I don't see IP address ESP32 [SOLVED]
Hi
I have esp32 dev kit v1
I am following tutorials ESP32 Web server in Arduino IDE - Contol GPIOs and LEDs
I don't know why I don't get IP address on serial monitor
#include <WiFi.h>
const char* WIFI_NAME= "Sarkar";
const char* WIFI_PASSWORD = "Sarkar@123";
WiFiServer server(80);
String header;
String LED_ONE_STATE = "off";
String LED_TWO_STATE = "off";
String LED_THREE_STATE = "off";
const int GPIO_PIN_NUMBER_22 = 22;
const int GPIO_PIN_NUMBER_23 = 23;
const int GPIO_PIN_NUMBER_15 = 15;
pinMode(GPIO_PIN_NUMBER_22, OUTPUT);
pinMode(GPIO_PIN_NUMBER_23, OUTPUT);
pinMode(GPIO_PIN_NUMBER_15, OUTPUT);
digitalWrite(GPIO_PIN_NUMBER_22, LOW);
digitalWrite(GPIO_PIN_NUMBER_23, LOW);
digitalWrite(GPIO_PIN_NUMBER_15, LOW);
Serial.print("Connecting to ");
Serial.println(WIFI_NAME);
WiFi.begin(WIFI_NAME, WIFI_PASSWORD);
Serial.print("Trying to connect to Wifi Network");
Serial.println("");
Serial.println("Successfully connected to WiFi network");
Serial.println("IP address: ");
server.begin();
void loop(){
WiFiClient client = server.available();
if (client) {
Serial.println("New Client is requesting web page");
String current_data_line = "";
while (client.connected()) {
if (client.available()) {
char new_byte = client.read();
Serial.write(new_byte);
header += new_byte;
if (new_byte == '\n') {
if (current_data_line.length() == 0)
client.println("Content-type:text/html");
client.println("Connection: close");
client.println();
if (header.indexOf("LED0=ON") != -1)
Serial.println("GPIO23 LED is ON");
LED_ONE_STATE = "on";
digitalWrite(GPIO_PIN_NUMBER_22, HIGH);
if (header.indexOf("LED0=OFF") != -1)
Serial.println("GPIO23 LED is OFF");
if (header.indexOf("LED1=ON") != -1)
LED_TWO_STATE = "on";
digitalWrite(GPIO_PIN_NUMBER_23, HIGH);
if (header.indexOf("LED1=OFF") != -1)
if (header.indexOf("LED2=ON") != -1)
Serial.println("GPIO15 LED is ON");
LED_THREE_STATE = "on";
digitalWrite(GPIO_PIN_NUMBER_15, HIGH);
if(header.indexOf("LED2=OFF") != -1) {
Serial.println("GPIO15 LED is OFF");
client.println("<!DOCTYPE html><html>");
client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
client.println("<link rel=\"icon\" href=\"data:,\">");
client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
client.println(".button { background-color: #4CAF50; border: 2px solid #4CAF50;; color: white; padding: 15px 32px; text-align: center; text-decoration: none; display: inline-block; font-size: 16px; margin: 4px 2px; cursor: pointer; }");
client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
// Web Page Heading
client.println("</style></head>");
client.println("<body><center><h1>ESP32 Web server LED controlling example</h1></center>");
client.println("<center><h2>Web Server Example Microcontrollerslab.com</h2></center>" );
client.println("<center><h2>Press on button to turn on led and off button to turn off LED</h3></center>");
client.println("<form><center>");
client.println("<p> LED one is " + LED_ONE_STATE + "</p>");
// If the PIN_NUMBER_22State is off, it displays the ON button
client.println("<center> <button class=\"button\" name=\"LED0\" value=\"ON\" type=\"submit\">LED0 ON</button>") ;
client.println("<button class=\"button\" name=\"LED0\" value=\"OFF\" type=\"submit\">LED0 OFF</button>
client.println("<p>LED two is " + LED_TWO_STATE + "</p>");
client.println("<button class=\"button\" name=\"LED1\" value=\"ON\" type=\"submit\">LED1 ON</button>");
client.println("<button class=\"button\" name=\"LED1\" value=\"OFF\" type=\"submit\">LED1 OFF</button>
client.println("<p>LED three is " + LED_THREE_STATE + "</p>");
client.println ("<button class=\"button\" name=\"LED2\" value=\"ON\" type=\"submit\">LED2 ON</button>");
client.println ("<button class=\"button\" name=\"LED2\" value=\"OFF\" type=\"submit\">LED2 OFF</button></center>");
client.println("</center></form></body></html>");
client.println();
else if (new_byte != '\r')
current_data_line += new_byte;
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("Client disconnected.");
Serial.println("");
Try resetting the ESP32 with the Serial monitor open after the code has been uploaded
UKHeliBob:
Hi UKHeliBob
Thanks for responding I have done that but No luck
Do you see anything on the Serial monitor after the reset ?
write a function that prints out the status instead of just
"Trying to connect to Wifi Network""
This will give hints what is going on
best regards Stefan
const int GPIO_PIN_NUMBER_22 = 22; This is pointless and verbose.
Name the pin after its function.
e.g.const int shapedChargeDetonator = 22;
There are already a set of ESP32 built in pin constants.
see the ESP32 API: API Reference - ESP32 - — ESP-IDF Programming Guide latest documentation
