I need help my project says expected initializer before 'currentStateCLK' on my code
// Include the Servo Library
#include <Servo.h>
// Rotary Encoder Inputs
#define inputCLK 4
#define inputDT 5
// Create a Servo object
Servo myservo;
int counter = 0;
int currentStateCLK;
int previousStateCLK;
// Set encoder pins as inputs
pinMode (inputCLK,INPUT);
pinMode (inputDT,INPUT);
// Setup Serial Monitor
Serial.begin (9600);
// Attach servo on pin 9 to the servo object
myservo.attach(9);
// Read the initial state of inputCLK
// Assign to previousStateCLK variable
previousStateCLK = digitalRead(inputCLK);
// Read the current state of inputCLK
currentStateCLK; = digitalRead(inputCLK);
// If the previous and the current state of the inputCLK are different then a pulse has occured
if (currentStateCLK != previousStateCLK){
// If the inputDT state is different than the inputCLK state then
// the encoder is rotating counterclockwise
if (digitalRead(inputDT) != currentStateCLK) {
counter --;
if (counter<0){
counter=0;
// Encoder is rotating clockwise
counter ++;
if (counter>180){
counter=180;
// Move the servo
myservo.write(counter);
Serial.print("Position: ");
Serial.println(counter);
// Update previousStateCLK with the current state
previousStateCLK = currentStateCLK;
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
