HTTP Request ESP32 to local IP
I got this HTTP Request Post from ESP to API point some local IP
#include <WiFi.h>
#include <HTTPClient.h>
#include <ArduinoJson.h>
// Replace with your network credentials
const char* ssid = "Wifi";
const char* password = "Password";
String sensorName = "Idk";
  WiFi.begin(ssid, password);
  Serial.println("Connecting");
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to WiFi network with IP Address: ");
  //Check WiFi connection status
  if (WiFi.status() == WL_CONNECTED) {
    WiFiClient client;
    HTTPClient http;
    StaticJsonDocument<200> doc;
    String url, nodemcuData;
    //equate with your computer's IP address and your directory application
    url = "<myIP>";
    doc["sensor"] = sensorName;
    doc["value"] = String(0.01 + random(0, 100));
    http.begin(client, url);
    http.addHeader("Content-Type", "application/json");
    serializeJson(doc, nodemcuData);
    Serial.print("POST data >> ");
    Serial.println(nodemcuData);
    int httpCode = http.POST(nodemcuData);  //Send the request
    Serial.println(httpCode);
    String payload;
    if (httpCode > 0) {            //Check the returning code
      payload = http.getString();  //Get the request response payload
      payload.trim();
      if (payload.length() > 0) {
        Serial.println(payload + "\n");
    http.end();  //Close connection
    Serial.println("WiFi Disconnected");
  //Send an HTTP POST request every 1 seconds
  delay(10000);
The problem was when the URL is domain like www.domain.com/ESP/API.php the response is 200 (working), but when using local IP from XAMPP like 192.168.1.x/ESP/API.php it doesnt work with response code -1.
API is working with postman but in ESP doesnt work
url should be a full url including http://
already done and same problem
Usually with application like XAMPP the web server is setted to accept connection only from localhost.
No, i already try from different computer (same wifi) using postman and its work.
but from esp is error code -1, the problem is from ESP i think because they cant address IP but with domain its work
did you ever find a solution? I am having the same exact issue with my Nano Exp32. I can access the website successfully from both my dev station and my cell phone on the same wifi. I change the IP to http://www.google.com and I get a response back. Also note that I copied the code from an example. Changed the SSID/PW and IP address and port to what mine is but I still get -1 from the nano.
I little forgot about it, but if im not wrong http request is always request to port 80 so if you try to change the port maybe it doesn't work.
