I uploaded the code to the arduino but the serial monitor is not displaying anything. Please help.
this is my code:
#include <Dps310.h>
// Dps310 Opject
Dps310 Dps310PressureSensor = Dps310();
while (!Serial);
//Call begin to initialize Dps310PressureSensor
//The parameter 0x76 is the bus address. The default address is 0x77 and does not need to be given.
//Dps310PressureSensor.begin(Wire, 0x76);
//Use the commented line below instead of the one above to use the default I2C address.
//if you are using the Pressure 3 click Board, you need 0x76
Dps310PressureSensor.begin(Wire);
Serial.println("Init complete!");
float temperature;
float pressure;
uint8_t oversampling = 7;
int16_t ret;
//lets the Dps310 perform a Single temperature measurement with the last (or standard) configuration
//The result will be written to the paramerter temperature
//ret = Dps310PressureSensor.measureTempOnce(temperature);
//the commented line below does exactly the same as the one above, but you can also config the precision
//oversampling can be a value from 0 to 7
//the Dps 310 will perform 2^oversampling internal temperature measurements and combine them to one result with higher precision
//measurements with higher precision take more time, consult datasheet for more information
ret = Dps310PressureSensor.measureTempOnce(temperature, oversampling);
if (ret != 0)
//Something went wrong.
//Look at the library code for more information about return codes
Serial.print("FAIL! ret = ");
Serial.println(ret);
Serial.print("Temperature: ");
Serial.print(temperature);
Serial.println(" degrees of Celsius");
//Pressure measurement behaves like temperature measurement
//ret = Dps310PressureSensor.measurePressureOnce(pressure);
ret = Dps310PressureSensor.measurePressureOnce(pressure, oversampling);
if (ret != 0)
Serial.print("Pressure: ");
Serial.print(pressure);
Serial.println(" Pascal");
//Wait some time
