You need to show ALL of your code. That snippet makes it look like the Arduino is a client. Clients make GET requests. Servers do not. Your question is about serving up a login page.
PaulS:
Are you implementing a server, that needs to provide data only to authorized clients, or are you implementing a client that needs to log on to a server?
I am implementing a WebServer , and i need an Authorization for the clients that connects to it. I dont want form authentication , i need the basic authentication.
i will also save the username and password to EEPROM and client will change it from the webserver UI.
But i do not know if this can be implemented into Mega2560 with Ethernet shield (i am at work can't test this)
/* Web_Authentication.ino - Webduino Authentication example */
/* This example assumes that you're familiar with the basics
* of the Ethernet library (particularly with setting MAC and
* IP addresses) and with the basics of Webduino. If you
* haven't had a look at the HelloWorld example you should
* probably check it out first */
/* you can change the authentication realm by defining
* WEBDUINO_AUTH_REALM before including WebServer.h */
#define WEBDUINO_AUTH_REALM "Weduino Authentication Example"
#include "SPI.h"
#include "Ethernet.h"
#include "WebServer.h"
/* CHANGE THIS TO YOUR OWN UNIQUE VALUE. The MAC number should be
* different from any other devices on your network or you'll have
* problems receiving packets. */
static uint8_t mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
/* CHANGE THIS TO MATCH YOUR HOST NETWORK. Most home networks are in
* the 192.168.0.XXX or 192.168.1.XXX subrange. Pick an address
* that's not in use and isn't going to be automatically allocated by
* DHCP from your router. */
static uint8_t ip[] = { 192, 168, 1, 210 };
/* This creates an instance of the webserver. By specifying a prefix
* of "", all pages will be at the root of the server. */
#define PREFIX ""
WebServer webserver(PREFIX, 80);
void defaultCmd(WebServer &server, WebServer::ConnectionType type, char *, bool)
server.httpSuccess();
if (type != WebServer::HEAD)
P(helloMsg) = "<h1>Hello, World!</h1><a href=\"private.html\">Private page</a>";
server.printP(helloMsg);
void privateCmd(WebServer &server, WebServer::ConnectionType type, char *, bool)
/* if the user has requested this page using the following credentials
* username = user
* password = user
* display a page saying "Hello User"
* the credentials have to be concatenated with a colon like
* username:password
* and encoded using Base64 - this should be done outside of your Arduino
* to be easy on your resources
* in other words: "dXNlcjp1c2Vy" is the Base64 representation of "user:user"
* if you need to change the username/password dynamically please search
* the web for a Base64 library */
if (server.checkCredentials("dXNlcjp1c2Vy"))
P(helloMsg) = "<h1>Hello User</h1>";
* username = admin
* password = admin
* display a page saying "Hello Admin"
* in other words: "YWRtaW46YWRtaW4=" is the Base64 representation of "admin:admin" */
else if (server.checkCredentials("YWRtaW46YWRtaW4="))
P(helloMsg) = "<h1>Hello Admin</h1>";
/* send a 401 error back causing the web browser to prompt the user for credentials */
server.httpUnauthorized();
Ethernet.begin(mac, ip);
webserver.setDefaultCommand(&defaultCmd);
webserver.addCommand("index.html", &defaultCmd);
webserver.addCommand("private.html", &privateCmd);
webserver.begin();
char buff[64];
int len = 64;
/* process incoming connections one at a time forever */
webserver.processConnection(buff, &len);
I finally found the solution , i can use http basic authentication with the classic ethernet library with the help of webduinos library,
this is for somebody searching the same , and if you have some better solution or comments i will be glad to hear them
#include <SPI.h>
#include <Ethernet.h>
#include <WebServer.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,2,57);
EthernetServer server(90);
byte USER_AUTHENDICATED=0;
#define PREFIX ""
WebServer webserver(PREFIX, 90);
void privateCmd(WebServer &serverA, WebServer::ConnectionType type, char *, bool)
if (serverA.checkCredentials("YWRtaW46YWRtaW4="))
serverA.httpSuccess();
USER_AUTHENDICATED=1;
delay(20);
P(helloMsg) = "<html><head><meta http-equiv='refresh' content=3;></head><body bgcolor='#000000' style='font-family:Verdana;color:#ffffff;font-size:12px;'><form>Login Succesfull!</form></body></html>";
serverA.printP(helloMsg);
delay(20);
STARTWEB();
{serverA.httpUnauthorized();
char buff[64];
int len = 64;
// listen for incoming clients0
if (USER_AUTHENDICATED==1)
STARTWEB();
void defaultCmd(WebServer &serverA, WebServer::ConnectionType type, char *, bool)
delay(20);
P(helloMsg) = "<html><head><meta http-equiv='refresh' content=4;></head><body bgcolor='#000000' style='font-family:Verdana;color:#ffffff;font-size:12px;'><form>Login Succesfull!</form></body></html>";
delay(20);
STARTWEB();
// start the Ethernet connection and the server:
server.begin();
webserver.setDefaultCommand(&privateCmd);
// webserver.addCommand("private.html", &defaultCmd);
webserver.begin();
void STARTWEB()
//Start Webserver with classic arduino way.......
if (client) {
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("
client.println("</html>");
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disonnected");
I'm using a code in the STARWEB function that refresh each 5 seconds, but all time that the page refresh appers the hello message in a black page some body solved this issue?
#include <SPI.h>
#define PREFIX ""
delay(20);
delay(20);
STARTWEB();
char buff[64];
int len = 64;
STARTWEB();
delay(20);
delay(20);
STARTWEB();
server.begin();
webserver.begin();
void STARTWEB()
if (client) {
Serial.write(c);
client.println();
client.println("
if (c == '\n') {
delay(1);
client.stop();
