LOGIC: if myswitch = 1, the stepper motor must rotate to the right. myswitch = 1 only when the buttonStateRight is HIGH (clicked) and buttonStateHomeTriggerSwitch is LOW, if you click the switch (buttonStateHomeTriggerSwitch) while pressing buttonStateRight , the stepper motor must stop.
The code below suppose to do the same logic but its not working
That does not give us much to go on. What happens and why did you not post the complete program ?
When debugging code that tests values it is useful to print the values being tested, which you have done apart from the all important myswitch variable. I presume that the values printed are as expected although the the use of Strings is to be avoided in most cases.
How are the inputs wired ? Do you have pulldown resistors in place to hold the inputs in a known state at all times or are they floating at an unknown voltage ?
I provided the full code below, when i run the code and click and hold buttonStateRight and then click
buttonStateHomeTriggerSwitch the motor must stop but now it is not stopping. it is accessing 2 'if statement at the same time', it is running these
which is suppose to access only one if statement that the myswitch = 0;
const int buttonHome = 10; // the number of the pushbutton pin
const int buttonLeft = 4; // the number of the pushbutton pin
const int buttonRight = 9; // the number of the pushbutton pin
const int buttonOn = 12; // the number of the pushbutton pin
const int buttonOff = 11; // the number of the pushbutton pin
const int buttonHomeTrigger = 13; // the number of the home limit switch pin
const int buttonEndTrigger = 7; // the number of the end limit switch pin
const int ledPin = 6; // the number of the LED pin
//For stepper
const int stepPin = 5;
const int dirPin = 2;
const int enPin = 8;
// variables will change:
int buttonStateLeft = 0; // variable for reading the pushbutton status
int buttonStateRight = 0;
int buttonStateHome = 0;
int buttonStateOn = 0;
int buttonStateOff = 0;
int buttonStateHomeTriggerSwitch = 0;
int myswitch = 0;
int buttonHomeLimit = 0;
int buttonEndLimit = 0;
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonLeft, INPUT);
pinMode(buttonRight, INPUT);
pinMode(buttonHome, INPUT);
pinMode(buttonHomeTrigger, INPUT);
pinMode(buttonEndTrigger, INPUT);
pinMode(buttonOn, INPUT);
pinMode(buttonOff, INPUT);
// Sets the two pins as Outputs
pinMode(stepPin,OUTPUT);
pinMode(dirPin,OUTPUT);
pinMode(enPin,OUTPUT);
digitalWrite(enPin,LOW);
// read the state of the pushbutton value:
buttonStateHomeTriggerSwitch = digitalRead(buttonHomeTrigger);
buttonStateRight = digitalRead(buttonRight);
if ((buttonStateRight == HIGH) && (buttonStateHomeTriggerSwitch == HIGH))
String printValue = "Both HIGH: Trigger = " + buttonStateHomeTriggerSwitch; //+ " Button = " + buttonStateRight;
Serial.println(printValue);
myswitch = 0;
else if ((buttonStateRight == HIGH) && (buttonStateHomeTriggerSwitch == LOW)) {
String printValue = "Button HIGH: Trigger = " + buttonStateHomeTriggerSwitch; //+ " Button = " + buttonStateRight;
myswitch = 1;
else if ((buttonStateRight == LOW) && (buttonStateHomeTriggerSwitch == LOW))
String printValue = "Both LOW: Trigger = " + buttonStateHomeTriggerSwitch; //+ " Button = " + buttonStateRight;
myswitch = 0;
else if ((buttonStateRight == LOW) && (buttonStateHomeTriggerSwitch == HIGH)) {
String printValue = "B LOW: Trigger = " + buttonStateHomeTriggerSwitch; //+ " Button = " + buttonStateRight;
myswitch = 0;
digitalWrite(ledPin, LOW);
myswitch = 0;
if(myswitch == 1) {
// turn LED on:
digitalWrite(ledPin, HIGH);
TurnRight();
int TurnRight(){
digitalWrite(dirPin,LOW); //Changes the rotations direction
// Makes 400 pulses for making two full cycle rotation
for(int x = 0; x < 8 ; x++) {
digitalWrite(stepPin,HIGH);
delayMicroseconds(100);
digitalWrite(stepPin,LOW);
First of all: use DIRECTLY the digitalRead () into the if condictions
Second: if (value or function or variable) is "if it is not zero", so in case of digitalRead () the '==HIGH' is useless
Third: all the variable that can't be nore than 255 can became 'byte', so less expansive.
Another: NEVER, NEVER, NEVER use Strings on Arduino. You can have the same results by this code:
I note that you are not using the built in pullup resistors and are testing inputs for HIGH to determine whether the buttons are pressed. So, do you have pulldown resistors in place ?
Print the values of buttonStateHomeTriggerSwitch and buttonStateRight immediately after you read the inputs. What do you see ? Is it what you expect ?
Is the circuit built on a breadboard and if so are you sure that all the connections are sound and has the breadboard got split or continuous power rails ?
What does the serial output and behavior look like for this simplified version?
//For stepper
int myswitch = 0;
pinMode(stepPin, OUTPUT);
pinMode(dirPin, OUTPUT);
pinMode(enPin, OUTPUT);
digitalWrite(enPin, LOW);
boolean buttonStateRight = digitalRead(buttonRight);
boolean buttonStateHomeTriggerSwitch = digitalRead(buttonHomeTrigger);
Serial.print(buttonStateRight);
Serial.print(' ');
Serial.println(buttonStateHomeTriggerSwitch);
digitalWrite(ledPin, HIGH); // turn LED on:
Serial.println("Runing...");
TurnRight();
Serial.println("STOPPED...");
delay(500); // Just for testing to slow down the serial output
void TurnRight()
digitalWrite(dirPin, LOW);
for (int x = 0; x < 8 ; x++)
digitalWrite(stepPin, HIGH);
digitalWrite(stepPin, LOW);
int pinState = digitalRead(pin);
if (pin == 0){
do something...
Why is putting the digitalRead() in the if-statement a bad choice? It works, and reduces lines of code and variables required without being messy to read.
silly_cone:
silly_cone:
Because it makes it impossible to check the value that is read before it is used in the IF statement.
Who cares how many lines of code there are? It's not as if you are wasting reams of paper.
silly_cone:
If you read your inputs at the start of the loop, you effectively take a snapshot of your inputs, then use the code to act on it.
If you are continually reading inputs throughout the code, it makes it hard to debug, if your code has any blocking code, then a mid change of input could disrupt your program.
if (val == 0)
is quicker than typing
if (digitalRead(valPin) == 0)
It also encourages the programmer to write descriptive names for the variables.
shonieratshie:
Good day, when the button and the switch are clicked at the same time it stop and then it run again.
Check the display below
1 1
STOPPED...
1 0
Runing...
Looks like it is doing exactly as you asked: When buttonStateRight is HIGH and buttonStateHomeTriggerSwitch is LOW it turns on the LED and takes 8 steps to the right. When both are HIGH it turns off the LED and doesn't move. Was that not what you wanted?!?
