Merry xmas to everybody, i'm working on a project in which i have to display temperature and humidity on a four 7seg digit LED. I want they show once temp once hum for 5 seconds.
i have already written the code, and for now i use a for cicle to calculate the 5000ms (one in the "temperatura" function and the other one in the "umidita" function), but it's not precise, so i would like to improve the code with the millis function but i have some troubles. now i put the current version of the code.
thanks to all people will join this topic ![]()
/* ------------------------------------------------------------------------- Pimpino v 1.1 ------------------------------------------------------------------------------- */
// Mostra umidità e temperatura ogni 5 secondi grazie ad un sensore DHT 11
// delay totale intorno ai 20ms, quindi 5ms per ogni DIG
#include <dht11.h>
#define DHT11_PIN 10 // pin DIGITALE del sensore DHT11
int temp, hum, humdec, tempdec, humun, tempun, u, t, n; // Su Windows funzionano anche come CHAR, ma su Linux no !!! li riconosce solo come byte int ecc...
dht11 DHT;
const int d1 = 14;
const int d2 = 15;
const int d3 = 11; // v1.1 PIN modificati per usare RTC
const int d4 = 12; // V1.1 PIN modificati per usare RTC
* const int sda = ; // pin SDA per rtc
* const int scl = ; // pin SCL per rtc
const int a=2;
const int b=3;
const int c=4;
const int d=5;
const int e=6;
const int f=7;
const int g=8;
const int h=9;
void ledon(int n) // accende i led
switch(n)
case 0:
digitalWrite(a, LOW);
digitalWrite(b, LOW);
digitalWrite(c, LOW);
digitalWrite(d, LOW);
digitalWrite(e, LOW);
digitalWrite(f, LOW);
digitalWrite(g, HIGH);
case 1:
digitalWrite(a, HIGH);
digitalWrite(d, HIGH);
digitalWrite(e, HIGH);
digitalWrite(f, HIGH);
case 2:
digitalWrite(c, HIGH);
digitalWrite(g, LOW);
case 3:
case 4:
case 5:
digitalWrite(b, HIGH);
case 6:
case 7:
case 8:
case 9:
void ledoff() // spegne tutti i led, DIG + SEG
digitalWrite ( a , HIGH );
digitalWrite ( b , HIGH );
digitalWrite ( c , HIGH );
digitalWrite ( d , HIGH );
digitalWrite ( e , HIGH );
digitalWrite ( f , HIGH );
digitalWrite ( g , HIGH );
digitalWrite ( h , HIGH );
digitalWrite ( d1 , LOW );
digitalWrite ( d2 , LOW );
digitalWrite ( d3 , LOW );
digitalWrite ( d4 , LOW );
void umidita () // inizio funzione UMIDITÀ
for (u=0; u < 325 ; u++)
ledoff();
digitalWrite( d1 , HIGH ); // H
digitalWrite( c , LOW );
digitalWrite( f , LOW );
digitalWrite( a , HIGH );
digitalWrite( b, LOW );
digitalWrite( d, HIGH );
digitalWrite( e, LOW );
digitalWrite( g, LOW );
digitalWrite( h, LOW );
delay (5);
ledoff();
digitalWrite (d3, HIGH);
ledon(humdec); // Decine UMIDITA >> HUM <<
delay (5);
ledoff ();
digitalWrite (d4, HIGH);
ledon(humun); // Unità UMIDITA >> HUM <<
delay(5);
ledoff();
} // fine funzione UMIDITÀ
void temperatura () // inizio funzione TEMPERATURA
for (t=0; t < 250 ; t++)
ledoff();
digitalWrite (d1, HIGH);
ledon(tempdec);
delay (5);
ledoff();
digitalWrite (d2, HIGH);
ledon (tempun);
delay (5);
ledoff();
digitalWrite ( a , LOW ); // AL CONTRARIO !!! accensione °
digitalWrite ( b , LOW );
digitalWrite ( f , LOW );
digitalWrite ( g , LOW );
delay (5);
ledoff();
digitalWrite ( a , LOW ); // accendo C
digitalWrite ( d , LOW );
digitalWrite ( e , LOW );
delay (5);
ledoff();
} // fine funzione TEMPERATURA
void check ()
int chk;
chk = DHT.read(DHT11_PIN); // READ DATA
temp = DHT.temperature;
hum = DHT.humidity;
// "temp" e "hum"
Serial.print ("Temperatura: ");
Serial.println (temp);
Serial.print ("Umidita: ");
Serial.println (hum);
Serial.println ();
humdec = hum / 10 ; // umidità decine e unità
humun = hum % 10 ;
tempdec = temp / 10 ; // temperatura: decine e unità
tempun = temp % 10;
Serial.begin(9600); // inizializzazione porta seriale
Serial.println("Inizializzazione programma...");
delay(3000);
pinMode(a, OUTPUT); // settaggio segment as OUTPUT
pinMode(b, OUTPUT);
pinMode(c, OUTPUT);
pinMode(d, OUTPUT);
pinMode(e, OUTPUT);
pinMode(f, OUTPUT);
pinMode(g, OUTPUT);
pinMode(h, OUTPUT);
pinMode(d1, OUTPUT); // settaggio digit as OUTPUT
pinMode(d2, OUTPUT);
pinMode(d3, OUTPUT);
pinMode(d4, OUTPUT);
ledoff ();
void loop ()
check (); // controlla temperatura e umidità
temperatura (); // richiamo funzione TEMPERATURA
umidita (); // richiamo funzione UMIDITÀ
