Hello everyone!
I need to store sensor data in on-board memory. Data should be available even if the power is not available. This data will be retrieved later through bluetooth. Do microcontrollers have such type of memory or some other component is required? Please share your ideas.
At the moment, I am just planning and gathering info so no Arduino Board. I need to collect acceleration using 3-axis accelerometer. Reading frequency may be expected twice per second. So the storage should be sufficient to hold data for at least 3 hours.
Have you calculated how much storage you will need for that? 3 hours * 60 minutes * 60 seconds * 2 equals roughly 21000 readings. Times 3 values per reading times N (4?) bytes for each value.
I suggest that you store in external memory as mentioned in my previous post. SD will probably be the easiest.
