Here is my node server for Arduino to connect to:
var port = process.env.PORT||3000
const http = require('http')
const app = require('./app')
const cors = require('cors');
let message = ''
const server = http.createServer(app)
const io = require('socket.io')(server)
server.listen(port,()=>{
console.log("server run on ", port)
io.on("connection",(socket)=>{
console.log(socket.id)
socket.on('message', data =>{
// console.log(data)
socket.broadcast.emit('message',data)
socket.on('open light',data=>{
socket.broadcast.emit('open_light',data)
console.log(data)
socket.on('disconnect',()=>{
console.log("Client disconnect")
Here is the code for ESP8266 for connect to the node server:
#include <SocketIoClient.h>
#include<ESP8266WiFi.h>
#include<Arduino.h>
#define USER_SERIAL Serial
SocketIoClient socket;
const char* ssid = "bunvath_guest";
const char* pass = "*********";
pinMode(2, OUTPUT);
USER_SERIAL.begin(115200);
searchWifi();
initWiFi();
socket.on("message", handleMessage);
socket.on("light_on",handleMessage);
socket.emit("message","hello from esp");
socket.begin("192.168.0.102",3000);
digitalWrite(2,LOW);
digitalWrite(2,HIGH);
socket.loop();
void handleMessage(const char* message, size_t length){
USER_SERIAL.println(message);
void initWiFi(){
WiFi.mode(WIFI_STA);
WiFi.hostname("ESP-host");
WiFi.setPhyMode(WIFI_PHY_MODE_11G);
WiFi.enableInsecureWEP(true);
WiFi.begin(ssid,pass);
while(WiFi.status() != WL_CONNECTED){
USER_SERIAL.print(".");
USER_SERIAL.print("");
USER_SERIAL.println("WiFi connected");
USER_SERIAL.print("IP Address: ");
USER_SERIAL.println(WiFi.localIP());
WiFi.setAutoReconnect(true);
WiFi.persistent(true);
void searchWifi(){
int numberOfNetwork = WiFi.scanNetworks();
USER_SERIAL.println("-----");
for ( int i = 0; i< numberOfNetwork;i++){
USER_SERIAL.print("Network name: ");
USER_SERIAL.println(WiFi.SSID(i));
USER_SERIAL.print("Signal Strength: ");
USER_SERIAL.println(WiFi.RSSI(i));
USER_SERIAL.println("-------------");
Here is what my serial monitor printing out:
12:57:13.083 -> Network name: Meas Nakry
12:57:13.083 -> Signal Strength: -85
12:57:13.083 -> -------------
12:57:13.083 -> Network name: bunvath_guest
12:57:13.083 -> Signal Strength: -57
12:57:13.083 -> Network name: BLaNKxD
12:57:13.083 -> Signal Strength: -89
12:57:13.121 -> -------------
12:57:13.121 -> Network name: Tuy vanny1
12:57:13.121 -> Signal Strength: -85
12:57:13.121 -> ....WiFi connected
12:57:17.165 -> IP Address: 192.168.0.100
12:57:17.165 -> [SIoC] add packet 42["message",hello from esp]
12:57:17.269 -> [SIoC] Disconnected!
12:57:17.269 -> [SIoC] event disconnected not found. 2 events available
12:57:17.787 -> [SIoC] Disconnected!
12:57:17.787 -> [SIoC] event disconnected not found. 2 events available
12:57:18.376 -> [SIoC] Disconnected!
12:57:18.376 -> [SIoC] event disconnected not found. 2 events available
12:57:18.992 -> [SIoC] Disconnected!
12:57:18.992 -> [SIoC] event disconnected not found. 2 events available
12:57:19.633 -> [SIoC] Disconnected!
12:57:19.633 -> [SIoC] event disconnected not found. 2 events available
12:57:20.217 -> [SIoC] Connected to url: /socket.io/?transport=websocket
12:57:20.217 -> [SIoC] packet "42["message",hello from esp]" emitted
12:57:20.251 -> [SIoC] Disconnected!
12:57:20.251 -> [SIoC] event disconnected not found. 2 events available
12:57:20.771 -> [SIoC] Connected to url: /socket.io/?transport=websocket
12:57:20.771 -> [SIoC] Disconnected!
12:57:20.771 -> [SIoC] event disconnected not found. 2 events available
12:57:21.435 -> [SIoC] Disconnected!
12:57:21.435 -> [SIoC] event disconnected not found. 2 events available
12:57:22.044 -> [SIoC] Disconnected!
12:57:22.044 -> [SIoC] event disconnected not found. 2 events available
12:57:22.596 -> [SIoC] Connected to url: /socket.io/?transport=websocket
12:57:22.596 -> [SIoC] Disconnected!
12:57:22.596 -> [SIoC] event disconnected not found. 2 events available
12:57:23.178 -> [SIoC] Connected to url: /socket.io/?transport=websocket
12:57:23.178 -> [SIoC] Disconnected!
12:57:23.178 -> [SIoC] event disconnected not found. 2 events available
12:57:23.798 -> [SIoC] Disconnected!
12:57:23.798 -> [SIoC] event disconnected not found. 2 events available
12:57:24.403 -> [SIoC] Disconnected!
12:57:24.403 -> [SIoC] event disconnected not found. 2 events available
12:57:24.945 -> [SIoC] Disconnected!
12:57:24.945 -> [SIoC] event disconnected not found. 2 events available
12:57:25.533 -> [SIoC] Disconnected!
12:57:25.533 -> [SIoC] event disconnected not found. 2 events available
12:57:26.201 -> [SIoC] Connected to url: /socket.io/?transport=websocket
12:57:26.201 -> [SIoC] Disconnected!
12:57:26.201 -> [SIoC] event disconnected not found. 2 events available
12:57:26.792 -> [SIoC] Disconnected!
12:57:26.792 -> [SIoC] event disconnected not found. 2 events available
12:57:27.380 -> [SIoC] Disconnected!
12:57:27.380 -> [SIoC] event disconnected not found. 2 events available
12:57:27.894 -> [SIoC] Disconnected!
12:57:27.894 -> [SIoC] event disconnected not found. 2 events available
12:57:28.711 -> [SIoC] Disconnected!
12:57:28.711 -> [SIoC] event disconnected not found. 2 events available
12:57:29.426 -> [SIoC] Disconnected!
12:57:29.426 -> [SIoC] event disconnected not found. 2 events available
12:57:30.131 -> [SIoC] Disconnected!
12:57:30.131 -> [SIoC] event disconnected not found. 2 events available
12:57:30.655 -> [SIoC] Disconnected!
12:57:30.655 -> [SIoC] event disconnected not found. 2 events available
12:57:31.254 -> [SIoC] Disconnected!
12:57:31.254 -> [SIoC] event disconnected not found. 2 events available
12:57:31.787 -> [SIoC] Disconnected!
12:57:31.787 -> [SIoC] event disconnected not found. 2 events available
12:57:32.375 -> [SIoC] Disconnected!
12:57:32.375 -> [SIoC] event disconnected not found. 2 events available
12:57:33.171 -> [SIoC] Disconnected!
12:57:33.171 -> [SIoC] event disconnected not found. 2 events available
12:57:33.731 -> [SIoC] Disconnected!
12:57:33.731 -> [SIoC] event disconnected not found. 2 events available
12:57:34.435 -> [SIoC] Connected to url: /socket.io/?transport=websocket
12:57:34.435 -> [SIoC] Disconnected!
12:57:34.435 -> [SIoC] event disconnected not found. 2 events available
12:57:34.978 -> [SIoC] Connected to url: /socket.io/?transport=websocket
12:57:34.978 -> [SIoC] Disconnected!
