Hello everyone. I need help with the codes. There are two engines in my boat. I check these with two separate drivers (BTS7960). I use two driving modes on my boat and replace these driving modes with the switch connected to the controller. In the first driving mode, I control the direction of the two motors with the right joystick. no problem in this section, it works fine. In the second driving mode, I wrote code to control an engine with the left and right joystick. However, with the right and left joysticks, I cannot control the right and left motors at the same time. Can you help with the code?
Part of the code that may be wrong.
//ARDUİNO MEGA 2560
if (leftswitch == HIGH) {
//LEFTSWİTCH OPEN, SECOND DRIVING MODE ACTIVE.
// TWO JOYSTİC DRIVING MODE
if (yAxis < 495) {
//RIGHT MOTOR BACKWARD
rightbackward = map(yAxis, 495, 0, 0, 255);
else if (xAxis < 495) {
//LEFT MOTOR BACKWARD
leftbackward = map(xAxis, 495, 0, 0, 255);
else if (yAxis > 520) {
//RİGHT MOTOR FORWARD
rightforward = map(yAxis, 520, 1023, 0, 255);
else if (xAxis > 520) {
//LEFT MOTOR FORWARD
leftforward = map(xAxis, 520, 1023, 0, 255);
else {
leftforward = 0;
leftbackward = 0;
rightforward = 0;
rightbackward = 0;
//MOTOR NOİSE REDUCTİON
if (leftforward < 10) {
leftforward = 0;
if (leftbackward < 10) {
leftbackward = 0;
if (rightforward < 10) {
rightforward = 0;
if (rightbackward < 10) {
rightbackward = 0;
analogWrite(left_Lpwm, leftforward);
analogWrite(left_Rpwm, leftbackward);
analogWrite(right_Rpwm, rightforward);
analogWrite(right_Lpwm, rightbackward)
This is the code I used on my boat.
//FISH BAİT BOAT WITH TWO DRIVING MODES
// ARDUİNO MEGA 2560
#include <nRF24L01.h>
#include <printf.h>
#include <RF24.h>
#include <RF24_config.h>
#include <Servo.h>
Servo myservo;
#define CE_PIN 9
#define CSN_PIN 53
const uint64_t pipe = 0xE8E8F0F0E1LL;
#define left_Lpwm 2 //left motor LPWM
#define left_Rpwm 3 //Left motor RPWM
#define right_Lpwm 4 //Right motor LPWM
#define right_Rpwm 5 // Right motor LPWM
RF24 radio(CE_PIN, CSN_PIN);
int joystick[10];
int leftforward = 0;
int leftbackward = 0;
int rightforward = 0;
int rightbackward = 0;
int xAxis, yAxis, zAxis, z0Axis;
int butonright;
int butonleft;
int leftswitch;
myservo.attach(6);
pinMode(left_Lpwm, OUTPUT);
pinMode(left_Rpwm, OUTPUT);
pinMode(right_Lpwm, OUTPUT);
pinMode(right_Rpwm, OUTPUT);
radio.begin();
radio.openReadingPipe(1, pipe);
radio.startListening();
if ( radio.available() )
radio.read( joystick, sizeof(joystick) );
xAxis = joystick[0];
yAxis = joystick[1];
zAxis = joystick[2];
z0Axis = joystick[3];
int butonright = joystick[4];
int butonleft = joystick[5];
int leftswitch = joystick[6];
if (butonleft == HIGH) {
myservo.write(25); //Bait Release
else if (butonright == HIGH) {
myservo.write(170); //Bait Release
else {
myservo.write(90);
if (leftswitch == LOW) {
// FIRST DRIVE MODE ACTIVE
// TWO MOTOR CONTROL WITH RIGHT JOISTIC Y AND Z AXİS
if (yAxis < 495) {
//TWO MOTOR BACKWARD
leftbackward = map(yAxis, 495, 0, 0, 255);
//TWO MOTOR FORWARD
leftforward = map(yAxis, 520, 1023, 0, 255);
else {
leftforward = 0;
leftbackward = 0;
rightforward = 0;
rightbackward = 0;
if (zAxis < 495) {
//TURN LEFT
int xMapped = map(zAxis, 495, 0, 0, 255);
leftforward = leftforward - xMapped;
rightforward = rightforward + xMapped;
if (leftforward < 0) {
leftforward = 0;
if (rightforward > 255) {
rightforward = 255;
if (zAxis > 520) {
//TURN RİGHT
int xMapped = map(zAxis, 520, 1023, 0, 255);
leftforward = leftforward + xMapped;
rightforward = rightforward - xMapped;
if (leftforward > 255) {
leftforward = 255;
if (rightforward < 0) {
rightforward = 0;
if (yAxis < 495) {
else {
leftforward = 0;
leftbackward = 0;
rightforward = 0;
rightbackward = 0;
leftforward = 0;
leftbackward = 0;
rightforward = 0;
rightbackward = 0;
analogWrite(right_Lpwm, rightbackward);
Serial.print("X = ");
Serial.print(xAxis);
Serial.print(" Y = ");
Serial.print(yAxis);
Serial.print(" Z = ");
Serial.print(zAxis);
Serial.print(" Z0 = ");
Serial.print(z0Axis);
Serial.print(" BUTON RIGHT = ");
Serial.print(joystick[4]);
Serial.print(" BUTON LEFT = ");
Serial.print(joystick[5]);
Serial.print(" LEFT SWİTCH = ");
Serial.println(joystick[6]);
