How to use Timer/Counter function for MKR family
Hello everybody,
do someone of you have experience with Counter and Timer on MKR Platform?
I have a piece of code running on my Uno-Boards and now I want to use the MKR-Board to handle this.
But I have no idea how to config the MKR-timers.
I want to use three TC inputs to read 3 humidity-sensors which provides a frequency signal up to 500kHz.
This is the running code on Uno.
Hopefully someone can help me.
Thanks a lot!
 * Hardware Counting sketch for Arduino micro
 * uses pin 12 on 32U4
const int ledPin = 13;
unsigned int freq;
const int selectPin0 = 6;
const int selectPin1 = 7;
const int selectPin2 = 8;
const int maxRead = 25;
int readCount;
int currPort;
  pinMode(ledPin, OUTPUT);
  //hardware counter setup
  TCCR1A = 0; // reset timer/counter control register
  pinMode(selectPin0, OUTPUT);
  pinMode(selectPin1, OUTPUT);
  pinMode(selectPin2, OUTPUT);
  readCount = 0;
  currPort = 0;
  freq = 0;
  digitalWrite(ledPin, LOW);
  delay(200);
  digitalWrite(ledPin, HIGH);
  // start the counting
  bitSet(TCCR1B, CS12); // Counter clock source is external pin
  bitSet(TCCR1B, CS11); // Clock on rising edge
  delay(40);  // wait 40ms
  // stop the counting
  TCCR1B = 0;
  freq = TCNT1/4; // devide by 4 to get number of oscillations per 10ms
  TCNT1 = 0; // reset the hardware counter
  Serial.println(freq);
  // Switch the sensor every 25 cycles
  readCount++;
  if(readCount > maxRead) {
    currPort++;
    if(currPort == 3) currPort = 0;
    readCount = 0;
    selectPort(currPort);
// select port in multiplexer
// for simple understanding, the binary pattern is directly entered for the selected port
// and not calculated
void selectPort(int port) {
  if (port==0) {
    digitalWrite(selectPin0, LOW);
    digitalWrite(selectPin1, LOW);
    digitalWrite(selectPin2, LOW);
  else if (port == 1) {
    digitalWrite(selectPin0, HIGH);
  else if (port == 2) {
    digitalWrite(selectPin1, HIGH);
