Hello, im making a simple new project but I have difficulties making the relay work. My sensor is a XKC-Y25-NPN powered by an external power, I'm using arduino UNO and a standard 5V relay powered by the UNO. The idea is when the sensor sense water the relay turns ON, and when there is not water the relay is OFF. I have the "sensor part" of the program but not the "relay part"
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// print out the value you read:
Serial.println(sensorValue);
delay(500); // delay in between reads for stability
So when the sensor sense water the monitor gives the number 17 and when there is not water the sensor gives 0. Any help or better idea is welcome (I'm a begginer). Thanks.
What voltage are you powering the level sensor with? The sensor negative ( - ) wire must be connected to the Arduino GND pin.
That sensor has a digital (ON / OFF) output that goes LOW when triggered. Try this test sketch:
const byte relayPin = 10;
pinMode(relayPin, OUTPUT);
pinMode(A0,INPUT_PULLUP);
byte sensorValue = digitalRead(A0);
// print out the value you read: // 1 or 0
digitalWrite(relayPin, sensorValue);
TomGeorge:
What did you do to solve your problem.
Let us know so that this thread might be helpful to someone else with your symptoms.
Tom...
Sure :
1: I was powering the sensor with an external source of power (5V battery) but it HAS to be connected to the arduino 5V output pin and the arduino GND. Same with the relay, it has to be connected with the arduino powering source (5V and GND from the arduino). My worry was the overcharge of the arduino output 5V source, but the relay + the sensor just use like a 10% of the capacity of the 5V pin so it's safe (70mA the relay + 5mA the sensor).
2: The rest was easy, i just made a new sketch with the if statement well placed (I changed the S from the relay from pin ~10 to pin 8 becuase why not):
// These constants won't change:
const int analogPin = A0; // pin that the signal of the water sensor is attached to
const int relayPin = 8; // pin that the relay is attached to
const int threshold = 10; // an arbitrary threshold level that's in the range of the analog input
// initialize the relay pin as an output:
// initialize serial communications:
int analogValue = analogRead(analogPin);
// if the analog value is high enough, turn on the relay:
if (analogValue > threshold) {
digitalWrite(relayPin, HIGH);
digitalWrite(relayPin, LOW);
// print the analog value:
Serial.println(analogValue);
delay(1000); // delay in between reads for stability
The analog A0 reads 17 when the sensor is ON and 0 when the sensor is OFF. So i place the threshold in 10.
