How to write data in to mifare card.
Hi.
I want to write some data in to sector 1 block 4 in to mifare card with pass key A "A0 A1 A2 A3 A4 A5"
I try some sckech found on these forum but nothing work's.
Ony to write data, without compare the data.
Sorry for my bad englease.
L.E I use arduino uno and RC522 card reader.
Install the MFRC522 library.
Open File->Examples->MFRC522->ReadAndWrite
File->Save As... to save a copy you can modify
Remove the reading parts you don't want.
Change the parts that do the writing to write what you want to write.
Thank's for replay.
I allready try these, but I don't know how to eliminate the read function, and how to change the default key FF with A0 A1 A2 A3 A4 A5.
  // using FFFFFFFFFFFFh which is the default at chip delivery from the factory
    for (byte i = 0; i < 6; i++) {
        key.keyByte[i] = 0xFF;
I don't know how to change this.
I'm newbie with this tipe of programing, I use BASIC programing.
I found another sketch:
 * This is a MFRC522 library example; see https://github.com/miguelbalboa/rfid
 * for further details and other examples.
 * NOTE: The library file MFRC522.h has a lot of useful info. Please read it.
 * Released into the public domain.
 * This sample shows how to read and write data blocks on a MIFARE Classic PICC
 * (= card/tag).
 * BEWARE: Data will be written to the PICC, in sector #1 (blocks #4 to #7).
 * Typical pin layout used:
 *             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
 *             Reader/PCD   Uno           Mega      Nano v3    Leonardo/Micro   Pro Micro
 * Signal      Pin          Pin           Pin       Pin        Pin              Pin
 * RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
 * SPI SS      SDA(SS)      10            53        D10        10               10
 * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
 * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
 * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN         9           // Configurable, see typical pin layout above
#define SS_PIN          10          // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance.
MFRC522::MIFARE_Key key;
 * Initialize.
    Serial.begin(115200); // Initialize serial communications with the PC
    while (!Serial);    // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
    SPI.begin();        // Init SPI bus
    mfrc522.PCD_Init(); // Init MFRC522 card
    // Prepare the key (used both as key A and as key B)
    Serial.println(F("Scan a MIFARE Classic PICC to demonstrate read and write."));
    Serial.print(F("Using key (for A and B):"));
    dump_byte_array(key.keyByte, MFRC522::MF_KEY_SIZE);
    Serial.println(F("BEWARE: Data will be written to the PICC, in sector #1"));
 * Main loop.
    // Look for new cards
    if ( ! mfrc522.PICC_IsNewCardPresent())
        return;
    // Select one of the cards
    if ( ! mfrc522.PICC_ReadCardSerial())
        return;
    // Show some details of the PICC (that is: the tag/card)
    Serial.print(F("Card UID:"));
    dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
    Serial.print(F("PICC type: "));
    byte piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
    Serial.println(mfrc522.PICC_GetTypeName(piccType));
    // Check for compatibility
    if (    piccType != MFRC522::PICC_TYPE_MIFARE_MINI
        &&  piccType != MFRC522::PICC_TYPE_MIFARE_1K
        &&  piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
        Serial.println(F("This sample only works with MIFARE Classic cards."));
        return;
    // In this sample we use the second sector,
    // that is: sector #1, covering block #4 up to and including block #7
    byte sector         = 1;
    byte blockAddr      = 4;
    byte dataBlock[]    = {
        0x01, 0x02, 0x03, 0x04, //  1,  2,   3,  4,
        0x05, 0x06, 0x07, 0x08, //  5,  6,   7,  8,
        0x08, 0x09, 0xff, 0x0b, //  9, 10, 255, 12,
        0x0c, 0x0d, 0x0e, 0x0f  // 13, 14,  15, 16
    byte trailerBlock   = 7;
    byte status;
    byte buffer[18];
    byte size = sizeof(buffer);
    // Authenticate using key A
    Serial.println(F("Authenticating using key A..."));
    status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, trailerBlock, &key, &(mfrc522.uid));
    if (status != MFRC522::STATUS_OK) {
        Serial.print(F("PCD_Authenticate() failed: "));
        Serial.println(mfrc522.GetStatusCodeName(status));
        return;
    // Show the whole sector as it currently is
    Serial.println(F("Current data in sector:"));
    mfrc522.PICC_DumpMifareClassicSectorToSerial(&(mfrc522.uid), &key, sector);
    // Read data from the block
    Serial.print(F("Reading data from block ")); Serial.print(blockAddr);
    Serial.println(F(" ..."));
    status = mfrc522.MIFARE_Read(blockAddr, buffer, &size);
        Serial.print(F("MIFARE_Read() failed: "));
    Serial.print(F("Data in block ")); Serial.print(blockAddr); Serial.println(F(":"));
    dump_byte_array(buffer, 16); Serial.println();
    // Authenticate using key B
    Serial.println(F("Authenticating again using key B..."));
    status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_B, trailerBlock, &key, &(mfrc522.uid));
        return;
    // Write data to the block
    Serial.print(F("Writing data into block ")); Serial.print(blockAddr);
    dump_byte_array(dataBlock, 16); Serial.println();
    status = mfrc522.MIFARE_Write(blockAddr, dataBlock, 16);
        Serial.print(F("MIFARE_Write() failed: "));
    // Read data from the block (again, should now be what we have written)
    // Check that data in block is what we have written
    // by counting the number of bytes that are equal
    Serial.println(F("Checking result..."));
    byte count = 0;
    for (byte i = 0; i < 16; i++) {
        // Compare buffer (= what we've read) with dataBlock (= what we've written)
        if (buffer[i] == dataBlock[i])
            count++;
    Serial.print(F("Number of bytes that match = ")); Serial.println(count);
    if (count == 16) {
        Serial.println(F("Success :-)"));
        Serial.println(F("Failure, no match :-("));
        Serial.println(F("  perhaps the write didn't work properly..."));
    // Dump the sector data
    // Halt PICC
    mfrc522.PICC_HaltA();
    // Stop encryption on PCD
    mfrc522.PCD_StopCrypto1();
 * Helper routine to dump a byte array as hex values to Serial.
void dump_byte_array(byte *buffer, byte bufferSize) {
    for (byte i = 0; i < bufferSize; i++) {
        Serial.print(buffer[i] < 0x10 ? " 0" : " ");
        Serial.print(buffer[i], HEX);
If you cand modify the skech with some explication , to understant how it work's.
Or some exaples of code that write exact sector or block, if I understand an exaple, is easy for me to adapt the sketch for me.
Thank's
Don't they have arrays in Basic?
key.keyByte[0] = 0xA0;
key.keyByte[5] = 0xA5;
Thank's for replay.
Yes it is but diferent from what you posted.
These is the stage were I need to change sector, block and data? or is need to change something else?
    byte sector         = 1;
    byte blockAddr      = 4;
    byte status;
    byte buffer[18];
