Hello
I'm looking into using the Arduino Uno's built in analogue comparator to help me detect a fan fail on my project and I basically need to compare two source inputs which will be in my case will by a 1.80V to 2.05V output from the fan circuit op-amp, as there are two fans there will be two voltages to compare against the 1.95V ref which is connected at AIN0 or AIN+.
I started to look at the "analogComp" library which will allow me to use the A0 to A5 pins as the AIN1 or AIN-, this library was a great start but its only allows one source to be compared against AIN0 or AIN+. I've looked in the datasheet on the Atmel 328 and I know how it basically works but I can't find any ideas or code on how to get the result I want to achieve on two sources.
Does anyone know how to achieve what I require ^^.
