Hi!
I wrote a code for the Arduino, in which the loop will start once the joystick button is pressed. The serial data will then be send to python and python stores the data in a csv file.
In the python script there are additional other data that are not coming from the arduino (camera file starts recording and load cell data).
Now I want the python script to start once joystick button is pressed as well, to make the arduino serial data sent to python and the python data synchronized.
So I thought maybe I could make something like "read serial data from arduino -> if pushbutton == 0 --> start the whole python script"
I kind of have no idea how I can do that, mabe someone could help me?
My arduino code:
#include <math.h>
const int Joystick_X = A0;
const int Joystick_Y = A1;
const int pushbutton = 3;
int JoystickValue_X = 0;
int JoystickValue_Y = 0;
const int middle_X = 512;
const int middle_Y = 512;
int pushbuttonState;
int JoystickValue_X_Y;
int tempsensor1 = A2;
int tempsensor2 = A3;
int tempsensor3 = A4;
int readVal1 = 0;
int readVal2 = 0;
int readVal3 = 0;
double Temp1 = 0;
double Temp2 = 0;
double Temp3 = 0;
int TempLimit;
double offset_degree;
double offset_degree1 = 2; // RT=26.0°C, difference
double offset_degree2 = 1;
double offset_degree3 = 2;
unsigned long startTime = 0;
unsigned long currentTime = 0;
//Define experiment (0 = manual, 1 = vollgas, 2 = , 3 = )
int experiment = 1;
//Define functions--------------------------------------------------------------------
void manual_function() {
JoystickValue_X = analogRead (Joystick_X); // [0, 1023]
JoystickValue_X = constrain(JoystickValue_X, middle_X, 1023); // [512, 1023]
JoystickValue_X = map(JoystickValue_X, middle_X, 1023, 0, 1023); // [0, 100]
JoystickValue_Y = analogRead (Joystick_Y); // [0, 1023]
JoystickValue_Y = constrain(JoystickValue_Y, middle_Y, 1023); // [512, 1023]
JoystickValue_Y = map(JoystickValue_Y, middle_Y, 1023, 0, 1023); // [0, 100]
Serial.print(Temp1);
Serial.print(";");
Serial.print(Temp2);
Serial.print(";");
Serial.print(Temp3);
Serial.print(";");
Serial.print(JoystickValue_X);
Serial.print(";");
Serial.println(JoystickValue_Y);
//Funktion Temperatur offset und Umrechung-----------------------------------------------------
double Thermistor(int RawADC, int sensor_number)
double Temp;
Temp = log(10000.0 * ((1024.0 / RawADC - 1)));
Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp )) * Temp );
Temp = Temp - 273.15; // Konvertierung von Kelvin in Celsius
switch (sensor_number) {
case 1:
offset_degree = offset_degree1;
case 2:
offset_degree = offset_degree2;
case 3:
offset_degree = offset_degree3;
default:
offset_degree = 0;
return Temp+offset_degree;
void case_function( int JoystickInput_X, int JoystickInput_Y, int TempLimit, int TempValue) {
if(currentTime < 45000L) {
JoystickValue_X = JoystickInput_X;
JoystickValue_Y = JoystickInput_Y;
Serial.print(";");
Serial.print(";");
Serial.print(";");
Serial.print(";");
else if ((currentTime > 45000L) && (TempValue > TempLimit)) {
Serial.print(";");
Serial.print(";");
Serial.print(";");
Serial.print(";");
else if ((currentTime > 45000L) && (TempValue < TempLimit)) {
Serial.print("Experiment done.");
exit(0);
startTime = millis(); //internal timer
pinMode(Joystick_X, INPUT); // X-axis
pinMode(Joystick_Y, INPUT); // Y-axis
pinMode(pushbutton,INPUT); // press button
digitalWrite(pushbutton, INPUT_PULLUP);
pushbuttonState = digitalRead(pushbutton);
while (digitalRead(pushbutton) == HIGH);
currentTime = millis();
readVal1 = analogRead(tempsensor1);
Temp1 = Thermistor(readVal1,1);
readVal2 = analogRead(tempsensor2);
Temp2 = Thermistor(readVal2,2);
readVal3 = analogRead(tempsensor3);
Temp3 = Thermistor(readVal3,3);
switch(experiment) {
case 0:
manual_function();
case 1:
case_function(1023, 0, 25, Temp1);
case 2:
case_function(0, 1023, 23, Temp2);
case 3:
case_function(1023, 1023, 23, Temp3);
delay(250);
My python code so far without the if statement:
import serial
from datetime import datetime
import cv2
import csv
#Camera Start------------------------------------------------------------------
webcam = cv2.VideoCapture(0) #laptop camera
frame_width = int(webcam.get(3))
frame_height = int(webcam.get(4))
size = (frame_width, frame_height)
result = cv2.VideoWriter('NameAsDateTime.avi', cv2.VideoWriter_fourcc(*'MJPG'), 10, size)
#Serial Data from Arduino---------------------------------------------------------
fileName = "temp_force_serialdata.csv"
ser = serial.Serial('COM4', 9600, timeout=1) #arduino port
file = open(fileName, "a")
#time.sleep(2)
#Serial Data from Loadcell--------------------------------------------------------
#dev = gsv8.gsv8("COM8", 115200) #load cell port
while True:
ret, frame = webcam.read()
if ret == True:
result.write(frame)
cv2.imshow("Test", frame)
key = cv2.waitKey(20) & 0xFF
if key == ord("q"):
break
#webcam.release()
#cv2.destroyAllWindows()
getData = ser.readline()
dataString = getData.decode('utf-8')
data = dataString.rstrip()
dateTimeObj = datetime.now()
timestampStr = dateTimeObj.strftime("%d-%b-%Y (%H:%M:%S)")
sensor_data = data.split(";")
sensor_data.append(timestampStr)
readings = data.split(";")
sensor_data.append(readings)
# get load cell data
#measurement = dev.ReadValue()
#measurement_str = measurement.toString()
#measurement_arr = measurement_str.split(";")
#force_x = measurement_arr[1].split(":")[2]
#force_y = measurement_arr[2].split(":")[1]
#force_z = measurement_arr[3].split(":")[1]
#entry = timestampStr + ',' + ','.join(readings) + ',' + force_x + ',' + force_y + ',' + force_z + '\n'
entry = timestampStr + ',' + ','.join(readings) + '\n'
print(entry)
with open(fileName, 'a', encoding='UTF8') as f:
f.write(entry)
file.close()
pass
