Question is I send (HEX)1B from PC serial tool , the arduino receive (HEX)72 ?
I try serial1 to receive HEX from PC, the result is the same. send (HEX)1B, arduino receive (HEX)72.
q164129345:
I tried serial1 and the result is the same. >_<
And what makes you hope that SoftwareSerial works better than HardwareSerial?
The number of connections on your claimed USB-TTL converter makes me believe it's a USB to RS-232 Adapter,
hopefully using TTL-Level (RS-232 has -12V for HIGH and +12V for LOW).
Whandall:
Dear Whandall:
I saw a lot of engineer use SoftwareSerial to communication successful. However, I tried SoftwareSerial and HardwareSerial , the result is the same.
it's USB to (RS232)UART converter. Are you questioning my hardware? it mean my code is no problem??
Whandall:
Dear Whandall:
Thank you for your help. Thank you so much.
I think I found the problem. You are right. My problem is I don't understand the difference between RS-232(RX,TX) and TTL(RX,TX). I need to study ,haha..
This morning, I tried to use another IC(CAN transform TTL) to test the code and circuit again . It's work. arduino micro got (HEX)1B.
