I need help with storing data in EEPROM
I am a beginner with Arduino and need help storing fingerprint IDs in one address without overriding the previous data. I will be hoping to bed now since its late
Full Code:
#include <Adafruit_Fingerprint.h>
#include <EEPROM.h>
#include "OneButton.h"
LiquidCrystal_I2C lcd(0x27, 16, 2);
SoftwareSerial fingerSerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&fingerSerial);
OneButton pushButton = OneButton(A3, true, true);
int count = 1;
bool regMode = false;
uint8_t id;
void (*resetFunc)(void) = 0;
  // Initialize the modules
  // Initialize the lcd
  lcd.init();
  lcd.backlight();
  displayText(false, 0, 0, F("Initializing"));
  displayText(false, 0, 1, F("Data"));
  // Initialize the fingeprint if not found then reset the arduino
  while (!Serial) {
    ;  // wait for serial port to connect. Needed for native USB port only
  finger.begin(57600);
  if (finger.verifyPassword()) {
    displayText(true, 0, 0, F("Fingerprint"));
    displayText(false, 1000, 1, F("Initialize"));
    displayText(false, 1000, 1, F("Not Initialize"));
    displayText(false, 0, 0, F("Rebooting"));
    displayText(false, 1000, 1, F("System"));
    resetFunc();
    while (1) { delay(1); }
  finger.getTemplateCount();
  if (finger.templateCount == 0) {
    displayText(true, 0, 0, F("No Finger"));
    displayText(false, 2000, 1, F("Enrolled"));
    displayText(true, 0, 0, String(finger.templateCount) + F(" Finger"));
  displayText(true, 0, 0, F("Attendance"));
  displayText(false, 0, 1, F("System"));
  // Button Events
  pushButton.attachClick(onSingleClick);
  pushButton.attachDoubleClick(onDoubleClick);
  pushButton.attachMultiClick(onMultiClick);
  int result = getFingerprintIDez();
  if (result > 0) {
    displayText(false, 1000, 1, F("Enrolled"));
    return;
  } else if (result == -2) {
    displayText(false, 1000, 1, F("Not Enrolled"));
  pushButton.tick();
void writeStringEEPROM(int address, String str) {
  byte len = str.length();
  EEPROM.write(address, len);
  for (int i = 0; i < len; i++) {
    EEPROM.write(address + 1 + i, str[i]);
String readStringEEPROM(int address) {
  int len = EEPROM.read(address);
  char data[len + 1];
    data[i] = EEPROM.read(address + 1 + i);
  data[len] = '\0';
  return String(data);
void incrementID() {
  if (regMode) {
    count++;
    if (count > 127) {
      count = 1;
void decrementID() {
  if (regMode) {
    count--;
    if (count < 1) {
      count = 1;
void centerText(int row, String text) {
  int totalColumns = 16;
  int textLength = text.length();
  int startingColumn = (totalColumns - textLength) / 2;
  lcd.setCursor(startingColumn, row);
  lcd.print(text);
void displayText(bool clearScreen, int duration, int row, String text) {
  if (clearScreen) {
    lcd.clear();
  centerText(row, text);
  if (duration != 0) {
    delay(duration);
    lcd.clear();
void enroll() {
  regMode = true;
  displayText(true, 0, 0, F("Enter your ID:"));
  while (regMode) {
    displayText(false, 0, 1, String(count));
    pushButton.tick();
void confirm() {
  id = count;
  String result = readStringEEPROM(1);
  if (result.length() > 0 && result == String(count)) {
    displayText(true, 0, 0, F("ID Already"));
    displayText(false, 2000, 1, F("Registered!"));
    regMode = false;
    home();
    getFingerprintEnroll();
    regMode = false;
  return;
void home() {
  regMode = false;
  count = 1;
void onSingleClick() {
  incrementID();
void onDoubleClick() {
  decrementID();
void onMultiClick() {
  int n = pushButton.getNumberClicks();
  if (n == 3 && regMode) {
    // Set back to home
    home();
  else if (n == 4 && !regMode) {
    // Set to regMode
    enroll();
  else if (n == 5 && regMode) {
    // Enroll the user
    confirm();
  else if (n == 10) {
    displayText(true, 0, 0, F("Rebooting"));
    displayText(false, 2000, 1, F("System"));
    resetFunc();
uint8_t getFingerprintEnroll() {
  int p = -1;
  String flashString = F("Your ID: ");
  String idString = String(id);
  String combinedString = flashString + idString;
  displayText(true, 1000, 0, combinedString);
  displayText(false, 0, 0, F("Place your"));
  displayText(false, 2000, 1, F("finger"));
  while (p != FINGERPRINT_OK) {
    p = finger.getImage();
    switch (p) {
      case FINGERPRINT_OK:
        displayText(true, 0, 0, F("Image taken"));
      case FINGERPRINT_NOFINGER:
        displayText(false, 0, 1, F("Found"));
      case FINGERPRINT_PACKETRECIEVEERR:
        displayText(true, 0, 0, F("Communication"));
        displayText(false, 0, 1, F("Error"));
      case FINGERPRINT_IMAGEFAIL:
        displayText(true, 0, 0, F("Imaging"));
      default:
        displayText(true, 0, 0, F("Unknown"));
  // OK success!
  p = finger.image2Tz(1);
  switch (p) {
      displayText(true, 0, 0, F("Image"));
      displayText(false, 0, 1, F("Converted"));
    case FINGERPRINT_IMAGEMESS:
      displayText(false, 0, 1, F("Too Messy"));
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      displayText(true, 0, 0, F("Feature"));
      displayText(false, 0, 1, F("Not Found"));
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  displayText(true, 0, 0, F("Remove your"));
  p = 0;
  while (p != FINGERPRINT_NOFINGER) {
  p = -1;
  displayText(true, 0, 0, F("Place your"));
  displayText(false, 0, 1, F("Finger Again"));
    switch (p) {
        Serial.println(F("Image taken"));
        Serial.print(F("."));
        Serial.println(F("Communication error"));
        Serial.println(F("Imaging error"));
      default:
        Serial.println(F("Unknown error"));
        return;
  // OK success!
  p = finger.image2Tz(2);
  switch (p) {
      Serial.println(F("Image converted"));
      Serial.println(F("Image too messy"));
      return p;
      return p;
      Serial.println(F("Could not find fingerprint features"));
      return p;
      return p;
    default:
      return p;
  // OK converted!
  Serial.print(F("Creating model for #"));
  Serial.println(id);
  p = finger.createModel();
  if (p == FINGERPRINT_OK) {
    Serial.println(F("Prints matched!"));
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_ENROLLMISMATCH) {
    Serial.println(F("Fingerprints did not match"));
    return p;
    return p;
  Serial.print(F("ID "));
  Serial.println(id);
  p = finger.storeModel(id);
    writeStringEEPROM(1, String(id));
    displayText(true, 0, 0, F("Your Fingerprint"));
    displayText(false, 2000, 1, F("ID is Stored"));
    id = 1;
    count = 1;
    displayText(false, 0, 0, F("Registering"));
    displayText(false, 1000, 1, F("Data"));
    resetFunc();
    return p;
  } else if (p == FINGERPRINT_BADLOCATION) {
    Serial.println(F("Could not store in that location"));
    return p;
  } else if (p == FINGERPRINT_FLASHERR) {
    Serial.println(F("Error writing to flash"));
    return p;
    return p;
uint8_t getimg_data[] = { FINGERPRINT_GETIMAGE };
#define FINGERPRINT_COMMANDPACKET 0x1  //!< Command packet
Adafruit_Fingerprint_Packet packet(FINGERPRINT_COMMANDPACKET, sizeof(getimg_data), getimg_data);
const Adafruit_Fingerprint_Packet startPacket(FINGERPRINT_COMMANDPACKET, sizeof(getimg_data), getimg_data);
bool is_waiting_for_response = false;
int better_get_image() {
  // Serial.println("Get better image()");
  if (!is_waiting_for_response) {
    packet = startPacket;
    finger.writeStructuredPacket(packet);
    is_waiting_for_response = true;
    // Serial.println("Send command packet");
    return -2;  // nothing yet! :)
    /* check if there is any serial data at all */
    if (fingerSerial.available() == 0) {
      /* FAST EXIT TO MAKE BUTTON WORK */
      return -2;
    // Serial.println("Got response");
    // we definitely have some amount of data now, read it
    if (finger.getStructuredPacket(&packet) != FINGERPRINT_OK) {
      return FINGERPRINT_PACKETRECIEVEERR;
    // we have received something, so evaluate the result in all cases
    if (packet.type != FINGERPRINT_ACKPACKET)
    return packet.data[0];
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
  uint8_t p = better_get_image();
  if (p != FINGERPRINT_OK) return -1;
  p = finger.image2Tz();
  p = finger.fingerFastSearch();
    return finger.fingerID;
  } else if (p == FINGERPRINT_NOTFOUND) {
    return -2;
    return -1;
Use EEPROM.put() and EEPROM.get() rather than EEPROM.write() and EEPROM.read().
See https://docs.arduino.cc/learn/programming/eeprom-guide/
