Hello, Good Afternoon
I am making a project in which if the loadcell gets weight more than "X" the led should blink.
Suppose :- If loadcell gets weight more than 1kg the LED1 should be continuous ONN, and if loadcell gets weight more than 5kg the LED2 should be continuous ONN , And If loadcell gets weight more than 19kg the BUZZER1 should be continuous ONN as it gets near to max weight of loadcell which is 20kg.
I am using
Arduino UNO, LCD, Loadcell 20kg, HX711 Amplifier
My code is
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
#include <HX711.h>
HX711 scale;
#define DT A0
#define SCK A1
#define sw 9
long sample=0;
float val=0;
long count=0;
unsigned long readCount(void)
unsigned long Count;
unsigned char i;
pinMode(DT, OUTPUT);
digitalWrite(DT,HIGH);
digitalWrite(SCK,LOW);
Count=0;
pinMode(DT, INPUT);
while(digitalRead(DT));
for (i=0;i<24;i++)
digitalWrite(SCK,HIGH);
Count=Count<<1;
if(digitalRead(DT))
Count++;
Count=Count^0x800000;
return(Count);
pinMode(SCK, OUTPUT);
pinMode(sw, INPUT_PULLUP);
lcd.begin(16, 2);
lcd.print(" Weight ");
lcd.setCursor(0,1);
lcd.print(" Measurement ");
lcd.clear();
calibrate();
count= readCount();
int w=(((count-sample)/val)-2*((count-sample)/val));
lcd.setCursor(0,0);
lcd.print("Measured Weight");
lcd.setCursor(0,1);
lcd.print(w);
lcd.print("g ");
if(digitalRead(sw)==0)
val=0;
sample=0;
w=0;
count=0;
calibrate();
void calibrate()
lcd.clear();
lcd.print("Calibrating...");
lcd.setCursor(0,1);
lcd.print("Please Wait...");
for(int i=0;i<100;i++)
count=readCount();
sample+=count;
sample/=100;
lcd.clear();
lcd.print("Put 100g & wait");
count=0;
while(count<1000)
count=readCount();
count=sample-count;
lcd.clear();
lcd.print("Please Wait....");
delay(2000);
count=readCount();
val+=sample-count;
val=val/100.0;
val=val/100.0; // put here your calibrating weight
lcd.clear();
Somebody help me
