I am encountering a bug with my driver in the IDE that i cannot fix
. Variables and constants in RAM (global, static), used 28268 / 80192 bytes (35%)
║ SEGMENT BYTES DESCRIPTION
╠══ DATA 1524 initialized variables
╠══ RODATA 1032 constants
╚══ BSS 25712 zeroed variables
. Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 59747 / 65536 bytes (91%)
╠══ ICACHE 32768 reserved space for flash instruction cache
╚══ IRAM 26979 code in IRAM
. Code in flash (default, ICACHE_FLASH_ATTR), used 237744 / 1048576 bytes (22%)
╚══ IROM 237744 code in flash
esptool.py v3.0
Serial port COM4
A fatal esptool.py error occurred: Cannot configure port, something went wrong. Original message: PermissionError(13, 'A device attached to the system is not functioning.', None, 31)
Is your bughopper in port 4? https://www.youtube.com/live/oBQTn2shxho?t=3843s
it is
Hi @foxfurious05. Please tell us which USB to serial bridge chip your Arduino board has. This is a black chip near the USB socket.
The chip will usually be identified by writing on the top. This might say something like "WCH CH340G" or "SILABS CP2102".
Examples:
WCH CH340
SparkFun - CC BY-SA 4.0 (cropped)
There are some boards on the market that have a USB chip with the same IC package as the WCH CH340, and which are identified by the computer as a CH340. However, these chips don't have the "WCH CH340C ..." labeling like you see on the chip in the picture above:
NodeMCU Lua Lol1n V3.jpg by Popolon - CC BY-SA 4.0 (cropped)
These mysterious unlabeled chips have different characteristics than the labeled CH340 chips, so please let us know if yours is labeled or not.
Silicon Labs CP2102
CP2102
If it isn't clear, alternatively you can provide the link to where you bought the board from and we'll see if we can determine the chip from the product listing.
I can’t really see it but here is the board i bought
I also bought the board on amazon with the arduino official seller account
i also noticed this
and i don't think its supposed to be here
I do not have a Windoz unit however this is what I have observed over time on this Forum.
  1. Close Serial Monitor and Serial Plotter.
  2. Close any other program using COM4.
  3. Unplug the board, wait a few seconds, plug it back in.
  4. Check Tools -> Port and make sure COM4 is still the board.
  5. Try a different USB cable.
  6. Try a different USB port.
  7. If it uses CH340, reinstall or update the CH340 driver.
  8. Lower upload speed if available.
  9. Try Linux
I will try that and give feedback on it also thanks for providing a fix but on the other hand i also think its because of the DFU
Found this in the arduino docs
Would it be possible to get the link ?
Here it is @foxfurious05:
https://docs.arduino.cc/tutorials/nano-esp32/getting-started-nano-esp32/#install-board-package
Thank you very much i will give feedback if anything goes wrong
it seems everything is working thanks everyone
