hello everyone !
i am trying to make a project which is the sunfounder sloth robot the photo here
but i didn't buy the kit i made it my self
instead of arduino nano i used arduino uno R3
but i used the same code which is this one
#include "VarSpeedServo.h" //include the VarSpeedServo library
#include <NewPing.h> //include the NewPing library
//#include <Servo.h>
VarSpeedServo RU; //Right Upper
VarSpeedServo RL; //Right Lower
VarSpeedServo LU; //Left Upper
VarSpeedServo LL; //Left Lower
NewPing sonar(4,3,200);
//vel(min), delay_Forward(max) = (5, 2000)
const int vel = 20, vel_Back = 10; //vel(mid), delay_Forward(mid) = (20, 750)
const int delay_Forward = 750, delay_Back = 1000; //vel(max), delay_Forward(min)= (256, 50)
//wonderful ---> (10, 700) (50, 500) (100, 100) (100, 300) (100, 500)
const int array_cal[4] = {90,90,90,90};
int RU_Degree = 0, LU_Degree = array_cal[2] + 5;
const int num1 = 6;
const int array_forward[num1][4] =
{0,-40,0,-20},
{30,-40,30,-20},
{30,0,30,0},
{0,20,0,40},
{-30,20,-30,40},
{-30,0,-30,0},
const int num2 = 5;
const int array_turn[num2][4] =
{-40,0,-20,0},
{-40,30,-20,30},
{0,30,0,30},
{30,0,30,0},
{0,0,0,0},
//#define INSTALL
//#define CALIBRATION
#define RUN
void Servo_Init()
RU.attach(9); // Connect the signal wire of the upper-right servo to pin 9
RL.attach(10); // Connect the signal wire of the lower-right servo to pin 10
LU.attach(11); // Connect the signal wire of the upper-left servo to pin 11
LL.attach(12); // Connect the signal wire of the lower-left servo to pin 12
void Adjust() // Avoid the servo's fast spinning in initialization
{ // RU,LU goes from array_cal[0] - 5 ,array_cal[2] + 5 degrees to array_cal[0],array_cal[2] degrees
for(RU_Degree = array_cal[0] - 5; RU_Degree <= array_cal[0]; RU_Degree += 1) {
RU.write(RU_Degree); // in steps of 1 degree
LU.write(LU_Degree--); // tell servo to go to RU_Degreeition, LU_Degreeition in variable 'RU_Degree', 'LU_Degree'
delay(15); // waits 15ms for the servo to reach the RU_Degreeition
bool TooClose()
int tooclose = 0;
for(int a=0; a<5; a++) {
delay(50);
int din = sonar.ping_in();
if (din < 7 && din > 0) tooclose++;
if (tooclose < 5) return 1;
return 0;
void Forward()
for(int x=0; x<num1; x++) {
RU.slowmove (array_cal[0] + array_forward[x][0] , vel);
RL.slowmove (array_cal[1] + array_forward[x][1] , vel);
LU.slowmove (array_cal[2] + array_forward[x][2] , vel);
LL.slowmove (array_cal[3] + array_forward[x][3] , vel);
delay(delay_Forward);
void Backward()
for(int z=0; z<4; z++) {
for(int y=0; y<num2; y++) {
RU.slowmove (array_cal[0] + array_turn[y][0] , vel_Back);
RL.slowmove (array_cal[1] + array_turn[y][1] , vel_Back);
LU.slowmove (array_cal[2] + array_turn[y][2] , vel_Back);
LL.slowmove (array_cal[3] + array_turn[y][3] , vel_Back);
delay(delay_Back);
#ifdef INSTALL
Servo_Init();
RU.slowmove (90 , vel);
RL.slowmove (90 , vel);
LU.slowmove (90 , vel);
LL.slowmove (90 , vel);
while(1);
#endif
#ifdef CALIBRATION
Servo_Init();
Adjust();
RL.slowmove (array_cal[1] , vel);
LL.slowmove (array_cal[3] , vel);
delay(2000);
while(1);
#endif
#ifdef RUN
Servo_Init();
Adjust();
delay(2000);
#endif
while(TooClose()) Forward();
Backward();
but when i upload the code the robot start doing crazy mouvements
which do not look like walking at all
if there is something wrong in the code or something can't work with arduino uno please tall me
thanks for any help !
