Every time i power on my arduino (usb or external) i have to press the reset button to get the sketch to run properly. When it first powers on there is a blinking curson on the lcd in the 13,3 position (the lcd is a 20x4) How can I fix this so I don't have to hit reset every time I power it on. Eventually I will have all of this mounted so the arduino is hidden. And i'd prefer not to make an external reset.
Thanks in advance.
JT
#include <Wire.h>
#include <Keypad.h>
//constants for Control Pin
int controlPin = 12;
char currentTimeValue[4];
int currentState = 1;
int timerSeconds = 0;
int lpcnt = 0;
//define the keypad
const byte rows = 4;
const byte cols = 4;
char keys[rows][cols] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[rows] = {11,10,9,8};
byte colPins[cols] = {7,6,5,4};
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, rows, cols);
LiquidCrystal_I2C lcd(0x3F,20,4); // set the LCD address to 0x27 for a 16 chars and 2 line
//display
lcd.init(); // initialize the lcd
// Print a message to the LCD.
lcd.backlight();
//display main screen
displayCodeEntryScreen();
//setup and turn off relay
pinMode(controlPin, OUTPUT);
digitalWrite(controlPin, LOW);
//setup default time to 00:00
currentTimeValue[0]='0';
currentTimeValue[1]='0';
currentTimeValue[2]='0';
currentTimeValue[3]='0';
showEnteredTime();
int l;
char tempVal[3];
char key = keypad.getKey();
//key pressed and state is 1
if (int(key) != 0 and currentState == 1) {
switch (key) {
case '*':
relayStatus(false);
showEnteredTime();
currentState = 1;
lpcnt = 0;
timerSeconds = 0;
case '#':
tempVal[0] = currentTimeValue[0];
tempVal[1] = currentTimeValue[1];
tempVal[2] = 0;
timerSeconds = atol(tempVal) * 60;
tempVal[0] = currentTimeValue[2];
tempVal[1] = currentTimeValue[3];
tempVal[2] = 0;
timerSeconds = timerSeconds + atol(tempVal);
currentState = 2;
default:
currentTimeValue[0] = currentTimeValue[1];
currentTimeValue[1] = currentTimeValue[2];
currentTimeValue[2] = currentTimeValue[3];
currentTimeValue[3] = key;
showEnteredTime();
if (currentState == 2) {
if (int(key) != 0) {
if (key == '*') {
relayStatus(false);
showEnteredTime();
currentState = 1;
lpcnt = 0;
timerSeconds = 0;
if (lpcnt > 9) {
lpcnt = 0;
--timerSeconds;
showCountdown();
if (timerSeconds <= 0) {
currentState = 1;
relayStatus(false);
showEnteredTime();
relayStatus(true);
++lpcnt;
delay(100);
void showEnteredTime()
lcd.setCursor(8,3);
lcd.print(currentTimeValue[0]);
lcd.print(currentTimeValue[1]);
lcd.print(":");
lcd.print(currentTimeValue[2]);
lcd.print(currentTimeValue[3]);
void relayStatus(bool state)
if (state)
digitalWrite(controlPin, HIGH);
void showCountdown()
char timest[6];\
lcd.setCursor(0,0);
lcd.print(" BURNING SCREEN ");
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(8,2);
lcd.print(" ");
sprintf(timest, "%d:%.2d", (timerSeconds/60), (timerSeconds - ((timerSeconds/60)*60)));
lcd.print(timest);
lcd.print(" ");
void displayCodeEntryScreen()
clearScreen();
lcd.setCursor(0,0);
lcd.print(" ENTER TIME ");
void clearScreen()
lcd.setCursor(0,0);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,2);
lcd.print(" ");
lcd.setCursor(0,3);
lcd.print(" ");
