I need help on door look code
i want to add more tags on my arduino i me can addd on
byte masterCard[cardSize] = {51,135,225,145}; //Change Master Card ID
more tags?
Hello ronaz
Welcome to the worldbest forum.
We need some additional information.
Post your sketch, well formated, with well-tempered comments and in so called code tags "< code >" and schematic to see how we can help.
//RFID Based Solenoid Door lock using Arduino
//The IoT Projects https://www.youtube.com/c/TheIoTProjects
//website:https://iotprojectsideas.com/
//RFID RC522 Master Card, Add and Remove multiple Cards
#include <SPI.h>
#include <Wire.h>
#include <MFRC522.h>
#define RST_PIN 9
#define SS_PIN  10
#define STATE_STARTUP       0
#define STATE_STARTING      1
#define STATE_WAITING       2
#define STATE_SCAN_INVALID  3
#define STATE_SCAN_VALID    4
#define STATE_SCAN_MASTER   5
#define STATE_ADDED_CARD    6
#define STATE_REMOVED_CARD  7
#define REDPIN 3
#define BLUEPIN 3
#define Relay 3
const int cardArrSize = 10;
const int cardSize    = 4;
byte cardArr[cardArrSize][cardSize];
byte readCard[cardSize];
byte cardsStored = 0;
// Create MFRC522 instance
MFRC522 mfrc522(SS_PIN, RST_PIN);
// Set the LCD I2C address
byte currentState = STATE_STARTUP;
unsigned long LastStateChangeTime;
unsigned long StateWaitTime;
int readCardState()
  int index;
  Serial.print("Card Data - ");
  for(index = 0; index < 4; index++)
    readCard[index] = mfrc522.uid.uidByte[index];
    Serial.print(readCard[index]);
    if (index < 3)
      Serial.print(",");
  Serial.println(" ");
  //Check Master Card
  if ((memcmp(readCard, masterCard, 4)) == 0)
    return STATE_SCAN_MASTER;
  if (cardsStored == 0)
    return STATE_SCAN_INVALID;
  for(index = 0; index < cardsStored; index++)
    if ((memcmp(readCard, cardArr[index], 4)) == 0)
      return STATE_SCAN_VALID;
void addReadCard()
  int cardIndex;
  int index;
  if (cardsStored <= 20)
    cardsStored++;
    cardIndex = cardsStored;
    cardIndex--;
    cardArr[cardIndex][index] = readCard[index];
void removeReadCard()
  int cardIndex;
  int index;
  boolean found = false;
  for(cardIndex = 0; cardIndex < cardsStored; cardIndex++)
    if (found == true)
        cardArr[cardIndex-1][index] = cardArr[cardIndex][index];
        cardArr[cardIndex][index] = 0;
    if ((memcmp(readCard, cardArr[cardIndex], 4)) == 0)
      found = true;
  if (found == true)
    cardsStored--;
void updateState(byte aState)
  if (aState == currentState)
    return;
  // do state change
  switch (aState)
    case STATE_STARTING:
      StateWaitTime = 1000;
      digitalWrite(REDPIN, HIGH);
      digitalWrite(BLUEPIN, LOW);
    case STATE_WAITING:
      StateWaitTime = 0;
      digitalWrite(REDPIN, LOW);
    case STATE_SCAN_INVALID:
      if (currentState == STATE_SCAN_MASTER)
        addReadCard();
        aState = STATE_ADDED_CARD;
        StateWaitTime = 2000;
        digitalWrite(BLUEPIN, HIGH);
      else if (currentState == STATE_REMOVED_CARD)
        return;
    case STATE_SCAN_VALID:
        removeReadCard();
        aState = STATE_REMOVED_CARD;
      else if (currentState == STATE_ADDED_CARD)
        return;
        digitalWrite(Relay,LOW);
        delay(3000);
        digitalWrite(Relay,HIGH);
    case STATE_SCAN_MASTER:
      StateWaitTime = 5000;
  currentState = aState;
  LastStateChangeTime = millis();
  SPI.begin();         // Init SPI Bus
  mfrc522.PCD_Init();  // Init MFRC522
  updateState(STATE_STARTING);
  pinMode(REDPIN, OUTPUT);
  pinMode(BLUEPIN, OUTPUT);
  pinMode(Relay, OUTPUT);
  byte cardState;
  if ((currentState != STATE_WAITING) &&
      (StateWaitTime > 0) &&
      (LastStateChangeTime + StateWaitTime < millis()))
    updateState(STATE_WAITING);
  // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent())
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial())
    return;
  cardState = readCardState();
  updateState(cardState);
what i need it i want to add ore cards to my codes thanks
Increase that constant.
