(I am Italian, but I thought that by writing in English I could get more opinions, since there are more people who speak it, so I translated some variables into English to make it clearer, I hope you understand).
This is the first time I have written in this forum and I am still not very experienced in programming, but I cannot fix this problem with malloc()
labirinto = labyrinth
rig = line
cln = column
#include <string.h>
char rig, cln, rig_cent, cln_cent;
char** labirinto;
char rig_cas, cln_cas, i, j;
bool error = false;
void free_memory(){
if (labirinto != NULL) {
for (i = 0; i < rig; i++) {
if (labirinto[i] != NULL) {
free(labirinto[i]); //Clear each allocated row
labirinto[i] = NULL;
free(labirinto); // Free the main pointer
labirinto = NULL;
error = false;
void choice_level(){
char scelta = 0, tentativi = 0;
Serial.println("Scegli il livello:\n1) Molto Facile\n2) Facile\n3) Normale\n4) Difficile\n5) Nightmare");
while(1){
while(scelta == 0){
if(Serial.available()){
scelta = Serial.read() - '0';
switch(scelta){
case 1: rig = 5; cln = 7; Serial.println("Modalita' Molto Facile impostata."); rig_cent = 3; cln_cent = 4;
case 2: rig = 9; cln= 11; Serial.println("Modalita' Facile impostata."); rig_cent = 5; cln_cent = 6;
case 3: rig = 13; cln = 17; Serial.println("Modalita' Normale impostata."); rig_cent = 7; cln_cent = 9;
case 4: rig = 15; cln = 21; Serial.println("Modalita' Difficile impostata."); rig_cent = 8; cln_cent = 11;
case 5: rig = 19; cln = 25; Serial.println("Modalita' Nightmare impostata."); rig_cent = 10; cln_cent = 13;
default: if(tentativi >= 2){
rig = 3; cln = 5; rig_cent = 2; cln_cent = 3;
Serial.println("\nTi piace fare il simpatico?\nmodalita' bambino impostata\n");
else{
scelta = 0; tentativi++; Serial.println("Numero non valido,\nscegli un numero da 1 a 5 per selezionare la difficolta'\n");
free_memory();
labirinto = (char**)malloc(rig * sizeof(char*)); // Allocate rows
if (labirinto == NULL) {
Serial.println("!Errore nell'allocazione della memoria per le righe!");
continue;
labirinto[i] = (char*)malloc(cln); // Allocate columns for each row
if (labirinto[i] == NULL) {
Serial.print("!Errore nell'allocazione della memoria per la colonna!");
error = true;
if (error) {
free_memory(); // Frees up all memory allocated so far
continue; //Go back to the beginning of the cycle and try again
for(i = 0; i<rig; i++){
memset(labirinto[i], '#',cln);
void inizio(){
rig_cas = rig;
cln_cas = cln;
while(1){
rig_cas = random(rig);
cln_cas = random(cln);
if(rig_cas == 0 || rig_cas == rig-1 || cln_cas == 0 || cln_cas == cln-1){
labirinto[rig_cas][cln_cas] = 'S';
void generazione_labirinto1(){
char direzione;
inizio();
while(rig_cas != rig_cent || cln_cas != cln_cent){
randomSeed(analogRead(0));
direzione = random(4);
if(direzione == 0 && rig_cas > rig_cent && (cln_cas != 0 && cln_cas != cln - 1)){
rig_cas--;
labirinto[rig_cas][cln_cas] = ' ';
else if(direzione == 1 && cln_cas > cln_cent && (rig_cas != 0 && rig_cas != rig - 1)){
cln_cas--;
else if(direzione == 2 && rig_cas < rig_cent && (cln_cas != 0 && cln_cas != cln - 1)){
rig_cas++;
else if(direzione == 3 && cln_cas < cln_cent && (rig_cas != 0 && rig_cas != rig - 1)){
cln_cas++;
while (rig_cas != 0 && rig_cas != rig-1 && cln_cas != 0 && cln_cas != cln-1) {
char direzione = random(4);
// Movimento casuale verso un bordo
if (direzione == 0 && rig_cas > 0 && labirinto[rig_cas-1][cln_cas] != ' ') { // Scava verso l'alto
rig_cas--;
else if (direzione == 1 && cln_cas > 0 && labirinto[rig_cas][cln_cas-1] != ' ') { // Scava verso sinistra
cln_cas--;
else if (direzione == 2 && rig_cas < rig-1 && labirinto[rig_cas+1][cln_cas] != ' ') { // Scava verso il basso
rig_cas++;
else if (direzione == 3 && cln_cas < cln-1 && labirinto[rig_cas][cln_cas+1] != ' ') { // Scava verso destra
cln_cas++;
labirinto[rig_cas][cln_cas] = 'F';
void generazione_labirinto2(){
void stampa_labirinto(){
for(i=0; i<rig; i++){
for(j=0; j<cln; j++){
Serial.print(labirinto[i][j]);
Serial.print(" ");
Serial.println("");
Serial.println("");
void gioco(){
void setup(){
DDRB = DDRB & ~0x0F;
void loop(){
choice_level();
generazione_labirinto1();
stampa_labirinto();
gioco();
while(1);
never mind that it's probably not very optimised and performant, but my goal was to create a labyrinth of varying difficulty with two-dimensional matrices, the choice of difficulty works perfectly, but i don't understand why when i then use malloc() to create a dynamic matrix, 40% of the time the program stops, and then when i tried to implement ways to make it so that when and if malloc() fails it frees the allocated memory and retries the allocation, nothing changed and it keeps stopping the program.
now the questions:
- did I do something wrong in programming ‘free_memory()’?
- is this not the error and is there something else in my program wrong?
Thank you in advance for any answers, if you have any questions or want me to put the rest of the code I am at your complete disposal
edit: I've added the full code, but for now you can only choose the difficulty (which changes the size of the labyrinth) and then it prints out the result. then I put a code underneath to replace in place of the code point where there is the column allocation so that it simulates an error and you don't have to wait for it to do it by itself.
I also add that at the moment I don't have Arduino available to me, so I used a software called Tinkercad to run it, I don't know if this could have affected the final result.
If I have forgotten anything, please let me know.
if (random(2) == 0) { // 50% di probabilità di fallire
Serial.print("Errore nell'allocazione della memoria per la riga ");
libera_memoria(); // Libera eventuale memoria allocata
continue;
