I need help with mega to arduino cloud communication
I have a variable in arduino IDE called "count" and it updates every time it passes through two ir sensors basically a bidirectional visitor counter and I want that data to send it to a dashboard in arduino cloud that updates the value of a gauge widget to display the count of visitors in a room.
Arduino IDE Code:
/* ========= PINS ========= */
#define IR_IN      22
#define IR_OUT     9
#define PIR_PIN    4
#define LIGHT_PIN  2
#define AC_PIN     3
enum State { IDLE, IN_FIRST, OUT_FIRST };
State state = IDLE;
int count = 0;
unsigned long stateTime = 0;
const unsigned long TIMEOUT = 800;
/* ===== MANUAL OVERRIDE ===== */
bool manualOverride = false;   // true = MANUAL, false = AUTO
bool manualLightState = LOW;
bool manualACState = LOW;
int lastSentCount = -1;       // For sending count only if changed
bool lastLight = LOW;
bool lastAC = LOW;
bool lastMode = false;
  pinMode(IR_IN, INPUT_PULLUP);
  pinMode(IR_OUT, INPUT_PULLUP);
  pinMode(PIR_PIN, INPUT);
  pinMode(LIGHT_PIN, OUTPUT);
  pinMode(AC_PIN, OUTPUT);
  Serial.begin(9600);   // Debug
  Serial1.begin(9600);  // ESP32 communication
/* ===== SEND VISITOR COUNT ===== */
void sendCount() {
  if (count != lastSentCount) {
    Serial1.print("COUNT:");
    Serial1.println(count);
    lastSentCount = count;
/* ===== SEND STATUS ===== */
void sendStatus() {
  bool currLight = digitalRead(LIGHT_PIN);
  bool currAC = digitalRead(AC_PIN);
  bool currMode = !manualOverride;
  if (currLight != lastLight || currAC != lastAC || currMode != lastMode) {
    Serial1.print("STATUS:");
    Serial1.print(currLight);
    Serial1.print(",");
    Serial1.print(currAC);
    Serial1.print(",");
    Serial1.println(currMode); // 1=AUTO, 0=MANUAL
    lastLight = currLight;
    lastAC = currAC;
    lastMode = currMode;
    Serial.println("SENT");
/* ===== IR VISITOR LOGIC ===== */
void handleIR() {
  bool inBlocked  = digitalRead(IR_IN)  == LOW;
  bool outBlocked = digitalRead(IR_OUT) == LOW;
  switch (state) {
    case IDLE:
      if (inBlocked && !outBlocked) { state = IN_FIRST; stateTime = millis(); }
      else if (outBlocked && !inBlocked) { state = OUT_FIRST; stateTime = millis(); }
    case IN_FIRST:
        count++;
        state = IDLE;
        sendCount();
      else if (millis() - stateTime > TIMEOUT) state = IDLE;
    case OUT_FIRST:
        if (count > 0) count--;
        state = IDLE;
        sendCount();
  handleIR();
  Serial.println(count);
  /* ===== RECEIVE COMMANDS FROM ESP32 ===== */
  if (Serial1.available()) {
    String cmd = Serial1.readStringUntil('\n');
    cmd.trim();
    if (cmd == "AUTO_MODE") {
    else if (cmd == "MANUAL_MODE") {
      manualOverride = true;
    else if (cmd == "LIGHT_ON") {
      manualLightState = HIGH;
    else if (cmd == "LIGHT_OFF") {
    else if (cmd == "AC_ON") {
      manualACState = HIGH;
    else if (cmd == "AC_OFF") {
    else if (cmd.startsWith("SET:")) {
      count = cmd.substring(4).toInt();
      manualOverride = false; // switch to AUTO after manual set
      sendCount();
  /* ===== OUTPUT CONTROL ===== */
  if (manualOverride) {
    digitalWrite(LIGHT_PIN, manualLightState);
    digitalWrite(AC_PIN, manualACState);
  else {
    if (count > 0) {
      digitalWrite(LIGHT_PIN, HIGH);
      digitalWrite(AC_PIN, HIGH);
    else {
      digitalWrite(LIGHT_PIN, LOW);
      analogWrite(AC_PIN, 50); // low AC power when no visitors
  // Send updated status if any changes
  sendStatus();
Arduino Cloud code:
#include "thingProperties.h"
// Mega connection pins
#define MEGA_RX 16
#define MEGA_TX 17
unsigned long lockUntil = 0; // Prevent overwrite during manual set
  Serial2.begin(9600, SERIAL_8N1, MEGA_RX, MEGA_TX); // Mega hardware serial
  delay(1500);  // Allow Serial to stabilize
  // Cloud setup
  initProperties();
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  // Keep Cloud updated
  ArduinoCloud.update();
  // Read incoming data from Mega
  if (millis() > lockUntil && Serial2.available()) {
    String msg = Serial2.readStringUntil('\n');
    msg.trim();
    Serial.println(msg);
    // === Visitor Count ===
    if (msg.startsWith("COUNT:")) {
      int receivedCount = msg.substring(6).toInt();
      if (visitorCount != receivedCount) {
        visitorCount = receivedCount; // This triggers Gauge update
    // === Status of lights/AC and mode ===
    else if (msg.startsWith("STATUS:")) {
      int c1 = msg.indexOf(',');
      int c2 = msg.indexOf(',', c1 + 1);
      light   = msg.substring(7, c1).toInt();
      aircon  = msg.substring(c1 + 1, c2).toInt();
      autoMode = msg.substring(c2 + 1).toInt(); // 1 = AUTO, 0 = MANUAL
/* ===== CLOUD CALLBACKS ===== */
// Stepper to manually set visitor count
void onVisitorSetChange() {
  Serial2.print("SET:");
  Serial2.println(visitorSet);
  lockUntil = millis() + 2000; // prevent instant overwrite from Mega
// AUTO / MANUAL toggle
void onAutoModeChange() {
  Serial2.println(autoMode ? "AUTO_MODE" : "MANUAL_MODE");
// Manual light control (only works in MANUAL mode)
void onLightChange() {
  if (!autoMode)
    Serial2.println(light ? "LIGHT_ON" : "LIGHT_OFF");
// Manual AC control (only works in MANUAL mode)
void onAirconChange() {
  if (!autoMode)
    Serial2.print
ln(aircon ? "AC_ON" : "AC_OFF");
thingsProperties.h:
// Code generated by Arduino IoT Cloud, DO NOT EDIT.
#include <ArduinoIoTCloud.h>
#include <Arduino_ConnectionHandler.h>
const char DEVICE_LOGIN_NAME[]  = "d1447613-5ba5-4a3e-99bf-d98e4975e5d2";
const char SSID[]               = SECRET_SSID;    // Network SSID (name)
const char PASS[]               = SECRET_OPTIONAL_PASS;    // Network password (use for WPA, or use as key for WEP)
const char DEVICE_KEY[]  = SECRET_DEVICE_KEY;    // Secret device password
void onVisitorSetChange();
void onAirconChange();
void onAutoModeChange();
void onLightChange();
int visitorCount;
int visitorSet;
bool aircon;
bool autoMode;
bool light;
void initProperties(){
  ArduinoCloud.setBoardId(DEVICE_LOGIN_NAME);
  ArduinoCloud.setSecretDeviceKey(DEVICE_KEY);
  ArduinoCloud.addProperty(visitorCount, READ, ON_CHANGE, NULL);
  ArduinoCloud.addProperty(visitorSet, READWRITE, ON_CHANGE, onVisitorSetChange);
  ArduinoCloud.addProperty(aircon, READWRITE, ON_CHANGE, onAirconChange);
  ArduinoCloud.addProperty(autoMode, READWRITE, ON_CHANGE, onAutoModeChange);
  ArduinoCloud.addProperty(light, READWRITE, ON_CHANGE, onLightChange);
WiFiConnectionHandler ArduinoIoTPreferredConnection(SSID, PASS);
I understand you want to send a visitor counter to the Arduino Cloud dashboard... Does it not work? Describe what it does in this state.
