Hx711 library scale
Hello I'm having a hard time finding my answer on the web and forums I even looked thru the hx711 library I got from git hub with lady adas Revision. This is where am at
I bought 10 load cell scales strain sensors df robot brand with the compatible hx711 ADC board .. having no trouble using up to 4 of them at a time
In the set up I'm. Using maga 2056.
I can call start each board and sensor communication in the setup like the following
Scale1.begin
Scale2.begin
Scale3.begin
Scale4.begin
These work fine and retrun the correct data
My troubles start at
Scale5.begin
And up to
Scale10.begin
Is there some limit on how many begins I can use on the mega I need 10 sensors for my project and I'm lost now.
why the scale.begin did not work past 4 sensors ?
Which pins are you using?
Post the entire code. Try to post the smallest version which shows the problem (5 scales).
sorry i cleaned it up a bit as it was confusing
#include "HX711.h"
HX711 scale;
HX711 scale1;
HX711 scale2;
HX711 scale3;
HX711 scale4;// VVV any scale defined past 4 on the mega seems to fail to communicate
HX711 scale5;
HX711 scale6;
HX711 scale7;
HX711 scale8;
HX711 scale9;
HX711 scale10;
  pinMode(4, OUTPUT);
  Serial.println("HX711 Demo");
  Serial.println("Before setting up the scale:");
  Serial.print("read: \t\t");
  Serial.println(scale1.read());      // print a raw reading from the ADC
 Serial.println(scale2.read());
 Serial.println(scale3.read());
 Serial.println(scale4.read());
 Serial.println(scale5.read());
 Serial.println(scale6.read());
 Serial.println(scale7.read());
 Serial.println(scale8.read());
  Serial.println("Readings:");
  Serial.println("Initializing the scale");
  // parameter "gain" is ommited; the default value 128 is used by the library
  // HX711.DOUT	- pin #52
  // HX711.PD_SCK	- pin #53
  scale1.begin(34, 35);
  scale1.set_scale(100000);
  scale2.begin(36, 37);
  scale2.set_scale(100000);
  scale3.begin(38, 39);
  scale3.set_scale(100000);
 scale4.begin(40, 41);
scale4.set_scale(100000);
// scale5.begin(42, 43);
 // scale5.set_scale(100000);//     <<<< when i remove the coment lines from here i get no response //                                                         from mega it turns in to a lifless brick
//scale6.begin(44, 45);
//  scale6.set_scale(100000);
////  scale7.begin(46, 48);
 // scale7.set_scale(100000);
 // scale8.begin(48, 49);
 // scale8.set_scale(100000);
  //scale9.begin(50, 51);
 // scale9.set_scale(100000);
  //scale10.begin(52, 53);
 // scale10.set_scale(100000);
  //byte x = 0;
  if (Serial.available()) {      // If anything comes in Serial (USB),
    // Serial.write(Serial.println(ww));
//using these to get readings from each sensor and board
 float a =(scale1.get_units());
  float b =(scale2.get_units());
  float c =(scale3.get_units());
 float d =(scale4.get_units());
  float e =(scale5.get_units());
   float f =(scale6.get_units());
    float g =(scale7.get_units());
     float h =(scale8.get_units());
  Serial.print("A is ");        // sends five bytes
  Serial.println(a);              // sends one byte
 Serial.print("b is ");        // sends five bytes
  Serial.println(b);              // sends one byte
   Serial.print("c is ");        // sends five bytes
  Serial.println(c);              // sends one byte
   Serial.print("d is ");        // sends five bytes
  Serial.println(d);              // sends one byte
   Serial.print("e is ");        // sends five bytes
  Serial.println(e);              // sends one byte
 Serial.print("f is ");        // sends five bytes
  Serial.println(f);              // sends one byte
   Serial.print("g is ");        // sends five bytes
  Serial.println(g);              // sends one byte
   Serial.print("h is ");        // sends five bytes
  Serial.println(h);              // sends one byte
 // Serial.endTransmission();    // stop transmitting
maybe the photo will help explain what i'm doing in the photo i have hacked a 16 port ether net switch to use as a single communication hub for all the scales to be used and connect to one place the arduino with then apply a mapped range and send off the filtered results to a remote pc via serial BLE or Ether net wifi Undecided yet
hx711 x 12.png - Google Drive
and the project it self
