How to use INPUT_PULLUP with dip switch
I've been trying to read if my dipswitches are on or off to perform different actions, but INPUT_PULLUP doesn't seem to work.
Here's some of my code:
#include <Servo.h>
int valorMap = 0;
int valorFoto = 0;
int miservo = 0;
int valorPot = 0;
Servo servo_2;
pinMode(A0, INPUT);
pinMode(A4, INPUT_PULLUP);
pinMode(A5, INPUT_PULLUP);
pinMode(A2, INPUT_PULLUP);
pinMode(A3, INPUT_PULLUP);
servo_2.attach(2);
int switch1 = digitalRead(A2);
Serial.println(switch1);
int switch2 = digitalRead(A3);
Serial.println(switch2);
if (switch1 == LOW && switch2 == LOW){
valorPot = analogRead(A0);
valorMap = map(valorPot, 0, 1023, 0, 179);
servo_2.write(valorMap);
delay(10); // Delay a little bit to improve simulation performance
Here's how my dipswitches are connected, yelloew cables are cobected to A2 and A3:
Let’s see an image of the bottom (lead side) of the switches.
The two switch leads need to strattle the center of the breadboard
Hello
post a picture of your hardware setup.
You have shorted out the switches by plugging into the same connector rows - DIP components go across the gap between rows, which is 0.3" wide for that purpose.
That was really helpfull, it worked. Thank You
