I'm trying to read received UDP packets in Arduino UNO using Wiznet w5500 module.
Wiring:
+5v -> 5v
GND -> GND
R -> Digital Pin 9
SS -> Digital Pin 10
MO -> Digital Pin 11
MI -> Digital Pin 12
CK -> Digital Pin 13
Code:
#include <SPI.h>
#include <Ethernet2.h>
#include <EthernetUdp2.h>
EthernetUDP Udp;
byte mac[] = {0xDE, 0xAD, 0xBE, 0xFF, 0xFE, 0xED};
IPAddress ip(172, 31, 92, 2);
unsigned int localPort = 10026; // local port to listen on
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet
Ethernet.begin(mac, ip);
Udp.begin(localPort);
int packetSize = Udp.parsePacket();
if (packetSize)
Serial.print("Received packet of size ");
Serial.println(packetSize);
// read the packet into packetBufffer
Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
Serial.print("Contents: ");
Serial.println(packetBuffer);
I successfully ping w5500 module from my PC's NIC. Then I use Packet Sender software to send a UDP packet (from my PC) to the IP and Port of the w5500 but Arduino doesn't even receive the packet.
I can't find the error.
Thanks
