How to tune PID for a quadcopter?
Hi!
I am trying to calibrate my PID for my quadcopter but it goes crazy, Ive tried to calculate in the order P, I, D but that doesnt work to good, Ive tried D, P, I doesnt work either... I manage to get my drone flying only using P and D, but now it goes completley crazy, here a video of how it behaves:
and here is my code:
#include <Adafruit_Sensor.h>
#include <Adafruit_BNO055.h>
#include <utility/imumaths.h>
#include <Servo.h>
#include <nRF24L01.h>
#include <SPI.h>
#include <RF24.h>
#include <printf.h>
#define CE_PIN   9
#define CSN_PIN 10
// Create Radio and define pins
RF24 radio(CE_PIN, CSN_PIN);
// Create Radio channels
const uint64_t pAddress = 0xB00B1E5000LL;
const uint64_t fAddress = 0xC3C3C3C3C3LL;
// Create a boolean for connection lost
bool lostConnection = false;
// Flight modes
bool acro, autoLevel = true, holdPosition, launchMode = true;
//Radio recived array
float recivedDataArray[8];
float feedbackArray[5];
Servo motor_LF;
Servo motor_RF;
Servo motor_LB;
Servo motor_RB;
Adafruit_BNO055 bno = Adafruit_BNO055(-1, 0x28);
imu::Vector<3> gyro;
bool setZeroBool = true;
float previousMessageMillis;
float input_throttle = 1000;
float input_yaw = 0;
float input_pitch = 0;
float input_roll = 0;
/* Roll PID */
float roll_PID, pid_throttle_L_F, pid_throttle_L_B, pid_throttle_R_F, pid_throttle_R_B, roll_error, roll_previous_error;
float roll_pid_p = 0;
float roll_pid_i = 0;
float roll_pid_d = 0;
/* Roll PID Constants */
double roll_kp = 2;
double roll_ki = 0.001;
double roll_kd = 10;
float roll_desired_angle = 0;
/* Pitch PID */
float pitch_PID, pitch_error, pitch_previous_error;
float pitch_pid_p = 0;
float pitch_pid_i = 0;
float pitch_pid_d = 0;
/* Pitch PID Constants */
double pitch_kp = roll_kp;
double pitch_ki = roll_ki;
double pitch_kd = roll_kd;
float pitch_desired_angle = 0;
/* Yaw PID */
float yaw_PID, yaw_error, yaw_previous_error;
float yaw_pid_p = 0;
float yaw_pid_i = 0;
float yaw_pid_d = 0;
double yaw_kp = 0; //0.5
double yaw_ki = 0;
double yaw_kd = 0; //5
float yaw_desired_angle = 0;
int yaw_pid_max = 200;
int pid_max = 400;
float pitchOffset = 0, rollOffset = 0;
  Wire.begin();
  while (!Serial);
  printf_begin();
  if (!bno.begin())
    Serial.print("Error, no BNO055 detected ... Check your wiring or I2C ADDR!");
    while (1);
  int8_t temp = bno.getTemp();
  bno.setExtCrystalUse(true);
  if (!radio.begin()) {
    Serial.println(F("radio hardware is not responding!!"));
    while (1) {}
  radio.setPALevel(RF24_PA_MAX);
  radio.openReadingPipe(1, pAddress);
  radio.openWritingPipe(fAddress);
  radio.printDetails();
  //radio.printDetails();
  radio.startListening();
  delay(5000);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  motor_LF.attach(5);
  motor_RF.attach(6);
  motor_LB.attach(7);
  motor_RB.attach(8);
  motor_LF.writeMicroseconds(1000);
  motor_RF.writeMicroseconds(1000);
  motor_LB.writeMicroseconds(1000);
  motor_RB.writeMicroseconds(1000);
  if(autoLevel == true || holdPosition == true) {
    gyro = bno.getVector(Adafruit_BNO055::VECTOR_EULER);
    //Serial.println("VECTOR_EULER");
  } else if(acro == true) {
    gyro = bno.getVector(Adafruit_BNO055::VECTOR_GYROSCOPE);
    //Serial.println("VECTOR_GYROSCOPE");
    //Serial.println("Else");
  if (!lostConnection) {
    if (radio.available()) {
      radio.read(&recivedDataArray, sizeof(recivedDataArray));
      //Serial.println("Recieved array:");
      previousMessageMillis = millis();
      for (byte i = 0; i < 4; i++) {
        //Serial.println(recivedDataArray[i]);
      input_throttle = recivedDataArray[0];
      yaw_desired_angle += recivedDataArray[1];
      roll_desired_angle = recivedDataArray[2] + rollOffset;
      pitch_desired_angle = -recivedDataArray[3] + pitchOffset;
      if(recivedDataArray[4] == 1) {
        acro = true;
        autoLevel = false;
        holdPosition = false;
      } else if(recivedDataArray[4] == 2) {
        acro = false;
        autoLevel = true;
      } else if(recivedDataArray[4] == 3) { // ICKE AKTIVERAD ÄNNU, KOM IHÅG
        acro = false;
        autoLevel = true;
      //Serial.println();
    if(yaw_desired_angle > 360) {
    } else if(yaw_desired_angle < 0) {
      yaw_desired_angle = 360;
    if (input_throttle > 1600) {
      input_throttle = 1600;
    } else if (input_throttle < 1000) {
    if(millis() >= 15000) {
      launchMode = false;
    SetZero(gyro.x(), gyro.y(), gyro.z());
    PIDControl(gyro.x(), gyro.y(), gyro.z());
    if (millis() - previousMessageMillis >= 400) {
      PID_reset();
      motor_LF.writeMicroseconds(pid_throttle_L_F);
      motor_RF.writeMicroseconds(pid_throttle_R_F);
      motor_LB.writeMicroseconds(pid_throttle_L_B);
      motor_RB.writeMicroseconds(pid_throttle_R_B);
    //print_roll_pitch_yaw(gyro.x(), gyro.y(), gyro.z());
    //printDesiredAngles();
    //print_PID();
    print_throttle();
    //print_detailed_PID();
    //printDesiredYaw(gyro.z());
    PID_reset();
    Serial.println("LOST CONNECTION!");
    //delay(2000);
  //sendFeedback(gyro.x(), gyro.y(), gyro.z());
  delay(10);
void sendFeedback(float x, float y, float z) {
  feedbackArray[0] = x;
  feedbackArray[1] = z;
  feedbackArray[2] = y;
  if(autoLevel == true) {
    feedbackArray[3] = 1;
    feedbackArray[3] = 2;
  } else if(holdPosition == true) {
    feedbackArray[3] = 3;
  radio.stopListening();
  radio.write( &feedbackArray, sizeof(feedbackArray));
void PIDControl(float x, float y, float z) {
  if (input_throttle > 1050) {
    /* PID */
    roll_error = roll_desired_angle - y;
    pitch_error = pitch_desired_angle - z;
    yaw_error = yaw_desired_angle - x;
    /* Prospect */
    roll_pid_p = roll_kp * roll_error;
    pitch_pid_p = pitch_kp * pitch_error;
    yaw_pid_p = yaw_kp * yaw_error;
    // Integral
    if(launchMode) {
      roll_pid_i = 0;
      pitch_pid_i = 0;
      yaw_pid_i = 0;
    } else if(!launchMode) {
    roll_pid_i += roll_ki * roll_error;
    pitch_pid_i += pitch_ki * pitch_error;
    yaw_pid_i += yaw_ki * yaw_error;
    // Derivate
    roll_pid_d = roll_kd * (roll_error - roll_previous_error);
    pitch_pid_d = pitch_kd * (pitch_error - pitch_previous_error);
    yaw_pid_d = yaw_kd * (yaw_error - yaw_previous_error);
    // ROLL
    if (roll_pid_i > pid_max) roll_pid_i = pid_max;
    else if (roll_pid_i < pid_max * -1)
      roll_pid_i = pid_max * -1;
    roll_PID = roll_pid_p + roll_pid_i + roll_pid_d;
    if (roll_PID > pid_max) roll_PID = pid_max;
    else if (roll_PID < pid_max * -1)
      roll_PID = pid_max * -1;
    // PITCH
    if (pitch_pid_i > pid_max) pitch_pid_i = pid_max;
    else if (pitch_pid_i < pid_max * -1)
      pitch_pid_i = pid_max * -1;
    pitch_PID = pitch_pid_p + pitch_pid_i + pitch_pid_d;
    if (pitch_PID > pid_max) pitch_PID = pid_max;
    else if (pitch_PID < pid_max * -1)
      pitch_PID = pid_max * -1;
    // YAW
    if (yaw_pid_i > yaw_pid_max) yaw_pid_i = yaw_pid_max;
    else if (yaw_pid_i < yaw_pid_max * -1)
      yaw_pid_i = yaw_pid_max * -1;
    yaw_PID = yaw_pid_p + yaw_pid_i + yaw_pid_d;
    if (yaw_PID > yaw_pid_max) yaw_PID = yaw_pid_max;
    else if (yaw_PID < yaw_pid_max * -1)
      yaw_PID = yaw_pid_max * -1;
    /* Set the throttle PID for each motor */
    pid_throttle_L_F = input_throttle + roll_PID + pitch_PID - yaw_PID;
    pid_throttle_R_F = input_throttle - roll_PID + pitch_PID + yaw_PID;
    pid_throttle_L_B = input_throttle + roll_PID - pitch_PID + yaw_PID;
    pid_throttle_R_B = input_throttle - roll_PID - pitch_PID - yaw_PID;
    /* Save Previous Error */
    roll_previous_error = roll_error;
    pitch_previous_error = pitch_error;
    yaw_previous_error = yaw_error;
    /* Regulate throttle for ESCs */
    //Right front
    if (pid_throttle_R_F < 1100) {
      pid_throttle_R_F = 1100;
    if (pid_throttle_R_F > 2000) {
      pid_throttle_R_F = 2000;
    //Left front
    if (pid_throttle_L_F < 1100) {
      pid_throttle_L_F = 1100;
    if (pid_throttle_L_F > 2000) {
      pid_throttle_L_F = 2000;
    //Right back
    if (pid_throttle_R_B < 1100) {
      pid_throttle_R_B = 1100;
    if (pid_throttle_R_B > 2000) {
      pid_throttle_R_B = 2000;
    //Left back
    if (pid_throttle_L_B < 1100) {
      pid_throttle_L_B = 1100;
    if (pid_throttle_L_B > 2000) {
      pid_throttle_L_B = 2000;
    PID_reset();
void print_roll_pitch_yaw(float x, float y, float z) {
  Serial.print(z);
  Serial.print(", ");
  Serial.println(y);
void printDesiredAngles() {
  Serial.print(roll_desired_angle);
  Serial.print(",");
  Serial.println(pitch_desired_angle);
void printDesiredYaw(float yaw) {
  Serial.print(yaw_desired_angle);
  Serial.print(",");
  Serial.println(yaw);
void print_throttle() {
  Serial.print(pid_throttle_L_F);
  Serial.print("   ");
  Serial.println(pid_throttle_R_F);
  Serial.print(pid_throttle_L_B);
  Serial.print("   ");
  Serial.println(pid_throttle_R_B);
void print_PID() {
  Serial.print(roll_PID);
  Serial.print(", ");
  Serial.print(pitch_PID);
  Serial.print(", ");
  Serial.println(yaw_PID);
void print_detailed_PID() {
  Serial.print(pitch_pid_p);
  Serial.print(", ");
  Serial.print(pitch_pid_i);
  Serial.print(", ");
  Serial.print(pitch_pid_d);
  Serial.print(", ");
  Serial.println(pitch_PID);
void SetZero(float x, float y, float z) {
  if (setZeroBool) {
      pitchOffset = y;
      rollOffset = z;
      yaw_desired_angle = x;
      setZeroBool = false;
void PID_reset() {
  pid_throttle_L_F = 1000;
  pid_throttle_L_B = 1000;
  pid_throttle_R_F = 1000;
  pid_throttle_R_B = 1000;
  pitch_PID = 0, roll_PID = 0, yaw_PID = 0;
  roll_error = 0, pitch_error = 0, yaw_error = 0;
  roll_previous_error = 0, pitch_previous_error = 0, yaw_previous_error = 0;
  yaw_pid_p = 0, roll_pid_p = 0, pitch_pid_p = 0;
  yaw_pid_i = 0, roll_pid_i = 0, pitch_pid_i = 0;
  yaw_pid_d = 0, roll_pid_d = 0, pitch_pid_d = 0;
Thanks in advance
Best regards Max
I hope you’ve watched 11,000 youtube videos on how to tune.
IMO you are not yet at the point of flying or tuning for doing.
I suggest you start with one axis at a time.
Constrain the quadcopter with a system of cords so it can, say, roll but do nothing else.
So we talking roll.
Next, back off the attempt to do a stabilised PID. For now, use only the gyro and attempt to get a tethered hover - zero rate of rotation is the goal.
This eliminates the control signal as it will be fixed input of mid-range, stick straight up.
Oh, wait, it looks like you doing just gyro, that is to say rate mode or acro?
Have you done much flying with rate mode? It is hard enough with a well-tuned quadcopter… just sayin’.
With a monster like you have in front of you, I again recommend the rough tuning using a constraint system, you can see it in many youtubes. The power that can be unleashed might turn all your work into trash, even if it didn’t also inflict severe injuries on the cat. Or yourself. Again, see youtube for gory evidence.
There will be nothing like seeing, eventually, your quadcopter rolling slowly back and forth at the rate you input from your controller.
You have come a long way and I think the light at the end of the tunnel may not just be a train headed towards you…
You could prolly also do some testing with a constrained quadcopter but not running the motors. Have you put your PID algorithm under enough instrumentation to see if everything is plausible?
I haven’t looked close at the code, but there are a few places where some values might not be at all what they need to be nor what you think.
The brief video looks like you have a fairly slow loop rate. What time step are you achieving, and how does this mesh with you theory?
I’d ask if you are just winging it, but of course quadcopters do not have. Wings. :wink:
a7
Hi!
Sorry for the late response, I am starting to go crazy with this auto level mode, I dont understand. I made a rework/minimazation/optimisation of the code to get a much higher loop rate, but it always "overshoots" and even if I use low values it "slowly" overshoots a lot.
I am wondering if I want to go back to ACRO mode but I still need my PID calculation to keep the desired degree per escond, and it will not work if it keeps overshooting... :upside_down_face:
//Max
I agree with myself this time:
You should try acro (gyro only) PID loops, and get pitch and roll operating well when the quadcopter is constrained so you can look at one axis at a time.
If you can't get acro going, stabilised will be a real challenge.
You can even do some tuning with no props. Play with the orientation of the quad/no props and get a feel how the system is responding to you physical input on the quad.
I haven't flown low about your code. How do the traditional "rates" enter your stabilised PID calculations?
Like I fly cro with the roll rate set at 940 degrees per second - full stick deflection means roll 360 degrees 2.6 times per second.
Or is it just maximum angular rate to attain the input angle?
a7
@lordmax2
I Made some adjustments to your code to help, I couldn't test it but this is a starting direction to simplify the PID tuning.
My balancing bot PID tuning 2-minute clip should help as it is similar:
#include <Servo.h>
#include <SPI.h>
#include <RF24.h>
#include <printf.h>
#define CE_PIN   9
#define CSN_PIN 10
// Flight modes
Servo motor_LF;
Servo motor_RF;
Servo motor_LB;
Servo motor_RB;
/* Roll PID */
double roll_kp = 2;
/* Pitch PID */
/* Yaw PID */
double yaw_ki = 0;
int pid_max = 400;
  Wire.begin();
  while (!Serial);
  printf_begin();
  if (!bno.begin())
    while (1);
    while (1) {}
  delay(5000);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  motor_LF.attach(5);
  motor_RF.attach(6);
  motor_LB.attach(7);
  motor_RB.attach(8);
  if (autoLevel == true || holdPosition == true) {
  } else if (acro == true) {
  GetRadio();
  if (LostConnection) {
    PID_reset();
    GoodConnection();
void GetRadio() {
    if (recivedDataArray[4] == 1) {
      acro = true;
      autoLevel = false;
    } else if (recivedDataArray[4] == 2) {
      acro = false;
      autoLevel = true;
    } else if (recivedDataArray[4] == 3) { // ICKE AKTIVERAD ÄNNU, KOM IHÅG
      acro = false;
      autoLevel = true;
    //Serial.println();
    lostConnection = true;
void GoodConnection() {
  if (yaw_desired_angle > 360) {
  } else if (yaw_desired_angle < 0) {
  if (millis() >= 15000) {
    launchMode = false;
  //print_PID();
  print_throttle();
  if (autoLevel == true) {
  } else if (holdPosition == true) {
    /* PID */
    /* Prospect */
    //Proportional dowsn't need any delay any change can be used instantly
    //Integral and Derivative need a delay 10 ms should be enough. We will use an exact delay to speed up the process
    // if you dont use a delay integral will wind up fast
    // Derivitive will not see any substantial change to be usefull
    static unsigned long _ExactTimer;
    if (( millis() - _ExactTimer) >= (10)) {
      _ExactTimer += (10);
      if (( millis() - _ExactTimer) >= (1))_ExactTimer = millis(); // prevents timer windup
      // Integral
      if (launchMode) {
        roll_pid_i = 0;
        pitch_pid_i = 0;
        yaw_pid_i = 0;
      } else (!launchMode) {
        roll_pid_i = roll_pid_i + (roll_ki * roll_error);
        if (roll_pid_i < (pid_max * -1)) roll_pid_i = pid_max * -1;
        if (pitch_pid_i < pid_max * -1) pitch_pid_i = pid_max * -1;
        if (yaw_pid_i < yaw_pid_max * -1) yaw_pid_i = yaw_pid_max * -1;
      // Derivate
    // ROLL
    // PITCH
    // YAW
    //Right front
    //Left front
    //Right back
    //Left back
    PID_reset();
  Serial.print(z);
  Serial.print(", ");
  Serial.println(y);
  Serial.print(",");
  Serial.print(",");
  Serial.print("   ");
  Serial.print("   ");
void print_PID() {
  Serial.print(", ");
  Serial.print(", ");
  Serial.print(", ");
  Serial.print(", ");
  Serial.print(", ");
  if (setZeroBool) {
    pitchOffset = y;
    rollOffset = z;
void PID_reset() {
Thank you! I will test it out!
