I'm trying to do a webserver on arduino mega 2560 + ethernet shield. When I use HTTP GET it works but when I switch to POST it stop working.
I stored the html files on the SD card, here is the code and the SD files. thanks
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 1, 20); // IP address, may need to change depending on network
EthernetServer server(80); // create a server at port 80
File webFile;
String HTTP_req = ""; // stores the received HTTP request
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
Serial.begin(9600); // for debugging
pinMode(11, OUTPUT);
// initialize SD card
Serial.println("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("ERROR - SD card initialization failed!");
return; // init failed
Serial.println("SUCCESS - SD card initialized.");
// check for index.htm file
//if (!SD.exists("index.htm")) {
//Serial.println("ERROR - Can't find index.htm file!");
//return; // can't find index file
//Serial.println("SUCCESS - Found index.htm file.");
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
HTTP_req += c; // save HTTP request character
Serial.print(c); // print HTTP request character to serial monitor
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connnection: close");
client.println();
// send web page
if ((HTTP_req.indexOf("POST / ") > -1)
|| (HTTP_req.indexOf("POST /loginPost.htm") > -1)) {
webFile = SD.open("loginPost.htm"); // open web page file
else if (HTTP_req.indexOf("POST /opcoesPost.htm") > -1) {
webFile = SD.open("opcoesPost.htm"); // open web page file
else if (HTTP_req.indexOf("POST /abrirPost.htm") > -1) {
webFile = SD.open("abrirPost.htm"); // open web page file
digitalWrite(11,HIGH);
delay(2000);
digitalWrite(11, LOW);
if (webFile) {
while(webFile.available()) {
client.write(webFile.read()); // send web page to client
webFile.close();
HTTP_req = ""; // empty the string
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
loginPost.html (285 Bytes)
opcoesPost.html (450 Bytes)
abrirPost.html (283 Bytes)
