My wife gave me a Yun for Christmas and 1 have started to play around with the web server. One of the first things I thought I might do, is hide the web control panel on a custom port. So I added a config section to /etc/config/uhttpd
#/etc/config/uhttpd
# User Server configuration
config uhttpd main
list listen_http 0.0.0.0:80
list listen_https 0.0.0.0:443
option home /wwwusr
option index_page index.html
option rfc1918_filter 0
option max_requests 10
option cert /etc/uhttp.crt
option key /etc/uhttpd.key
option cgi_prefix /cgi-bin
list interpreter ".php=/usr/bin/php-cgi"
list interpreter ".cgi=/usr/bin/perl"
option script_timeout 60
option network_timeout 30
option tcp_keepalive 1
option config /etc/httpd.conf
# Admin Server configuration
config uhttpd admin
list listen_http 0.0.0.0:8099
list listen_https 0.0.0.0:8443
option home /www
option max_requests 2
option cert /etc/uhttpd.crt
option realm OpenWrt
Where I am stuck is trying to get the bridge interface working with the website located in the /wwwusr folder
I have uploaded this sketch
#include <Bridge.h>
#include <YunServer.h>
#include <YunClient.h>
YunServer server;
String startString;
long hits = 0;
uint8_t pin13State = HIGH;
Serial.println("Setup...");
pinMode(13, OUTPUT);
digitalWrite(13, LOW);
Bridge.begin();
digitalWrite(13, HIGH);
server.listenOnLocalhost();
server.begin();
uint8_t lastHits = hits;
YunClient client = server.accept();
if (client) {
String command = client.readString();
command.trim();
Serial.println(command);
client.stop();
hits++;
//flash the LED
pinMode(13, INPUT);
pin13State == digitalRead(13);
if (pin13State == HIGH) {
pin13State = LOW;
else {
pin13State = HIGH;
digitalWrite(13, pin13State);
//print UTRL hits
if (lastHits != hits) {
Serial.print("hits=");
Serial.println(hits);
[quote author=Federico Fissore link=topic=206899.msg1523071#msg1523071 date=1388231226]
Can you confirm that http://yun.local:8099/arduino/helloworld is printing helloworld in the serial monitor?[/quote]
I am 99.9% sure. I flashed back to a default image so I can not retest, I am afraid.
the webpanel control panel and the /arduino/ endpoint are the same application code, so I guess you can't do that easily
Am I right in assuming the response is passed to the luci binary in /www/cgi-bin and that binary depends on the contents of /www/luci-static? Is there any other process in the chain? Sorry to press but I would like to get my head around how the response data is passed around and in what order it happens.
you have to modify file /etc/httpd.conf, that defines two url aliases.
Thanks. Your pointer helped me on my way.
I have managed to get almost what I want now.
//root@yun1:~# cat /etc/httpd.conf
A:/arduino:/cgi-bin/luci/arduino%s
A:/mydata:/cgi-bin/luci/arduino%s
//hide the arduino web control panel
mv /www/index.html /www/admin.html
ln -s /www/sd/www/js1.html index.html
Ultimately I would like to make the web control panel completely inaccessible to the internet but this is good enough for now.
MattS-UK:
If with "depends" you mean that the generated html pages (from cgi-bin) load images and javascripts from luci-static, then yes.
MattS-UK:
You can use a strong password: webpanel will still be accessible, but unusable
By "depends" I mean, will the luci binary still pass data, sent in the HTTP request, to the bridge, if the static-content folder is removed. I guess I could test this myself.
Maybe it would be better to tell you the problem I am trying to solve. I want to pass data sent to uhttpd in a URL, to my sketch, without having to learn yet another programming language (lua, perl, python).
Not the answer I was looking for but many thanks for your assistance anyway.
MattS-UK:
Use the Bridge library then. Take a look at the TemperatureWebPanel example: it shows how you can talk to your sketch via URLs. There is a blog post about it: in essence, you can send commands to your sketch. In the example, with the URL "http://blabla/arduino/temperature", the command "temperature" is sent to the sketch and instructs it to read and report the temp sensor value
