarm+1;}
  lcd.clear();}
if(digitalRead (bt_time) == 1 && digitalRead (bt_alarm) == 1){flag=0;}
 if(digitalRead (bt_up) == 0){
            if (setAlarm<2 && setMode==1)hh=hh+1;
            if (setAlarm<2 && setMode==2)mm=mm+1;
            if (setAlarm<2 && setMode==3)ss=ss+1;
            if (setAlarm<2 && setMode==4)set_day=set_day+1;
            if (setAlarm<2 && setMode==5)dd=dd+1;
            if (setAlarm<2 && setMode==6)bb=bb+1;
            if (setAlarm<2 && setMode==7)yy=yy+1;
            //Alarm
            if (setMode==0 && setAlarm==1)mode=1;
            if (setMode==0 && setAlarm==2 && AlarmHH<23)AlarmHH=AlarmHH+1;
            if (setMode==0 && setAlarm==3 && AlarmMM<59)AlarmMM=AlarmMM+1;
            if (setMode==0 && setAlarm==4 && AlarmSS<59)AlarmSS=AlarmSS+1;
if(hh>23)hh=0;
if(mm>59)mm=0;
if(ss>59)ss=0;
if(set_day>7)set_day=0;
if(dd>31)dd=0;
if(bb>12)bb=0;
if(yy>2030)yy=2000;
rtc.setDOW(set_day);
if(digitalRead (bt_down) == 0){
            if (setAlarm<2 && setMode==1)hh=hh-1;
            if (setAlarm<2 && setMode==2)mm=mm-1;
            if (setAlarm<2 && setMode==3)ss=ss-1;
            if (setAlarm<2 && setMode==4)set_day=set_day-1;
            if (setAlarm<2 && setMode==5)dd=dd-1;
            if (setAlarm<2 && setMode==6)bb=bb-1;
            if (setAlarm<2 && setMode==7)yy=yy-1;
            //Alarm
            if (setMode==0 && setAlarm==1 )mode=0;
            if (setMode==0 && setAlarm==2 && AlarmHH>0)AlarmHH=AlarmHH-1;
            if (setMode==0 && setAlarm==3 && AlarmMM>0)AlarmMM=AlarmMM-1;
            if (setMode==0 && setAlarm==4 && AlarmSS>0)AlarmSS=AlarmSS-1;
if(hh<0)hh=23;
if(mm<0)mm=59;
if(ss<0)ss=59;
if(set_day<0)set_day=7;
if(dd<0)dd=31;
if(bb<0)bb=12;
if(yy<0)yy=2030;
void setTimer (){
  //Alarm
 if (setMode == 0 && setAlarm >0){
  lcd.print("Alarm ");
 if(mode==0){lcd.print("Deactivate");}
        else{lcd.print("Activated ");}
  lcd.setCursor (4,1);
  lcd.print((AlarmHH/10)%10);
  lcd.print(AlarmHH % 10);
  lcd.print(":");
  lcd.print((AlarmMM/10)%10);
  lcd.print(AlarmMM % 10);
  lcd.print(":");
  lcd.print((AlarmSS/10)%10);
  lcd.print(AlarmSS % 10);
void ReadEeprom () {
  AlarmHH=EEPROM.read(1);
  AlarmMM=EEPROM.read(2);
  AlarmSS=EEPROM.read(3);
  mode=EEPROM.read(4);
void WriteEeprom () {
  EEPROM.write(1,AlarmHH);
  EEPROM.write(2,AlarmMM);
  EEPROM.write(3,AlarmSS);
  EEPROM.write(4,mode);
void Received ()
//String timeString = String(t.hour, DEC) + String(t.min, DEC) + String(t.sec, DEC);
//Serial.println(timeString);
//// Convert the current time to a string
//String timeStr = String(t.hour, DEC) + ":" + String(t.min, DEC) + ":" + String(t.sec, DEC);
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
   Serial.println(controller);
if (vw_get_message(buf, &buflen)) // Non-blocking
      if(buf[0]=='1')
      digitalWrite(13,HIGH);
      controller = "8";
//       // Send the current time to the receiver
//       vw_send((uint8_t *)timeStr.c_str(), timeStr.length());
//       vw_wait_tx();
       // Print the current time to the Serial Monitor
//       Serial.println(timeStr);
      char timeStr[20];
      sprintf(timeStr, "%02d:%02d:%02d", t.hour, t.min, t.sec);
      vw_send((uint8_t *)timeStr, strlen(timeStr));
      vw_wait_tx();
//      //vw_send((uint8_t *)controller, strlen(controller));
//      //vw_wait_tx();
//      delay(100);
//      vw_send((uint8_t *)timeString.c_str(), strlen(timeString.c_str()));
//      vw_wait_tx();
      digitalWrite(2,HIGH);
      digitalWrite(13,LOW);
      controller="2";
//      vw_send((uint8_t *)controller, strlen(controller));
//      vw_wait_tx();
//      delay(100);
//      vw_wait_tx();
Her is the other code used to receive the transmitted hour, minute and second
#include <Time.h>
char *controller;
char *msg;
const int buttonPin1 = 2;
int buttonState1 = 0;
// Define the pins used by the receiver
const int receiverPin = 12;
  pinMode(buttonPin1, INPUT);
  // Set the receiver pin as an input
  pinMode(receiverPin, INPUT);
  // Initialize the Time library
 // setTime(10, 30, 0, 1, 1, 2023);
  pinMode(11, OUTPUT);
  vw_set_tx_pin(12);
  vw_set_rx_pin(9);
  vw_setup(4000);// speed of data transfer Kbps
  delay(100);
  buttonState1 = digitalRead(buttonPin1);
  Serial.println(" controller ");
  if (buttonState1 == HIGH)
    controller = "1" ;
    vw_wait_tx(); // Wait until the whole message is gone
    delay(100);
    digitalWrite(13, LOW);
    controller = "0" ;
    digitalWrite(13, HIGH);
   Serial.println("             ");
   // The loop function runs repeatedly, forever
   // Define the buffer
   char buf[VW_MAX_PAYLOAD];
   // Check if there is a message from the transmitter
   if (vw_get_message(buf, VW_MAX_PAYLOAD)) {
    // Print the message from the transmitter
    for (int i = 0; i < VW_MAX_PAYLOAD; i++) {
      Serial.print(" buf[i] ");
      Serial.print(buf[i]);
      int hour = buf[0] * 10 + buf[1];
      int minute = buf[2] * 10 + buf[3];
      int second = buf[4] * 10 + buf[5];
      // Print the hour, minute, and second separately
      Serial.print("Hour: ");
      Serial.println(hour);
      Serial.print("Minute: ");
      Serial.println(minute);
      Serial.print("Second: ");
      Serial.println(second);
      Serial.print(" buf[0] ");
      Serial.print(buf[0]);
      Serial.print("buf[1]");
      Serial.print(buf[1]);
      Serial.print("buf[2]");
      Serial.print(buf[2]);
      Serial.print("buf[3]");
      Serial.print(buf[3]);
For debugging radio message transmission, it is much easier to get that working starting from a simple example program, before adding all the baggage.
Hello abel706
For wireless projects I recommend the use of the HC12 module.
What are the advantages:
  1. no external functions from a library are needed.
  2. the development of a communication protocol is in your hands
  3. the necessary development steps can be programmed and tested without using the wireless module
  4. the radio module can be easily configured for the project requirements
  5. both transmitter and receiver are contained in one radio module.
I have tried it again by losing DEC but the result is the same. Here i have formatted the code
#include <EEPROM.h>
#define bt_time   A0
#define bt_up     A1
#define bt_down   A2
#define bt_alarm  A3
#define buzzer 8
//rf variables
char *controller;
char *temp;
int yy = 0;
String Day = "  ";
int AlarmHH  = 21, AlarmMM  = 22, AlarmSS  = 23, setMode = 0, setAlarm = 0, alarmMode = 0;
int stop = 0, mode = 0, flag = 0;
uint8_t HH;
uint8_t MM;
  B00100,
  B01110,
  B01110,
  B01110,
  B01110,
  B11111,
  B01000,
  B00100
  B00100,
  B01010,
  B01010,
  B01110,
  B01110,
  B11111,
  B11111,
  B01110
  lcd.setCursor(0, 0); //Show "TIME" on the LCD
  lcd.setCursor (0, 0);
  lcd.setCursor (0, 1);
  delay (2000);
  lcd.clear();
  stop = EEPROM.read(50);
  if (stop == 0) {
    WriteEeprom ();
  EEPROM.write(50, 0);
  ReadEeprom();
  //Set RTC Untuk Pertama kali
  //rtc.setDOW(2);     // Set Day-of-Week to SUNDAY
  //rtc.setTime (00, 9, 50);
  //rtc.setDate(12, 11, 2017);
  //rf pin starting
  vw_set_rx_pin(7);
  vw_set_tx_pin(9);
  pinMode(2, OUTPUT);
  t = rtc.getTime();
  if (setMode == 0) {
    hh = t.hour;
    mm = t.min;
    ss = t.sec;
    dd = t.date;
    bb = t.mon;
    yy = t.year;
  if (setAlarm == 0) {
    lcd.print((hh / 10) % 10);
    lcd.print(hh % 10);
    lcd.print(":");
    lcd.print((mm / 10) % 10);
    lcd.print(mm % 10);
    lcd.print(":");
    lcd.print((ss / 10) % 10);
    lcd.print(ss % 10);
    lcd.print(" ");
    if (mode == 1) {
      lcd.write(2);
    else {
      lcd.print(" ");
    lcd.print(" ");
    lcd.write(1);
    lcd.print(rtc.getTemp(), 0);
    lcd.write(223);
    lcd.print("C");
    lcd.print("  ");
    lcd.setCursor(1, 1);
    lcd.print(Day);
    lcd.print(" ");
    lcd.print((dd / 10) % 10);
    lcd.print(dd % 10);
    lcd.print("/");
    lcd.print((bb / 10) % 10);
    lcd.print(bb % 10);
    lcd.print("/");
    lcd.print((yy / 1000) % 10);
    lcd.print((yy / 100) % 10);
    lcd.print((yy / 10) % 10);
    lcd.print(yy % 10);
  setupClock();
  setTimer();
  delay (100);
  blinking();
  //Alarm
  if (alarmMode == 1 && mode == 1 && hh == AlarmHH && mm == AlarmMM && ss >= AlarmSS) {
    delay (300);
  delay (100);
  Received ();
void blinking () {
  //BLINKING SCREEN
  if (setAlarm < 2 && setMode == 1) {
    lcd.print("  ");
  if (setAlarm < 2 && setMode == 2) {
    lcd.setCursor(3, 0);
    lcd.print("  ");
  if (setAlarm < 2 && setMode == 3) {
    lcd.setCursor(6, 0);
    lcd.print("  ");
  if (setAlarm < 2 && setMode == 4) {
    lcd.print("   ");
  if (setAlarm < 2 && setMode == 5) {
    lcd.setCursor(5, 1);
    lcd.print("  ");
  if (setAlarm < 2 && setMode == 6) {
    lcd.setCursor(8, 1);
    lcd.print("  ");
  if (setAlarm < 2 && setMode == 7) {
    lcd.setCursor(11, 1);
    lcd.print("    ");
  //Alarm
  if (setMode == 0 && setAlarm == 1) {
    lcd.print("           ");
  if (setMode == 0 && setAlarm == 2) {
    lcd.setCursor(4, 1);
    lcd.print("  ");
  if (setMode == 0 && setAlarm == 3) {
    lcd.setCursor(7, 1);
    lcd.print("  ");
  if (setMode == 0 && setAlarm == 4) {
    lcd.setCursor(10, 1);
    lcd.print("  ");
  if (setMode == 8) {
    delay (1000);
    lcd.clear();
    setMode = 0;
  if (setAlarm == 5) {
    WriteEeprom();
    delay (2000);
    lcd.clear();
    setAlarm = 0;
    alarmMode = 1;
  if (setAlarm > 0) {
    alarmMode = 0;
  if (digitalRead (bt_time) == 0 && flag == 0) {
    flag = 1;
    if (setAlarm > 0) {
      setAlarm = 5;
    else {
      setMode = setMode + 1;
  if (digitalRead (bt_alarm) == 0 && flag == 0) {
    flag = 1;
    if (setMode > 0) {
      setMode = 8;
    else {
      setAlarm = setAlarm + 1;
    lcd.clear();
  if (digitalRead (bt_time) == 1 && digitalRead (bt_alarm) == 1) {
    flag = 0;
  if (digitalRead (bt_up) == 0) {
    if (setAlarm < 2 && setMode == 1)hh = hh + 1;
    if (setAlarm < 2 && setMode == 2)mm = mm + 1;
    if (setAlarm < 2 && setMode == 3)ss = ss + 1;
    if (setAlarm < 2 && setMode == 4)set_day = set_day + 1;
    if (setAlarm < 2 && setMode == 5)dd = dd + 1;
    if (setAlarm < 2 && setMode == 6)bb = bb + 1;
    if (setAlarm < 2 && setMode == 7)yy = yy + 1;
    //Alarm
    if (setMode == 0 && setAlarm == 1)mode = 1;
    if (setMode == 0 && setAlarm == 2 && AlarmHH < 23)AlarmHH = AlarmHH + 1;
    if (setMode == 0 && setAlarm == 3 && AlarmMM < 59)AlarmMM = AlarmMM + 1;
    if (setMode == 0 && setAlarm == 4 && AlarmSS < 59)AlarmSS = AlarmSS + 1;
    if (hh > 23)hh = 0;
    if (mm > 59)mm = 0;
    if (ss > 59)ss = 0;
    if (set_day > 7)set_day = 0;
    if (dd > 31)dd = 0;
    if (bb > 12)bb = 0;
    if (yy > 2030)yy = 2000;
  if (digitalRead (bt_down) == 0) {
    if (setAlarm < 2 && setMode == 1)hh = hh - 1;
    if (setAlarm < 2 && setMode == 2)mm = mm - 1;
    if (setAlarm < 2 && setMode == 3)ss = ss - 1;
    if (setAlarm < 2 && setMode == 4)set_day = set_day - 1;
    if (setAlarm < 2 && setMode == 5)dd = dd - 1;
    if (setAlarm < 2 && setMode == 6)bb = bb - 1;
    if (setAlarm < 2 && setMode == 7)yy = yy - 1;
    //Alarm
    if (setMode == 0 && setAlarm == 1 )mode = 0;
    if (setMode == 0 && setAlarm == 2 && AlarmHH > 0)AlarmHH = AlarmHH - 1;
    if (setMode == 0 && setAlarm == 3 && AlarmMM > 0)AlarmMM = AlarmMM - 1;
    if (setMode == 0 && setAlarm == 4 && AlarmSS > 0)AlarmSS = AlarmSS - 1;
    if (hh < 0)hh = 23;
    if (mm < 0)mm = 59;
    if (ss < 0)ss = 59;
    if (set_day < 0)set_day = 7;
    if (dd < 0)dd = 31;
    if (bb < 0)bb = 12;
    if (yy < 0)yy = 2030;
void setTimer () {
  //Alarm
  if (setMode == 0 && setAlarm > 0) {
    if (mode == 0) {
    else {
    lcd.setCursor (4, 1);
    lcd.print((AlarmHH / 10) % 10);
    lcd.print(":");
    lcd.print((AlarmMM / 10) % 10);
    lcd.print(":");
    lcd.print((AlarmSS / 10) % 10);
  AlarmHH = EEPROM.read(1);
  AlarmMM = EEPROM.read(2);
  AlarmSS = EEPROM.read(3);
  mode = EEPROM.read(4);
  EEPROM.write(1, AlarmHH);
  EEPROM.write(2, AlarmMM);
  EEPROM.write(3, AlarmSS);
  EEPROM.write(4, mode);
void Received ()
    if (buf[0] == '1')
      controller = "8";
      //       vw_wait_tx();
      char timeStr[20];
      vw_wait_tx();
      //      //vw_wait_tx();
      //      delay(100);
      //      vw_wait_tx();
      digitalWrite(2, HIGH);
      controller = "2";
#include <Time.h>
char *controller;
char *msg;
  vw_set_tx_pin(12);
  vw_set_rx_pin(9);
  delay(100);
    controller = "1" ;
    delay(100);
    controller = "0" ;
      // Extract the hour, minute, and second from the data
      int hour = buf[0] + buf[1] * 10;
      int minute = buf[2] + buf[3] * 10;
      int second = buf[4] + buf[5] * 10;
      Serial.print("The time is ");
      Serial.print(hour);
      Serial.print(":");
      Serial.print(minute);
      Serial.print(":");
I have only RF433Hz module I don't have HC12
+1
And, get it working over a wired link before adding all the complexities of radios!
