How to use millis function to turn led on for 5s then turn it off indefinitely?
Have a look at the blink without delay example.
Hi i have looked at that but i cant get the led to turn LOW indefinitely.
Any suggestions?
Put all your code in setup, then when when your LED goes LOW, there'll be no code to send it high.
You can set a variable in setup that you change when the led is turned off. Then in the main loop the origional variable condition will never be met again. Like setting a "flag".
Can anyone give me an example?
int ledPin = 13;
int leddone = 0;
  pinMode(ledPin, OUTPUT);
  if (leddone == 0) {
  digitalWrite(ledPin, HIGH);   // set the LED on
  delay(5000);
  leddone = 1;
  if (leddone == 0) {
  delay(5000);
  leddone = 1;
Close...very close.
How about:
int ledPin = 13;
int leddone = 0;
  if (leddone == 0) {
  delay(5000);
  leddone = 1;
  digitalWrite(ledPin, LOW);   // set the LED off
Why is everyone making it look so hard?
const int ledPin = 13;
    delay(5000);
void loop() {}
(if your LED is wired to +5V, you need to swap the order of the digitalWrites.)
Its all just a warmup for the "...but what I really want to do..." post. :slight_smile:
Ahh... one problem..... I dont want to use the delay function i want to use the Millis function? Any ideas?
swifftyb:
So we have circled around again to the AWOL suggestion:
Any ideas?
Sure, post your Millis code that isn't working so we can see what the problem might be. I'd hate to think you are just waiting for somebody to do all the work and effort for you.
sorry. here is the code. basically its a push button circuit and im trying to get the leds to switch off after 5 and 10 seconds. so far i have both the leds blinking but i am trying to get ledOdd to turn off after 5 seconds and ledEven to turn off after ten seconds.
here's the code..
const int buttonPin = 2;     // the number of the pushbutton pin
const int ledOdd =  13;      // the number of the LED pin
const int ledEven = 50;
// variables will change:
int buttonstate = 0;
// variable for reading the pushbutton status
int buttonPress = 0;
int buttonPresses = 0;
int ledState = LOW;
int ledEoff = LOW;
 // ledState used to set the LED
long previousMillis = 0;
long interval = 1000;
long intervalTen = 10000;
  // initialize the LED pin as an output:
  pinMode(ledOdd, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  pinMode(ledEven, OUTPUT);
void loop(){
  // read the state of the pushbutton value:
  buttonstate = digitalRead(buttonPin);
buttonPresses = buttonPresses;
  if(buttonstate == HIGH) buttonPresses ++;
  boolean odd = buttonPresses % 2;
  if(odd){
//this will only happen if buttonPresses is odd
  if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    // if the LED is off turn it on and vice-versa:
    ledState = !ledState;
    // set the LED with the ledState of the variable:
    digitalWrite(ledOdd, ledState);}
else{
//this will only happen if buttonPresses is even
    digitalWrite(ledEven, ledState);}
    unsigned long  currentMillis2 = millis();
    if(currentMillis2 - previousMillis > intervalTen){
      previousMillis = currentMillis2;
      ledEoff = ledEoff;
      digitalWrite(ledEven, ledEoff);}
It would need to be done in the main loop to use millis().
const int ledPin =  13;      // the number of the LED pin
unsigned long time;
  // set the digital pin as output:
  digitalWrite(ledPin,LOW);
{  time= millis();
   if (time >= 1000 && time < 1020){digitalWrite(ledPin,HIGH);};  // turn it on when its been running for a second
   if (time >= 6000 && time < 6020){digitalWrite(ledPin,LOW);};  // turn it off when its been running for 6 seconds
// write rest of code here . as written it will repeat about every 49 days when millis() 'goes round the clock'
Tested code.......
The 1020 and 6020 figures will need to be tweaked if the loop time exceeds 20 milliseconds.
For some reason im still not getting the result i hoped for...
I entered the millis code you just quoted but still nothing. Am i missing something obvious?
int ledState = LOW;
int ledEoff = LOW;
unsigned long time;
void loop(){
    time= millis();
   if (time >= 1000 && time < 1020){digitalWrite(ledEven,HIGH);};  // turn it on when its been running for a second
   if (time >= 6000 && time < 6020){digitalWrite(ledEven,LOW);};  // turn it off when its been running for 6 seconds
  if(odd){
else{
      ledEoff = ledEoff;
Doesn't "delay()" use "millis()"?
Remove all the other references to ledEven.
Hmmm still having trouble.
I dont want to use the delay function as it stopps running the other code.
I have moved all the code about and tried this. I have used some of your code again Pluggy.
int ledState = LOW;
unsigned long time;
unsigned long time2;
  if(odd)
    time= millis();
    if (time >= 1000 && time < 1020){digitalWrite(ledOdd,HIGH);};  // turn it on when its been running for a second
    if (time >= 6000 && time < 6020){digitalWrite(ledOdd,LOW);};  // turn it off when its been running for 6 seconds
 if(!odd)
 time2= millis();
    if (time2 >= 1000 && time2 < 1020){digitalWrite(ledEven,HIGH);};  // turn it on when its been running for a second
    if (time2 >= 11000 && time2 < 6020){digitalWrite(ledEven,LOW);};  // turn it off when its been running for 6 seconds
Can anyone see why its not working??
