#include <SD.h>
#include <SPI.h>
// debug output at 9600 baud
// setup SD-card
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println(" failed!");
while(true);
Serial.println(" done.");
// hi-speed SPI transfers
// 44100kHz stereo => 88200 sample rate
// 100 mSec of prebuffering.
Audio.begin(88200, 100);
int count = 0;
// open wave file from sdcard
File myFile = SD.open("Yam.wav");
if (!myFile) {
// if the file didn't open, print an error and stop
Serial.println("error opening Yam.wav");
while (true);
const int S = 1024; // Number of samples to read in block
short buffer~~;~~
~~ Serial.print("Playing");~~
~~ // until the file is not finished~~
~~ while (myFile.available()) {~~
~~ // read from the file into buffer~~
~~ myFile.read(buffer, sizeof(buffer));~~
~~ // Prepare samples~~
~~ int volume = 1024;~~
~~ ; Audio.prepare(buffer, S, volume);~~
~~ // Feed samples to audio~~
~~ Audio.write(buffer, S);~~
~~ // Every 100 block print a '.'~~
~~ count++;~~
~~ if (count == 100) {~~
~~ Serial.print(".");~~
~~ count = 0;~~
~~ myFile.close();~~
~~ Serial.println("End of file. Thank you for listening!");~~
~~ while (true) ;~~
