I made some changes and now getting a linking error but it makes no sense
The error is when it links and it says
"C:\Users\timoc\Documents\Arduino\simpleMesh6\simpleMesh6/simpleMesh6.ino:173: undefined reference to `_Z8tag_nodev'
collect2.exe: error: ld returned 1 exit status"
Note I have an earlier version prior to some logic changes and it compiles fine
// this is a simple example that uses the easyMesh library
// 1. blinks led once for every node on the mesh
// 2. blink cycle repeats every BLINK_PERIOD
// 4. prints anything it receives to Serial.print
String splits[20];
//enum State {
//    not_started,
//    decide_mode,
//    started,
//    done};
int not_started=0;
int decide_mode=1;
int started=2;
int done=3;
int state;
int mode;
#include <painlessMesh.h>
#include <Bounce2.h>
#include <FastLED.h>
#define ARRAY_SIZE(A) (sizeof(A) / sizeof((A)[0]))
Bounce bounce = Bounce();
// some gpio pin that is connected to an LED...
// on my rig, this is 5, change to the right number of your LED.
#ifdef LED_BUILTIN
#define LED LED_BUILTIN
#else
#define LED 2
#endif
#define PUSHBUTTON 5 //D1mini D1
#define ON LOW
#define OFF HIGH
#define   BLINK_PERIOD    3000 // milliseconds until cycle repeat
#define   BLINK_DURATION  150  // milliseconds LED is on for
//fast led stuff
#define DATA_PIN    4 //D1MINI - D2
#define LED_TYPE    WS2812B
#define COLOR_ORDER GRB
#define NUM_LEDS    8
CRGB leds[NUM_LEDS];
#define BRIGHTNESS          255
#define   MESH_SSID       "whateverYouLike"
#define   MESH_PASSWORD   "somethingSneaky"
#define   MESH_PORT       5555
// Prototypes
void sendMessage();
void receivedCallback(uint32_t from, String & msg);
void newConnectionCallback(uint32_t nodeId);
void changedConnectionCallback();
void nodeTimeAdjustedCallback(int32_t offset);
void delayReceivedCallback(uint32_t from, int32_t delay);
void tag_node();
void Light(bool on);
void rainbow_wave(uint8_t thisSpeed, uint8_t deltaHue);
int splitString(String str,String delim);
uint32_t getRandomNode();
bool other_nodes();
int num_other_nodes;
Scheduler     userScheduler; // to control your personal task
painlessMesh  mesh;
bool calc_delay = false;
SimpleList<uint32_t> nodes;
uint32_t myself;
uint32_t maxNode;
String myself_string;
void sendMessage() ; // Prototype
Task taskSendMessage( TASK_SECOND * 1, TASK_FOREVER, &sendMessage ); // start with a one second interval
// Task to blink the number of nodes
Task blinkNoNodes;
bool onFlag = false;
unsigned long modestart = 0UL;
unsigned long mode2TimeStamp = 0UL;
// FAST LED STUFF -----------------
 // tell FastLED about the LED strip configuration
  FastLED.addLeds<LED_TYPE,DATA_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  FastLED.setBrightness(BRIGHTNESS); //set master brightness
  FastLED.clear(true);
  FastLED.show();
  pinMode(LED, OUTPUT);
  bounce.attach( PUSHBUTTON ,  INPUT_PULLUP ); // USE INTERNAL PULL-UP
  bounce.interval(100);                        // interval in ms
  mesh.setDebugMsgTypes(ERROR | DEBUG);  // set before init() so that you can see error messages
  mesh.init(MESH_SSID, MESH_PASSWORD, &userScheduler, MESH_PORT);
  mesh.onReceive(&receivedCallback);
  mesh.onNewConnection(&newConnectionCallback);
  mesh.onChangedConnections(&changedConnectionCallback);
  mesh.onNodeTimeAdjusted(&nodeTimeAdjustedCallback);
  mesh.onNodeDelayReceived(&delayReceivedCallback);
  userScheduler.addTask( taskSendMessage );
  taskSendMessage.enable();
  myself = mesh.getNodeId();
  myself_string = String(myself);
  blinkNoNodes.set(BLINK_PERIOD, (mesh.getNodeList().size() + 1) * 2, []() {
      // If on, switch off, else switch on
      if (onFlag)
        onFlag = false;
        onFlag = true;
      blinkNoNodes.delay(BLINK_DURATION);
      if (blinkNoNodes.isLastIteration()) {
        // Finished blinking. Reset task for next run
        // blink number of nodes (including this node) times
        blinkNoNodes.setIterations((mesh.getNodeList().size() + 1) * 2);
        // Calculate delay based on current mesh time and BLINK_PERIOD
        // This results in blinks between nodes being synced
        blinkNoNodes.enableDelayed(BLINK_PERIOD -
            (mesh.getNodeTime() % (BLINK_PERIOD*1000))/1000);
  userScheduler.addTask(blinkNoNodes);
  blinkNoNodes.enable();
  randomSeed(analogRead(A0));
//how to use the rainbow
  mesh.update();
  bounce.update();
  if (state == not_started) {
      Light(onFlag);
  // if button pressed
  if (bounce.changed() && (bounce.read()==LOW)) {
    Serial.println("button pressed");
    //gotta start somewhere
      if (other_nodes()) {
        state=decide_mode;
        mode=0;
        modestart = millis();
        Serial.println("blinkNoNodes disabled for decide_mode after button");
        blinkNoNodes.disable();
        Serial.println("Turning off LED");
        Light(false);
        //rainbow_wave(10, 10);                                      // Speed, delta hue values.
        //FastLED.show();
        Serial.println("trying to start but no other nodes");
    } else if (state == decide_mode) {
      mode++;
      //is my light on- tag someone else and turn light off
    } else if  ((digitalRead(LED)==ON) && (state==started) && (mode==1)) {
       Serial.println("Turning off LED since it was on and button pressed");
       Light(false);
        tag_node();
    //no button
    } else if ( (state == decide_mode) && ((millis()- modestart)>5000)) {
      state=started;
      tag_node(mode);
    } else if ( (state == started) && (mode == 2) && (digitalRead(LED)==ON) && ((millis()- modestart)>2000)) {
        Light(false);
        tag_node();
void sendMessage() {
  //debug
  if (ESP.getFreeHeap() < 15000) {
     String msg = "node: ";
     msg += mesh.getNodeId();
     msg += " myFreeMemory: " + String(ESP.getFreeHeap());
     mesh.sendBroadcast(msg);
     Serial.printf("Sending message: %s\n", msg.c_str());
  if (calc_delay) {
    SimpleList<uint32_t>::iterator node = nodes.begin();
    while (node != nodes.end()) {
      mesh.startDelayMeas(*node);
      node++;
    calc_delay = false;
  //taskSendMessage.setInterval( random(TASK_SECOND * 1, TASK_SECOND * 5));  // between 1 and 5 seconds
  taskSendMessage.setInterval( TASK_SECOND * 1);  // every second
//************process incoming message        *********
void receivedCallback(uint32_t from, String & msg) {
  int numsplits;
  Serial.printf("startHere: Received from %u msg=%s\n", from, msg.c_str());
  if (msg.indexOf("TAG")>-1) {
         if (state != started) {
           state = started;
           //tagging has started-disable blink
           Serial.println("blinkNoNodes disabled for TAG");
           //turn off
           Light(false);
         numsplits = splitString(msg," ");
         String tagged_node = splits[4];
         Serial.println(tagged_node);
         //check if my node is the 2nd one
         if  (tagged_node == myself_string ) {
              //capture mode
               mode = splits[5].toInt();
              //acknowledge i was tagged
           // parms: myself_string, source -caller ,dest (me)
           String mymsg = build_string(myself_string,splits[2],myself_string,mode);
           Serial.println(mymsg);
           //turn on -I'm tagged
           Light(true);
void newConnectionCallback(uint32_t nodeId) {
  // Reset blink task
  onFlag = false;
  blinkNoNodes.enableDelayed(BLINK_PERIOD - (mesh.getNodeTime() % (BLINK_PERIOD*1000))/1000);
  Serial.printf("--> startHere: New Connection, nodeId = %u\n", nodeId);
  Serial.printf("--> startHere: New Connection, %s\n", mesh.subConnectionJson(true).c_str());
void changedConnectionCallback() {
  Serial.printf("Changed connections\n");
  // Reset blink task
  onFlag = false;
  nodes = mesh.getNodeList();
  num_other_nodes = nodes.size();
  Serial.printf("Num nodes: %d\n", num_other_nodes);
  Serial.printf("Connection list:");
    Serial.printf(" %u", *node);
    node++;
  calc_delay = true;
void nodeTimeAdjustedCallback(int32_t offset) {
  Serial.printf("Adjusted time %u. Offset = %d\n", mesh.getNodeTime(), offset);
void delayReceivedCallback(uint32_t from, int32_t delay) {
  Serial.printf("Delay to node %u is %d us\n", from, delay);
uint32_t getRandomNode() {
  //this will not include self
  int index = random(0,num_other_nodes);
  if (index> (num_other_nodes-1)) {
     index=0;
      if (index-- == 0) {
        return *node;
      node++;
//A tagging randomnode
void tag_node(int mode) {
     //get some other node
     String randomnode_string(getRandomNode());
     //// parms: myself_string, source,dest,dir
     String newmessage = build_string(myself_string,myself_string,randomnode_string,mode);
     mesh.sendBroadcast(newmessage);
     Serial.println(newmessage);
bool other_nodes() {
  return (num_other_nodes)?true:false;
String build_string(String myself,String source_node, String dest_node, int mode) {
  char buffer[40];
  char mesource[3]="__";
  char medest[3]  ="__";
  if (myself == source_node) {
    mesource[0]='M';
    mesource[1]='E';
    mesource[2]=0;
  }  if (myself == dest_node) {
    medest[0]='M';
    medest[1]='E';
    medest[2]=0;
  //source_node = source_node.substring(7,10);
  //dest_node = dest_node.substring(7,10);
  //example
  //TAG ME 1234567890    __ 1234567890
  sprintf(buffer,"TAG %3s %10s    %3s %10s %1d %2d",mesource,source_node.c_str(),medest,dest_node.c_str(), mode, num_other_nodes);
  String message(buffer);
  return message;
void Light(bool on) {
 int colors[] = {0x00FFFF,0x0000FF,0x008080,0x000080,0x0000CD,0x00BFFF,0x00FFFF,0x00CED1,0x40E0D0,0xFFFFFF,0xFF0000,0x00FF00,0xFFFF00,0xDC143C,0xFF1493,0xFFA500,0xFF4500,0xFF00FF};
  if (on) {
      Serial.println("Light:ON");
      digitalWrite(LED, ON);
      //pick color
      int index = random(0,ARRAY_SIZE(colors));
      fill_solid(leds, NUM_LEDS, CRGB(colors[index]));
       FastLED.show();
      FastLED.show();
      FastLED.show();
             FastLED.show();
      FastLED.show();
      FastLED.show();
      Serial.println("Light:OFF");
      digitalWrite(LED, OFF);
      FastLED.show();
void rainbow_wave(uint8_t thisSpeed, uint8_t deltaHue) {     // The fill_rainbow call doesn't support brightness levels.
// uint8_t thisHue = beatsin8(thisSpeed,0,255);                // A simple rainbow wave.
 uint8_t thisHue = beat8(thisSpeed,255);                     // A simple rainbow march.
 fill_rainbow(leds, NUM_LEDS, thisHue, deltaHue);            // Use FastLED's fill_rainbow routine.
} // rainbow_wave()
int splitString(String str,String delim) {
  // Split the string into substrings
  int StringCount=0;
  while (str.length() > 0)
    int index = str.indexOf(delim);
    if (index == -1) // No space found
      splits[StringCount++] = str;
      splits[StringCount++] = str.substring(0, index);
      str = str.substring(index+1);
  return StringCount;
> Blockquote
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\timoc\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\timoc\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\timoc\Documents\Arduino\libraries -fqbn=esp8266:esp8266:d1_mini:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3216,non32xfer=fast,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -ide-version=10819 -build-path C:\Users\timoc\AppData\Local\Temp\arduino_build_419005 -warnings=none -build-cache C:\Users\timoc\AppData\Local\Temp\arduino_cache_122700 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\timoc\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\timoc\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs.path=C:\Users\timoc\Documents\ArduinoData\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\timoc\Documents\ArduinoData\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs.path=C:\Users\timoc\Documents\ArduinoData\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\timoc\Documents\ArduinoData\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\timoc\Documents\ArduinoData\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\timoc\Documents\ArduinoData\packages\esp8266\tools\python3\3.7.2-post1 -verbose C:\Users\timoc\Documents\Arduino\simpleMesh6\simpleMesh6\simpleMesh6.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\timoc\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\timoc\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\timoc\Documents\Arduino\libraries -fqbn=esp8266:esp8266:d1_mini:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3216,non32xfer=fast,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -ide-version=10819 -build-path C:\Users\timoc\AppData\Local\Temp\arduino_build_419005 -warnings=none -build-cache C:\Users\timoc\AppData\Local\Temp\arduino_cache_122700 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\timoc\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\timoc\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs.path=C:\Users\timoc\Documents\ArduinoData\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\timoc\Documents\ArduinoData\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs.path=C:\Users\timoc\Documents\ArduinoData\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\timoc\Documents\ArduinoData\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\timoc\Documents\ArduinoData\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\timoc\Documents\ArduinoData\packages\esp8266\tools\python3\3.7.2-post1 -verbose C:\Users\timoc\Documents\Arduino\simpleMesh6\simpleMesh6\simpleMesh6.ino
Using board 'd1_mini' from platform in folder: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2
Using core 'esp8266' from platform in folder: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2
Detecting libraries used...
"C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\sketch\\simpleMesh6.ino.cpp" -o nul
Alternatives for painlessMesh.h: [Painless_Mesh@1.4.10]
ResolveLibrary(painlessMesh.h)
  -> candidates: [Painless_Mesh@1.4.10]
"C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\Painless_Mesh\\src" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\sketch\\simpleMesh6.ino.cpp" -o nul
Alternatives for TaskSchedulerDeclarations.h: [TaskScheduler@3.7.0]
ResolveLibrary(TaskSchedulerDeclarations.h)
  -> candidates: [TaskScheduler@3.7.0]
"C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\Painless_Mesh\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\TaskScheduler\\src" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\sketch\\simpleMesh6.ino.cpp" -o nul
Alternatives for ArduinoJson.h: [ArduinoJson@6.17.3]
ResolveLibrary(ArduinoJson.h)
  -> candidates: [ArduinoJson@6.17.3]
"C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\Painless_Mesh\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\TaskScheduler\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\sketch\\simpleMesh6.ino.cpp" -o nul
Alternatives for ESP8266WiFi.h: [ESP8266WiFi@1.0]
ResolveLibrary(ESP8266WiFi.h)
  -> candidates: [ESP8266WiFi@1.0]
"C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\Painless_Mesh\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\TaskScheduler\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\sketch\\simpleMesh6.ino.cpp" -o nul
Alternatives for ESPAsyncTCP.h: [ESPAsyncTCP-master@1.2.2]
ResolveLibrary(ESPAsyncTCP.h)
  -> candidates: [ESPAsyncTCP-master@1.2.2]
"C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\Painless_Mesh\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\TaskScheduler\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\ESPAsyncTCP-master\\src" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\sketch\\simpleMesh6.ino.cpp" -o nul
Alternatives for LittleFS.h: [LittleFS@0.1.0]
ResolveLibrary(LittleFS.h)
  -> candidates: [LittleFS@0.1.0]
"C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\Painless_Mesh\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\TaskScheduler\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\ESPAsyncTCP-master\\src" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\LittleFS\\src" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\sketch\\simpleMesh6.ino.cpp" -o nul
Alternatives for Bounce2.h: [Bounce2@2.71]
ResolveLibrary(Bounce2.h)
  -> candidates: [Bounce2@2.71]
"C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\Painless_Mesh\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\TaskScheduler\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\ESPAsyncTCP-master\\src" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\LittleFS\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\Bounce2\\src" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\sketch\\simpleMesh6.ino.cpp" -o nul
Alternatives for FastLED.h: [FastLED@3.5.0]
ResolveLibrary(FastLED.h)
  -> candidates: [FastLED@3.5.0]
"C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\Painless_Mesh\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\TaskScheduler\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\ESPAsyncTCP-master\\src" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\LittleFS\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\Bounce2\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\sketch\\simpleMesh6.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\Painless_Mesh\src\painlessMeshSTA.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\Painless_Mesh\src\scheduler.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\Painless_Mesh\src\wifi.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\BearSSLHelpers.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\CertStoreBearSSL.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFi.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiAP.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiGratuitous.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiSTA-WPS.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiSTA.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiScan.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\WiFiClient.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\WiFiClientSecureBearSSL.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\WiFiServer.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\WiFiServerSecureBearSSL.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\WiFiUdp.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\enable_wifi_at_boot_time.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\ESPAsyncTCP-master\src\AsyncPrinter.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\ESPAsyncTCP-master\src\ESPAsyncTCP.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\ESPAsyncTCP-master\src\ESPAsyncTCPbuffer.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\ESPAsyncTCP-master\src\SyncClient.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\ESPAsyncTCP-master\src\tcp_axtls.c
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\LittleFS\src\LittleFS.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\LittleFS\src\lfs.c
Using cached library dependencies for file: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\LittleFS\src\lfs_util.c
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\Bounce2\src\Bounce2.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\FastLED\src\FastLED.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\FastLED\src\bitswap.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\FastLED\src\colorpalettes.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\FastLED\src\colorutils.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\FastLED\src\hsv2rgb.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\FastLED\src\lib8tion.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\FastLED\src\noise.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\FastLED\src\platforms\esp\32\clockless_rmt_esp32.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\FastLED\src\platforms.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\FastLED\src\power_mgt.cpp
Using cached library dependencies for file: C:\Users\timoc\Documents\Arduino\libraries\FastLED\src\wiring.cpp
Generating function prototypes...
"C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\Painless_Mesh\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\TaskScheduler\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\ESPAsyncTCP-master\\src" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\LittleFS\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\Bounce2\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\sketch\\simpleMesh6.ino.cpp" -o "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/signing.py" --mode header --publickey "C:\\Users\\timoc\\Documents\\Arduino\\simpleMesh6\\simpleMesh6/public.key" --out "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/core/Updater_Signing.h"
"C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DIO -DESP8266 "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\Painless_Mesh\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\TaskScheduler\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\ArduinoJson\\src" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\ESPAsyncTCP-master\\src" "-IC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\LittleFS\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\Bounce2\\src" "-IC:\\Users\\timoc\\Documents\\Arduino\\libraries\\FastLED\\src" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\sketch\\simpleMesh6.ino.cpp" -o "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\sketch\\simpleMesh6.ino.cpp.o"
In file included from C:\Users\timoc\Documents\Arduino\libraries\FastLED\src/FastLED.h:67,
                 from C:\Users\timoc\Documents\Arduino\simpleMesh6\simpleMesh6\simpleMesh6.ino:26:
C:\Users\timoc\Documents\Arduino\libraries\FastLED\src/fastspi.h:145:23: note: '#pragma message: No hardware SPI pins defined.  All SPI access will default to bitbanged output'
  145 | #      pragma message "No hardware SPI pins defined.  All SPI access will default to bitbanged output"
Compiling libraries...
Compiling library "Painless_Mesh"
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\Painless_Mesh\scheduler.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\Painless_Mesh\painlessMeshSTA.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\Painless_Mesh\wifi.cpp.o
Compiling library "TaskScheduler"
Compiling library "ArduinoJson"
Compiling library "ESP8266WiFi"
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESP8266WiFi\BearSSLHelpers.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESP8266WiFi\ESP8266WiFiGratuitous.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESP8266WiFi\CertStoreBearSSL.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESP8266WiFi\ESP8266WiFiAP.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESP8266WiFi\ESP8266WiFiGeneric.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESP8266WiFi\ESP8266WiFiSTA.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESP8266WiFi\ESP8266WiFi.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESP8266WiFi\ESP8266WiFiMulti.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESP8266WiFi\ESP8266WiFiSTA-WPS.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESP8266WiFi\WiFiClient.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESP8266WiFi\ESP8266WiFiScan.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESP8266WiFi\WiFiClientSecureBearSSL.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESP8266WiFi\WiFiServerSecureBearSSL.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESP8266WiFi\WiFiUdp.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESP8266WiFi\enable_wifi_at_boot_time.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESP8266WiFi\WiFiServer.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESP8266WiFi\ESP8266WiFi.a
Compiling library "ESPAsyncTCP-master"
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESPAsyncTCP-master\tcp_axtls.c.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESPAsyncTCP-master\ESPAsyncTCPbuffer.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESPAsyncTCP-master\AsyncPrinter.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESPAsyncTCP-master\SyncClient.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\ESPAsyncTCP-master\ESPAsyncTCP.cpp.o
Compiling library "LittleFS"
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\LittleFS\lfs_util.c.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\LittleFS\lfs.c.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\LittleFS\LittleFS.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\LittleFS\LittleFS.a
Compiling library "Bounce2"
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\Bounce2\Bounce2.cpp.o
Compiling library "FastLED"
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\FastLED\lib8tion.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\FastLED\colorpalettes.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\FastLED\bitswap.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\FastLED\colorutils.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\FastLED\FastLED.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\FastLED\hsv2rgb.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\FastLED\platforms.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\FastLED\noise.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\FastLED\wiring.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\FastLED\power_mgt.cpp.o
Using previously compiled file: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\libraries\FastLED\platforms\esp\32\clockless_rmt_esp32.cpp.o
Compiling core...
Using precompiled core: C:\Users\timoc\AppData\Local\Temp\arduino_cache_122700\core\core_27717f0dca85655ceba999b7a2d636e3.a
Linking everything together...
"C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/mkdir.py" -p "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/ld_h/"
"C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/cp.py" "C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/ld/eagle.flash.4m2m.ld" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/ld_h/local.eagle.flash.ld.h"
"C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-gcc" -CC -E -P -DVTABLES_IN_FLASH -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/ld_h/local.eagle.flash.ld.h" -o "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/local.eagle.flash.ld"
"C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-gcc" -CC -E -P -DVTABLES_IN_FLASH -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x4000 -DMMU_SEC_HEAP=0x40108000 -DMMU_SEC_HEAP_SIZE=0x4000 "C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/ld/eagle.app.v6.common.ld.h" -o "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/local.eagle.app.v6.common.ld"
"C:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-gcc" -fno-exceptions -Wl,-Map "-Wl,C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/simpleMesh6.ino.map" -g -w -Werror=return-type -Os -nostdlib -Wl,--no-check-sections -u app_entry -u _printf_float -u _scanf_float -Wl,-static "-LC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lib" "-LC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lib/NONOSDK22x_190703" "-LC:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005" "-LC:\\Users\\timoc\\Documents\\ArduinoData\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/lib" -Tlocal.eagle.flash.ld -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,spi_flash_read -o "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005/simpleMesh6.ino.elf" -Wl,--start-group "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\sketch\\simpleMesh6.ino.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\Painless_Mesh\\painlessMeshSTA.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\Painless_Mesh\\scheduler.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\Painless_Mesh\\wifi.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\ESP8266WiFi\\ESP8266WiFi.a" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\ESPAsyncTCP-master\\tcp_axtls.c.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\ESPAsyncTCP-master\\AsyncPrinter.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\ESPAsyncTCP-master\\ESPAsyncTCP.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\ESPAsyncTCP-master\\ESPAsyncTCPbuffer.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\ESPAsyncTCP-master\\SyncClient.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\LittleFS\\LittleFS.a" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\Bounce2\\Bounce2.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\FastLED\\FastLED.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\FastLED\\bitswap.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\FastLED\\colorpalettes.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\FastLED\\colorutils.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\FastLED\\hsv2rgb.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\FastLED\\lib8tion.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\FastLED\\noise.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\FastLED\\platforms.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\FastLED\\power_mgt.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\FastLED\\wiring.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005\\libraries\\FastLED\\platforms\\esp\\32\\clockless_rmt_esp32.cpp.o" "C:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_cache_122700\\core\\core_27717f0dca85655ceba999b7a2d636e3.a" -lhal -lphy -lpp -lnet80211 -llwip2-536-feat -lwpa -lcrypto -lmain -lwps -lbearssl -lespnow -lsmartconfig -lairkiss -lwpa2 -lstdc++ -lm -lc -lgcc -Wl,--end-group "-LC:\\Users\\timoc\\AppData\\Local\\Temp\\arduino_build_419005"
c:/users/timoc/documents/arduinodata/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\sketch\simpleMesh6.ino.cpp.o: in function `_Z8tag_nodei':
C:\Users\timoc\Documents\Arduino\simpleMesh6\simpleMesh6/simpleMesh6.ino:318: undefined reference to `_Z8tag_nodev'
c:/users/timoc/documents/arduinodata/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\timoc\AppData\Local\Temp\arduino_build_419005\sketch\simpleMesh6.ino.cpp.o: in function `loop':
Using library Painless_Mesh at version 1.4.10 in folder: C:\Users\timoc\Documents\Arduino\libraries\Painless_Mesh
Using library TaskScheduler at version 3.7.0 in folder: C:\Users\timoc\Documents\Arduino\libraries\TaskScheduler
Using library ArduinoJson at version 6.17.3 in folder: C:\Users\timoc\Documents\Arduino\libraries\ArduinoJson
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi
Using library ESPAsyncTCP-master at version 1.2.2 in folder: C:\Users\timoc\Documents\Arduino\libraries\ESPAsyncTCP-master
Using library LittleFS at version 0.1.0 in folder: C:\Users\timoc\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\libraries\LittleFS
Using library Bounce2 at version 2.71 in folder: C:\Users\timoc\Documents\Arduino\libraries\Bounce2
Using library FastLED at version 3.5.0 in folder: C:\Users\timoc\Documents\Arduino\libraries\FastLED
exit status 1
Error compiling for board LOLIN(WEMOS) D1 R2 & mini.
Any suggestions?
In such a case I very carefully compare the earlier version with the later version, and scrutinize every single change.
If that doesn't identify the culprit, start over from the earlier version and introduce the changes one by one, making sure after each change that the result compiles without errors. The second time around is always faster.
Thanks for the quick response... i was already attempting what you suggested and found that I was inconsistent on a function call tag_node() I should have passed an integer...but sometimes i did not.
The error msg was so divorced from the issue but your recommendation was spot on...but once consistent it did compile !
The trick is that 'overloaded' functions (functions with the same name but different arguments) are given different names for linking purposes. The error message said that the linker could not find "_Z8tag_nodev". That would be a version of "tag_node". I looked at the code and saw that the prototype for tag_node() was:
void tag_node();
But down at the actual declaration it's:
That was enough to cause the error. You told the compiler that somewhere there was a void tag_node(void); so that's what it called but the linker couldn't find it because you only declared a void tag_node(int);
WOW, thanks for explaining that...it makes a LOT more sense... Really appreciate it !
