I have this small code I need to make for school (1st year electrical engineer). But i can seem to figure out how let the serial wait before I give it a new number.
the task: I need to make a code that makes it possible to count in the serial monitor 10 times. and it needs to keep adding up upon the last number.
here is the code:
int Number = 0;
int Sum = 0;
int Getal = 1;
void Get_Number() {
Serial.println("Please insert you're next number: ");
Getal++;
while (Serial.available () == 0) { Number = Serial.read(); } //het allereerste getal wat ingevoerd wordt en later als basis wordt gebruikt
while( Getal != 11) {
Get_Number();
Sum = Number + Sum;
Serial.print( "Your number is now:");
Serial.println (Number, DEC);
current situation:
I am able to upload the code, and then the serial monitor asks me to insert my 1st number (and waits), and when i enter '5' for example this happens:
Your number is now:-1
nothing is done with the input and then i just keeps saying " Please insert you're next number:
Your number is now:-1 " for the next 9 times.
"Getal" is just another word for "Number" in Dutch. just to clarify!
while (Serial.available() == 0)
Serial.read() returns -1 when there is nothing to read so Number will be set to -1. This will be repeated until Getl equals 11 so what your sketch is doing is expected behaviour
Change the while in Get_Nimber() to an if and change the test so that a new number is read only when Serial.available() tells you that there is something to read
a number is composed of multiple characters. For example if you type 420 you'll have sent the ASCII code for '4' followed by the ASCII code for '2' and then the ASCII code for '0'.
if you hit enter, depending how you configured the Serial monitor in the IDE (assuming this is what you use) you'll send some extra bytes like Carriage return and line feed.
for example try this code
Serial.println(F("Type something and validate"));
if (Serial.available()) {
char c = Serial.read(); // get the character that was sent
// print the HEX code for the character on 2 digits
Serial.print("0x");
if (c < 0x10) Serial.write('0');
Serial.print(c, HEX);
Serial.write('\t'); // add a tab and show the characters (interpret some of the non visible ones)
switch (c) {
case '\r': Serial.println("CR"); break;
case '\n': Serial.println("LF"); break;
case '\t': Serial.println("TAB"); break;
case ' ' : Serial.println("SPACE"); break;
default : Serial.println(c); break;
and type something in the Serial monitor (set at 115200 bauds)
this will show you the byte stream you get.
➜ you need to first write a code that is able to receive multiple bytes and parse that as one number.
You wish to enter 5 (for example) from the InputBox of the Serial Monitor and then the OutputBox of Serial Monitor should show the following pattern at 1-sec interval -- correct?
no, like this: (everything that is thick printed is my input)
5 6
Your Number: 11 1
Your Number: 11+1 (12) 9
Your Number: 21
etc.
for the rest of you guys that posted something, thank you! i will try to study those post and try to get it working. and i will report back if i have any new questions!
Please, note the following points (also few are mentioned in post #3@J-M-L) with respect to reeceiving a data item (for example: 23) from the InputBox of Serial Monitor by Arduino UNO. (Assume that you have selected Newline option in the Line ending box of Serial Monitor as termination character.)
1. You enter 23 (for example) in the InputBox and click on the Send Button of the Serial Monitor, the following ASCII discrete data items (the ASCII Codes of 2 3 Newline) travels towards Arduino one after another in bit form.
0x32 0x33 0x0A
(Hex codes are written for convenience, space for clarity)
2. The data items (also called frames) are automatically received by UNO and are saved in a FIFO type Serial Buffer in the background on interrupt basis.
3. Depending on the Baud Rate (Bd), the frames will take some definite amount of time to arrive at UNO and get saved in the Serial Buffer.
4. It is normal idea to check that the Serial Buffer contains at least one data item before making an attempt to read a character/data from the Buffer. This is done by executing the following code:
byte n = Serial.available();
if(n != 0) //Serial Buffer contains at least one character
char ch = Serial.read();
5. Multiple data items are saved in a null-character terminated char type array and then the atoi() function is applied to convert the array content into a single data item.
6. The following sketch is testd for five entries:
byte numCounter = 0;
int numAdd = 0;
char myData [20];
Serial.print("Enter your first max 2-digit number: ");
if (n != 0)
byte m = Serial.readBytesUntil('\n', myData, sizeof myData - 1);
myData[m] = '\0'; //adding null character
int myNum = atoi(myData); //converting ASCII coded discrete data items into a single data item
Serial.println(myNum);
numAdd = numAdd + myNum;
Serial.println(numAdd);
numCounter++;
if (numCounter == 5)
while (true);
Serial.print("Enter next max 2-digit number to add: ");
7. Output:
Enter your first max 2-digit number: 5
5
Enter next max 2-digit number to add: 6
11
Enter next max 2-digit number to add: 24
35
Enter next max 2-digit number to add: 15
50
51
Incorrect Use of Serial.read(): Serial.read() reads a single byte from the input buffer, returning an ASCII value of the character, not the actual number. The line:
while (Serial.available() == 0) { Number = Serial.read(); }
has two main issues:
The while loop waits until data is available but immediately tries to read a value even when Serial.available() is still 0.
Serial.read() reads only one character at a time, and because it's inside the while loop, the assignment Number = Serial.read(); only executes once data is available, which is incorrect.
Increments Getal Unnecessarily:
The line Getal++; increases Getal every time Get_Number() is called, which may not be necessary depending on your logic.
No Handling of User Input as a String:
Reading numbers directly from Serial.read() without converting input properly leads to logical errors, especially for multi-digit numbers.
int Number = 0;
int Sum = 0;
int Getal = 1;
Get_Number();
void Get_Number() {
Serial.println("Please insert your next number: ");
// Wait for input , This will block the code
// Do nothing, just wait
// Read the input as a string, and then convert string to int.
String input = Serial.readStringUntil('\n'); // Reads until newline character
Number = input.toInt(); // Convert the input string to an integer
Serial.print("You entered: ");
Serial.println(Number); // Display the ASCII number read as an integer
// Additional code can be added here based on what you want to do with Number
** We did the following Changes Because:**
Serial.readStringUntil('\n'):
This reads the input from the Serial Monitor as a complete string until the Enter key (\n) is pressed, ensuring you capture multi-digit numbers correctly.
input.toInt():
Converts the string input into an integer, allowing you to handle the input correctly.
Waiting Loop Fix:
The waiting loop now properly pauses until input is available without immediately reading data prematurely.
This code will prompt the user for input, correctly read the number from the Serial Monitor, and convert it into an integer for further processing.
I have done somework on the code and i think i almost got i working.
but it still has trouble with adding the numbers up.
here is the code atm:
String Number;
String Sum;
void Get_Number() {
while (Serial.available() == 0) { }
String Input = Serial.readStringUntil("\n"); // reads until enter is pressed
Number = Input.toInt(); // converts the given number into a whole
Get_Number();
Serial.print("You enterd: ");
Serial.print("\t");
String Sum = Number + Sum;
Serial.print( "Your number is now: ");
Serial.println (Sum);
Serial.println( "\t");
I removed the counter to 10 atm so i can focus on getting it working.
this is what i get in serial:
You enterd: 5
Your number is now:
You enterd: 7
Your number is now: 7
You enterd: 9
Your number is now: 9
as you can see it is able to display the number given but it is unable to convert Number into Sum. I think this is because Sum holds no value on the first run.
So 5 + ?? = blank.
but i cant put a value on Sum.
also when i try to put sum into HEX or DEC it doenst work. for you guys it is probalby obvious but for me not atm.
this project is due to 36hrs but don't feel guilty. this is 100% my fault for asking the arduino forum or one of my theachers this late.
This declares a new String variable named Sum which is not the same as the global variable with the same name
You cannot add Strings together like you can with numeric variables. What that line of code will do instead is to concatenate the two Strings together rather than adding them. So, if Number is say "9" and the new Sum variable is "" then the result is "9"
I just remove the String and i workes "better" now it does it like this:
You enterd: 5
Your number is now: 5
You enterd: 8
Your number is now: 85
You enterd: 9
^ also pretty funny
If i use Serial.readBytesUntil("\n");
and change the string to int' s will that work? or will i still miss something?
this is the code atm:
String Number;
String Sum;
void Get_Number() {
Get_Number();
Serial.print("\n");
Serial.print("\t");
Sum = Number + Sum;
Sum = Sum.toInt();
Serial.println( "\n");
Compilation error: no matching function for call to 'HardwareSerial::readBytesUntil(const char [2])'
probably expected but what do i do about it?
code:
int Number;
int Sum;
void Get_Number() {
int Input = Serial.readBytesUntil("\n"); // reads until enter is pressed
Get_Number();
Serial.print("\n");
Serial.print("\t");
Sum = Number + Sum;
Sum = Sum.toInt();
int Number;
int Sum;
void Get_Number()
while (Serial.available() == 0) {}
Number = Serial.parseInt(); // read an int
Get_Number();
Serial.print("\n");
Serial.print("\t");
Sum = Number + Sum;
Serial.print("Your number is now: ");
Serial.println(Sum);
Serial.println("\n");
i will come back on Serial.parseInt(); later (because i do wanna know why i need to use that and what it does) but first i wanna get this working because it works but not correctly.
You enterd: 1
Your number is now: 10
You enterd: 0
here is a piece of serial. and i already had 9 before this. and you can see i enterd 1, that makes 10. but then what the program does is that is goes through Get_Number(); again.
int Number;
int Sum;
Serial.begin(115200); }
void Get_Number() {
Number = Serial.parseInt(); //read an int
Get_Number();
Serial.println(Number); //gives the enterd number
Serial.print("\n");
Serial.print("\t");
Sum = Number + Sum;
Serial.println (Sum); // Displays the current sum of all the Previous numbers
Think -- 1. When ioInt() method is applied on a String type variable, the result is an integer number. So, the data type of the variable Number should be int.
2. As Number variable is of type int, the Sum should also be of type int.
3. The quoted variables are declared as follows; now, the output is:
5
You enterd: 5
6
You enterd: 6
Your number is now: 11
17
You enterd: 17
Your number is now: 28
Your sketch after moderation:
int Number;
int Sum;
Get_Number();
Serial.print('\t');
//Sum = Number + Sum;
Sum = Sum + Number;
Serial.println( '\t');
void Get_Number()
String Input = Serial.readStringUntil('\n'); // reads until enter is pressed
