I keep getting the error 'send' was not declared in this scope
here is the code hope someone can help
#include <VirtualWire.h>
int sensorAnalogPin = A0; // Select the Arduino input pin to accept the Sound Sensor's analog output
int sensorDigitalPin = 3; // Select the Arduino input pin to accept the Sound Sensor's digital output
int analogValue = 0; // Define variable to store the analog value coming from the Sound Sensor
int digitalValue; // Define variable to store the digital value coming from the Sound Senso
// Initialize the IO and ISR
vw_setup(2000); // Bits per sec
Serial.begin(9600); // The IDE settings for Serial Monitor/Plotter (preferred) must match this speed
pinMode(sensorDigitalPin,INPUT); // Define pin 7 as an input port, to accept digital input
analogValue = analogRead(sensorAnalogPin); // Read the value of the analog interface A0 assigned to digitalValue
digitalValue=digitalRead(sensorDigitalPin); // Read the value of the digital interface 7 assigned to digitalValue
Serial.println(analogValue); // Send the analog value to the serial transmit interface
if(analogValue>300) // When the Sound Sensor sends signla, via voltage present, light LED13 (L)
send("Alarm went off");
void send (char *message)
vw_send((uint8_t *)message, strlen(message));
vw_wait_tx(); // Wait until the whole message is gone
Of course you are. You didn't really change anything but the issue should be obvious. All of your code got indented because you are missing the closing } for the loop() function.
pinMode(sensorDigitalPin, INPUT); // Define pin 7 as an input port, to accept digital input
digitalValue = digitalRead(sensorDigitalPin); // Read the value of the digital interface 7 assigned to digitalValue
if (analogValue > 300) // When the Sound Sensor sends signla, via voltage present, light LED13 (L)
// vvvvvvv--- strange indentation here
int digitalValue;
send("Hello, it's me");
Hi @nuthead411
The send() function is inside the loop() function.
Test it now.
RV mineirin
int digitalValue;
