Hi all.
how to use for loop multiple condition?
for (int inc = 0, int col = 0; inc < 81, col < 59; inc++, col =+1) {
or:
for (int inc = 0, int col = 0; inc < 81 && col < 59; inc++, col =+1) {
Thanks
Adam
Hi all.
or:
Thanks
Adam
Neither compiles. So don't use either.
Once fixed, they both compile
for (int inc = 0, col = 0; inc < 81, col < 59; inc++, col =+1) {
for (int inc = 0, col = 0; inc < 81 && col < 59; inc++, col =+1) {
But it looks like the second one is what you want. At a glance, however, col will hit 59 and terminate the loop long before inc never reaches 81.
Also why add 1 for one variable, and increment the other?
for (int inc = 0, col = 0; inc < 81 && col < 59; inc++, col++) {
Review the syntax of the comma operator.
Also, what are you trying to do with this multiple conditions loop? I have to confess it looks to me
like you are trying for something other that what the loop does...
a7
Fixes aside, what you are doing is running diagonally through a 2D matrix, hitting only those locations where inc=col, unless you start manipulating one of the two counters within the loop.
So yeah, what are you trying to do?
Thank you alto777.
the multi condition for-loop I'm try to use in TFT_ArcFill from:
that was designed to fill arc inside loop function that is relatively easy?
I'd like to put the fillRac in the setup function, that's why need a for-loop.
/* https://github.com/Bodmer/TFT_eSPI/blob/master/examples/320%20x%20240/TFT_ArcFill/TFT_ArcFill.ino
// Demo using arcFill to draw ellipses and a segmented elipse
#include <TFT_eSPI.h> // Hardware-specific library
#include <SPI.h>
TFT_eSPI tft = TFT_eSPI(); // Invoke custom library
#define DEG2RAD 0.0174532925
#define LOOP_DELAY 10 // Loop delay to slow things down
byte inc = 0;
unsigned int col = 0;
byte red = 31; // Red is the top 5 bits of a 16 bit colour value
byte green = 0;// Green is the middle 6 bits
byte blue = 0; // Blue is the bottom 5 bits
byte state = 0;
void setup(void) {
tft.begin();
tft.setRotation(1);
tft.fillScreen(TFT_BLACK);
// Continuous elliptical arc drawing
fillArc(160, 120, inc * 6, 1, 140, 100, 10, rainbow(col));
// Continuous segmented (inc*2) elliptical arc drawing
fillArc(160, 120, ((inc * 2) % 60) * 6, 1, 120, 80, 30, rainbow(col));
// Circle drawing using arc with arc width = radius
fillArc(160, 120, inc * 6, 1, 42, 42, 42, rainbow(col));
inc++;
col += 1;
if (col > 191) col = 0;
if (inc > 59) inc = 0;
delay(LOOP_DELAY);
// Draw a circular or elliptical arc with a defined thickness
// x,y == coords of centre of arc
// start_angle = 0 - 359
// seg_count = number of 6 degree segments to draw (60 => 360 degree arc)
// rx = x axis outer radius
// ry = y axis outer radius
// w = width (thickness) of arc in pixels
// colour = 16 bit colour value
// Note if rx and ry are the same then an arc of a circle is drawn
void fillArc(int x, int y, int start_angle, int seg_count, int rx, int ry, int w, unsigned int colour)
byte seg = 6; // Segments are 3 degrees wide = 120 segments for 360 degrees
byte inc = 6; // Draw segments every 3 degrees, increase to 6 for segmented ring
// Calculate first pair of coordinates for segment start
float sx = cos((start_angle - 90) * DEG2RAD);
float sy = sin((start_angle - 90) * DEG2RAD);
uint16_t x0 = sx * (rx - w) + x;
uint16_t y0 = sy * (ry - w) + y;
uint16_t x1 = sx * rx + x;
uint16_t y1 = sy * ry + y;
// Draw colour blocks every inc degrees
for (int i = start_angle; i < start_angle + seg * seg_count; i += inc) {
// Calculate pair of coordinates for segment end
float sx2 = cos((i + seg - 90) * DEG2RAD);
float sy2 = sin((i + seg - 90) * DEG2RAD);
int x2 = sx2 * (rx - w) + x;
int y2 = sy2 * (ry - w) + y;
int x3 = sx2 * rx + x;
int y3 = sy2 * ry + y;
tft.fillTriangle(x0, y0, x1, y1, x2, y2, colour);
tft.fillTriangle(x1, y1, x2, y2, x3, y3, colour);
// Copy segment end to sgement start for next segment
x0 = x2;
y0 = y2;
x1 = x3;
y1 = y3;
// Return the 16 bit colour with brightness 0-100%
unsigned int brightness(unsigned int colour, int brightness)
byte red = colour >> 11;
byte green = (colour & 0x7E0) >> 5;
byte blue = colour & 0x1F;
blue = (blue * brightness) / 100;
green = (green * brightness) / 100;
red = (red * brightness) / 100;
return (red << 11) + (green << 5) + blue;
// Return a 16 bit rainbow colour
unsigned int rainbow(byte value)
// Value is expected to be in range 0-127
// The value is converted to a spectrum colour from 0 = blue through to 127 = red
switch (state) {
case 0:
green ++;
if (green == 64) {
green = 63;
state = 1;
case 1:
red--;
if (red == 255) {
red = 0;
state = 2;
case 2:
blue ++;
if (blue == 32) {
blue = 31;
state = 3;
case 3:
green --;
if (green == 255) {
green = 0;
state = 4;
case 4:
red ++;
if (red == 32) {
red = 31;
state = 5;
case 5:
blue --;
if (blue == 255) {
blue = 0;
state = 0;
return red << 11 | green << 5 | blue;
the modified code put fillArc as a class FillArc_loop() and put in setup:
#include "HCONFIG.h"
#include "Ajpeg.h"
void setup(void) {
tft.begin();
tft.setRotation(1);
tft.setSwapBytes(true);
/// tft.pushImage(0, 0, 320, 240, pict1);
tft.pushImage(Cx0, Cy0, wt0, ht0, image_test);
FillArc_loop();
void FillArc_loop() {
for (inc = 0, col = 0; inc < 81, col < 59; inc++, col =+1) {
fillArc(Cxarc, Cyarc, inc * 6, 1, Rax, Ray, 10, TFT_RED);
fillArc(Cxarc, Cyarc, inc * 6, 1, Rax - 20, Ray - 20, 10, TFT_WHITE);
delay(LOOP_DELAY);
Maybe col += 1 ?
But then, as @alto777 said, why use ++ on one and += on the other? ![]()
Maybe col=col+1?
I, not alone perhaps, lsdyexised and saw col += 1;
Now about this clever bit of code:
for (int row=0, col=0; row < NUM_ROWS; (++col < NUM_COLS) ? :(col=0 , row++)){
I haven't run across anything like that. And… I hope I never do. In the absence of your complete sketch that does indeed what you say, I would not have been able to tell you what that does. I would not get the job.
Is there something you don't like about nested loops? I dare say @shanren might do better with them for awhile…
a7
Thank you Delta_G.
what I like to have is tft.fillArc and tft.fillTriangle works at same code.
yes, it is.
Thanks.
sure I like any thing new and better.
this topic can be simple as how to put the function below inside setup().
inc++;
col += 1;
delay(LOOP_DELAY);
inc++; col += 1;
There you go again - why do you use ++ for one variable, but +=1 for the other?
Why not be consistent?
be consistent
yes. should be consistent better.
you are right. testing shown that. I'll set both inc and col < 60.
this answers none of them
Thank you for many helps.
Sorry of if any missed answer.
--- one question from #4 was answered at #10 indirectly;
--- 2 questions in #6 was answered in #9, answers may not so relevant;
--- #11: to be honestly, I am not quite understand the meaning of;
--- #14 was answered in #16;
--- #17: here now: I'll attach pictures to show what the code for and how the result is, may better the my description.
fillRac:
fillTriangle:
what I like to have is both of them appear on screen, with both of the functions sit in setup.
THANKS FOR ALL, QUESTION IS SOLVED by set inc = col = 60.
