Hello All,
I am trying to understand the Arduino library of PCA9685 module. However, I cant understand the following.
There is a variable of type TwoWire pointer as _i2cWire
TwoWire* _i2cWire;
What does this exactly mean?
Thank you.
Hello All,
TwoWire* _i2cWire;
Thank you.
Show the code and where you found it.
Sorry the heading was misleading and I have modified it.
I ve found the code from here.
Also two more things I dont understand is that, the i2cAddress variable is initialized as byte i2cAddress = B000000;
As far as I know, i2c address must be 7 bits long, but this B000000 is something I dont know.
In addition to that, there is an assignment as TwoWire& i2cWire = Wire;
I think it must be TwoWire* i2cWire.
Could you please shed light on these ?
Thanks.
/* Arduino Library for the PCA9685 16-Channel PWM Driver Module.
Copyright (C) 2016-2020 NachtRaveVL <nachtravevl@gmail.com>
Copyright (C) 2012 Kasper Skårhøj <kasperskaarhoj@gmail.com>
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
Created by Kasper Skårhøj, August 3rd, 2012.
Forked by Vitska, June 18th, 2016.
Forked by NachtRaveVL, July 29th, 2016.
PCA9685-Arduino - Version 1.2.15
#ifndef PCA9685_H
#define PCA9685_H
// Library Setup
// NOTE: While editing the main header file isn't ideal, it is often the easiest given
// the Arduino IDE's limited custom build flag support. Editing this header file directly
// will affect all projects compiled on your system using these library files.
// Uncomment or -D this define to enable use of the software i2c library (min 4MHz+ processor).
//#define PCA9685_ENABLE_SOFTWARE_I2C // http://playground.arduino.cc/Main/SoftwareI2CLibrary
// Uncomment or -D this define to swap PWM low(begin)/high(end) phase values in register reads/writes (needed for some chip manufacturers).
//#define PCA9685_SWAP_PWM_BEG_END_REGS
// Uncomment or -D this define to enable debug output.
//#define PCA9685_ENABLE_DEBUG_OUTPUT
// Hookup Callouts
// -PLEASE READ-
// Many digital servos run on a 20ms pulse width (50Hz update frequency) based duty cycle,
// and do not utilize the entire pulse width for their control. Typically, 2.5% of the
// 20ms pulse width (0.5ms) represents -90° offset, and 12.5% of the 20ms pulse width
// (2.5ms) represents +90° offset. This roughly translates to raw PCA9685 PWM values of
// 102 and 512 (out of the 4096/12-bit value range) for their -90°/+90° offset control.
// However, these may need to be adjusted to fit your specific servo (e.g. some we've
// tested run ~130 to ~525 for their -90°/+90° offset control). Be aware that driving
// some 180° servos too far past their -90°/+90° operational range can cause a little
// plastic limiter pin to break off and get stuck inside of the servo's gearing, which
// could potentially cause the servo to become jammed and no longer function. Continuous
// servos operate in much the same fashion as 180° servos, but instead of the 2.5%/12.5%
// pulse width controlling a -90°/+90° offset it controls a -1x/+1x speed multiplier,
// with 0x being parked/no-movement and -1x/+1x being maximum speed in either direction.
#if defined(ARDUINO) && ARDUINO >= 100
#include <Arduino.h>
#else
#include <WProgram.h>
#endif
#ifndef PCA9685_ENABLE_SOFTWARE_I2C
#include <Wire.h>
#if BUFFER_LENGTH
#define PCA9685_I2C_BUFFER_LENGTH BUFFER_LENGTH
#elif I2C_BUFFER_LENGTH
#define PCA9685_I2C_BUFFER_LENGTH I2C_BUFFER_LENGTH
#else
#warning "i2c buffer length not defined - using default value of 32, which may not be correct for your microcontroller. Check Wire.h (or similar) for your hardware and manually define BUFFER_LENGTH or I2C_BUFFER_LENGTH to remove this warning."
#define PCA9685_I2C_BUFFER_LENGTH 32
#endif // /if BUFFER_LENGTH
#else
#include <avr/io.h>
#define PCA9685_USE_SOFTWARE_I2C
#endif // /ifndef PCA9685_ENABLE_SOFTWARE_I2C
// Default proxy addresser i2c addresses
#define PCA9685_I2C_DEF_ALLCALL_PROXYADR (byte)0xE0 // Default AllCall i2c proxy address
#define PCA9685_I2C_DEF_SUB1_PROXYADR (byte)0xE2 // Default Sub1 i2c proxy address
#define PCA9685_I2C_DEF_SUB2_PROXYADR (byte)0xE4 // Default Sub2 i2c proxy address
#define PCA9685_I2C_DEF_SUB3_PROXYADR (byte)0xE8 // Default Sub3 i2c proxy address
// Output driver control mode (see datasheet Table 12 and Fig 13, 14, and 15 concerning correct
// usage of OUTDRV).
enum PCA9685_OutputDriverMode {
PCA9685_OutputDriverMode_OpenDrain, // Module outputs in an open-drain (aka direct connection) style structure with 400mA @5v total sink current, useful for LEDs and low-power Servos
PCA9685_OutputDriverMode_TotemPole, // Module outputs in a totem-pole (aka push-pull) style structure with 400mA @5v total sink current and 160mA total source current, useful for external drivers (default)
PCA9685_OutputDriverMode_Count, // Internal use only
PCA9685_OutputDriverMode_Undefined = -1 // Internal use only
// NOTE: Totem-pole mode should be used when an external N-type or P-type driver is in
// use, which provides actual sourcing current while open-drain mode doesn't. At max
// channel capacity, the sink current limit is 25mA@5v per channel while the source
// current limit, in totem-pole mode, is 10mA@5v per channel. However, from datasheet
// Table 6. subnote [1]: "Some newer LEDs include integrated Zener diodes to limit
// voltage transients, reduce EMI, and protect the LEDs, and these -MUST- be driven only
// in the open-drain mode to prevent over-heating the IC." Also from datasheet, Section
// 10. question 5: "in the push-pull architecture there is a low resistance path to GND
// through the Zener and this [causes] the IC to overheat."
// Output-enabled/active-low-OE-pin=LOW driver output mode (see datasheet Table 12 and
// Fig 13, 14, and 15 concerning correct usage of INVRT).
enum PCA9685_OutputEnabledMode {
PCA9685_OutputEnabledMode_Normal, // When OE is enabled/LOW, channels output a normal signal, useful for N-type external drivers (default)
PCA9685_OutputEnabledMode_Inverted, // When OE is enabled/LOW, channels output an inverted signal, useful for P-type external drivers or direct connection
PCA9685_OutputEnabledMode_Count, // Internal use only
PCA9685_OutputEnabledMode_Undefined = -1 // Internal use only
// NOTE: Polarity inversion is often set according to if an external N-type driver
// (should not use INVRT) or external P-type driver/direct connection (should use INVRT)
// is used. Most breakouts have just a 220Ω resistor between the individual channel
// outputs of the IC and PWM output pins, which is useful when powering LEDs. The V+ rail
// of most breakouts can connect through a 10v 1000μF decoupling capacitor, typically
// already installed on most breakouts, which can reduce voltage spikes and ground bounce
// during phase shifts at the start/end of the PWM high phase when many channel devices
// are connected together. See https://forums.adafruit.com/viewtopic.php?f=8&t=127421 and
// https://forums.adafruit.com/viewtopic.php?f=8&t=162688 for information on installing
// a decoupling capacitor if need arises.
// Output-not-enabled/active-low-OE-pin=HIGH driver output mode (see datasheet Section
// 7.4 concerning correct usage of OUTNE).
enum PCA9685_OutputDisabledMode {
PCA9685_OutputDisabledMode_Low, // When OE is disabled/HIGH, channels output a LOW signal (default)
PCA9685_OutputDisabledMode_High, // When OE is disabled/HIGH, channels output a HIGH signal (only available in totem-pole mode)
PCA9685_OutputDisabledMode_Floating, // When OE is disabled/HIGH, channel outputs go into a floating (aka high-impedance/high-Z) state, which may be further refined via external pull-up/pull-down resistors
PCA9685_OutputDisabledMode_Count, // Internal use only
PCA9685_OutputDisabledMode_Undefined = -1 // Internal use only
// NOTE: Active-low-OE pin is typically used to synchronize multiple PCA9685 devices
// together, but can also be used as an external dimming control signal.
// Channel update strategy used when multiple channels are being updated in batch.
enum PCA9685_ChannelUpdateMode {
PCA9685_ChannelUpdateMode_AfterStop, // Channel updates commit after full-transmission STOP signal (default)
PCA9685_ChannelUpdateMode_AfterAck, // Channel updates commit after individual channel update ACK signal
PCA9685_ChannelUpdateMode_Count, // Internal use only
PCA9685_ChannelUpdateMode_Undefined = -1 // Internal use only
// Software-based phase balancing scheme.
enum PCA9685_PhaseBalancer {
PCA9685_PhaseBalancer_None, // Disables software-based phase balancing, relying on installed hardware to handle current sinkage (default)
PCA9685_PhaseBalancer_Linear, // Uses linear software-based phase balancing, with each channel being a preset 16 steps (out of the 4096/12-bit value range) away from previous channel (may cause LED flickering/skipped-cycles on PWM changes)
PCA9685_PhaseBalancer_Count, // Internal use only
PCA9685_PhaseBalancer_Undefined = -1 // Internal use only
// NOTE: Software-based phase balancing attempts to further mitigate ground bounce and
// voltage spikes during phase shifts at the start/end of the PWM high phase by shifting
// the leading edge of each successive PWM high phase by some amount. This helps make
// the current sinks occur over the entire duty cycle range instead of all together at
// once. Software-based phase balancing can be useful in certain situations, but in
// practice has been the source of many problems, including the case whereby the PCA9685
// will skip a cycle between PWM changes when the leading/trailing edge is shifted past a
// certain point. While we may revisit this idea in the future, for now we're content on
// leaving None as the default, and limiting the shift that Linear applies.
class PCA9685 {
public:
#ifndef PCA9685_USE_SOFTWARE_I2C
// Library constructor. Typically called during class instantiation, before setup().
// The i2c address should be the value of the A5-A0 pins, as the class handles the
// module's base i2c address. It should be a value between 0 and 61, which gives a
// maximum of 62 modules that can be addressed on the same i2c line.
// Boards with more than one i2c line (e.g. Due/Mega/etc.) can supply a different
// Wire instance, such as Wire1 (using SDA1/SCL1), Wire2 (using SDA2/SCL2), etc.
// Supported i2c clock speeds are 100kHz, 400kHz (default), and 1000kHz.
PCA9685(byte i2cAddress = B000000, TwoWire& i2cWire = Wire, uint32_t i2cSpeed = 400000);
// Convenience constructor for custom Wire instance. See main constructor.
PCA9685(TwoWire& i2cWire, uint32_t i2cSpeed = 400000, byte i2cAddress = B000000);
#else
// Minimum supported i2c clock speed is 100kHz, which sets minimum processor speed at
// 4MHz+ running in i2c standard mode. For up to 400kHz i2c clock speeds, minimum
// processor speed is 16MHz+ running in i2c fast mode.
PCA9685(byte i2cAddress = B000000);
#endif
// Resets modules. Typically called in setup(), before any init()'s. Calling will
// perform a software reset on all PCA9685 devices on the Wire instance, ensuring
// that all PCA9685 devices on that line are properly reset.
void resetDevices();
// Initializes module. Typically called in setup().
// See individual enums for more info.
void init(PCA9685_OutputDriverMode driverMode = PCA9685_OutputDriverMode_TotemPole,
PCA9685_OutputEnabledMode enabledMode = PCA9685_OutputEnabledMode_Normal,
PCA9685_OutputDisabledMode disabledMode = PCA9685_OutputDisabledMode_Low,
PCA9685_ChannelUpdateMode updateMode = PCA9685_ChannelUpdateMode_AfterStop,
PCA9685_PhaseBalancer phaseBalancer = PCA9685_PhaseBalancer_None);
// Convenience initializer for custom phase balancer. See main init method.
void init(PCA9685_PhaseBalancer phaseBalancer,
PCA9685_ChannelUpdateMode updateMode = PCA9685_ChannelUpdateMode_AfterStop);
// Initializes module as a proxy addresser. Typically called in setup(). Used when
// instance talks through to AllCall/Sub1-Sub3 instances as a proxy object. Using
// this method will disable any method that performs a read or conflicts with certain
// states. Proxy addresser i2c addresses must be >= 0xE0, with defaults provided via
// PCA9685_I2C_DEF_[ALLCALL|SUB[1-3]]_PROXYADR defines.
void initAsProxyAddresser();
// Mode accessors
byte getI2CAddress();
uint32_t getI2CSpeed();
PCA9685_OutputDriverMode getOutputDriverMode();
PCA9685_OutputEnabledMode getOutputEnabledMode();
PCA9685_OutputDisabledMode getOutputDisabledMode();
PCA9685_ChannelUpdateMode getChannelUpdateMode();
PCA9685_PhaseBalancer getPhaseBalancer();
// Min: 24Hz, Max: 1526Hz, Default: 200Hz. As Hz increases channel resolution
// diminishes, as raw pre-scaler value, computed per datasheet, starts to require
// much larger frequency increases for single-digit increases of the raw pre-scaler
// value that ultimately controls the PWM frequency produced.
void setPWMFrequency(float pwmFrequency = 200);
// Sets standard servo frequency of 50Hz.
void setPWMFreqServo();
// Turns channel either full on or full off
void setChannelOn(int channel);
void setChannelOff(int channel);
// PWM amounts 0 - 4096, 0 full off, 4096 full on
void setChannelPWM(int channel, uint16_t pwmAmount);
void setChannelsPWM(int begChannel, int numChannels, const uint16_t *pwmAmounts);
// Sets all channels, but won't distribute phases
void setAllChannelsPWM(uint16_t pwmAmount);
// Returns PWM amounts 0 - 4096, 0 full off, 4096 full on
uint16_t getChannelPWM(int channel);
// Enables multiple talk-through paths via i2c bus (lsb/bit0 must stay 0). To use,
// create a new proxy instance using initAsProxyAddresser() with proper proxy i2c
// address >= 0xE0, and pass that instance's i2c address into desired method below.
void enableAllCallAddress(byte i2cAddressAllCall = PCA9685_I2C_DEF_ALLCALL_PROXYADR);
void enableSub1Address(byte i2cAddressSub1 = PCA9685_I2C_DEF_SUB1_PROXYADR);
void enableSub2Address(byte i2cAddressSub2 = PCA9685_I2C_DEF_SUB2_PROXYADR);
void enableSub3Address(byte i2cAddressSub3 = PCA9685_I2C_DEF_SUB3_PROXYADR);
void disableAllCallAddress();
void disableSub1Address();
void disableSub2Address();
void disableSub3Address();
// Allows external clock line to be utilized (power reset required to disable)
void enableExtClockLine();
byte getLastI2CError();
#ifdef PCA9685_ENABLE_DEBUG_OUTPUT
int getWireInterfaceNumber();
void printModuleInfo();
void checkForErrors();
#endif
protected:
byte _i2cAddress; // Module's i2c address (default: B000000)
TwoWire* _i2cWire; // Wire class instance (unowned) (default: Wire)
uint32_t _i2cSpeed; // Module's i2c clock speed (default: 400000)
#endif
PCA9685_OutputDriverMode _driverMode; // Output driver mode
PCA9685_OutputEnabledMode _enabledMode; // OE enabled output mode
PCA9685_OutputDisabledMode _disabledMode; // OE disabled output mode
PCA9685_ChannelUpdateMode _updateMode; // Channel update mode
PCA9685_PhaseBalancer _phaseBalancer; // Phase balancer scheme
bool _isProxyAddresser; // Proxy addresser flag (disables certain functionality)
byte _lastI2CError; // Last module i2c error
byte getMode2Value();
void getPhaseCycle(int channel, uint16_t pwmAmount, uint16_t *phaseBegin, uint16_t *phaseEnd);
void writeChannelBegin(int channel);
void writeChannelPWM(uint16_t phaseBegin, uint16_t phaseEnd);
void writeChannelEnd();
void writeRegister(byte regAddress, byte value);
byte readRegister(byte regAddress);
#ifdef PCA9685_USE_SOFTWARE_I2C
uint8_t _readBytes;
#endif
void i2cWire_begin();
void i2cWire_beginTransmission(uint8_t);
uint8_t i2cWire_endTransmission(void);
uint8_t i2cWire_requestFrom(uint8_t, uint8_t);
size_t i2cWire_write(uint8_t);
uint8_t i2cWire_read(void);
// Class to assist with calculating Servo PWM values from angle/speed values
class PCA9685_ServoEval {
public:
// Uses a linear interpolation method to quickly compute PWM output value. Uses
// default values of 2.5% and 12.5% of phase length for -90/+90 (or -1x/+1x).
PCA9685_ServoEval(uint16_t minPWMAmount = 102, uint16_t maxPWMAmount = 512);
// Uses a cubic spline to interpolate due to an offsetted zero point that isn't
// exactly between -90/+90 (or -1x/+1x). This takes more time to compute, but gives a
// smoother PWM output value along the entire range.
PCA9685_ServoEval(uint16_t minPWMAmount, uint16_t midPWMAmount, uint16_t maxPWMAmount);
~PCA9685_ServoEval();
// Returns the PWM value to use given the angle offset (-90 to +90)
uint16_t pwmForAngle(float angle);
// Returns the PWM value to use given the speed multiplier (-1 to +1)
uint16_t pwmForSpeed(float speed);
private:
float *_coeff; // a,b,c,d coefficient values
bool _isCSpline; // Cubic spline tracking, for _coeff length
#endif // /ifndef PCA9685_H
It's a binary representation of zero, reflecting the A5-A0 pins for selection of the sub-buses.
I only can guess that the pointer type is for use with some software I2C library.
thank you @DrDiettrich
I am learning Arduino specific variables, so my question is that, is TwoWire a variable type in Arduino ?
I may be wrong but it might be the type of the Wire object in the Arduino standard I2C (Wire) library.
"Wire" is just one I2C implementation.
The usage of
TwoWire* _i2cWire;
gives you the option to write your own I2C implementation and handover the instance of that implementation to the PCA9685 API.
Or - there are microcontrollers with several I2C instances. In that case you can hand over Wire1, Wire2 to the PCA9685 API and use the second, the third I2C interface.
The library also defaults to Wire --> the "standard" I2C interface. So by default you don't need to care about. Hence the constructor with:
So, does this mean that, if I want to use lets say a method as beginTransmission OR requestFrom APIs from wire library, can I simply do the following ?
TwoWire* _i2cWire;
i2cWire -> beginTransmission(address);
i2cWire -> requestFrom(address, 2);
yes, just use it like in the .cpp of that library.
you can see the definition for TwoWire in Wire.h as well as that Wire is an instantiation of a TwoWire object
this says _i2cWire is a pointer to a TwoWire object.
in your case, it's the pointer to a TwoWire object in the PCA9685 class
Have you used a Servo motor (or any other library) ? Here is an example for the Servo library: https://docs.arduino.cc/learn/electronics/servo-motors/
The class declares how all the variables and functions should look like.
The object is the actual data that is created and used.
#include <Servo.h> // the class definition is in Servo.h
Servo myservo; // create servo object to control a servo
The class "Servo" is declared in "Servo.h". The term is "declared" because it is just a description how it should look like.
The object "myservo" is created.
For the I2C library, it should look like this:
#include <TwoWire.h>
TwoWire mytwowire;
But then they renamed "TwoWire.h" to "Wire.h" and they already created a object called "Wire" inside "Wire.h".
So you get:
#include <Wire.h> // The object "Wire" is created in Wire.h
Wire.begin(); // Use "Wire" because it is already created.
As a result, you can just include "Wire.h" and use the "Wire" object.
That is fine, as long as you don't dive deeper and find the "TwoWire" class.
Close. You must first assign a value to the pointer:
TwoWire* _i2cWire;
_i2cWire = &Wire;
_i2cWire -> beginTransmission(address);
_i2cWire -> requestFrom(address, 2);
