I am desperately trying to work out how to display my code on my LCD screen.
I have attached my written code, it displays to the serial monitor correctly but lcd remains blank.
any offers of help would be greatly accepted.
The project is a soil moisture sensor showing dry and wet soil from analog to a percentage on two lines of the LCD.
type or paste code here
regards
Kaylo
#include <LiquidCrystal_I2C.h> #include <Wire.h>
LiquidCrystal_I2C lcd(0x3F,16,2);
int sensorPin = A0;
int delayTime = 5000;
int sensorVal;
int min = 158; // soil is dry.
int max = 138; // soil is wet.
float V2 = 0;
int percentage;
Thank you for trying to use code tags but you posted the code in the wrong place. Please edit your post and move your code to where it says "type or paste code here"
// i2c_scanner
// Modified from https://playground.arduino.cc/Main/I2cScanner/
#include <Wire.h>
// Set I2C bus to use: Wire, Wire1, etc.
#define WIRE Wire
WIRE.begin();
while (!Serial)
delay(10);
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
WIRE.beginTransmission(address);
error = WIRE.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknown error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println("done\n");
delay(5000); // wait 5 seconds for next scan
The above script will display a list of I2C devices connected to your arduino, making sure that the address is 0x3F. I use a 0x27 for my displays that uses the following: LiquidCrystal_I2C lcd(0x27,20,4);
There are 2 versions of the PCF8574. The PCF8574 and the PCF8574A. The PCF8574 has 0x27 as its derault address. The PCF8574A has 0x3f as its default address.
There are several libraries eith the name LiquidCrystal_I2C. They are not the same. Code written for one library may not work with another. Only trust examle code that comes with the library that you have installed.
