I Want to Convert a std::string to a cstring
Hi all,
I want to convert a std::string to a cstring.
I have found this tutorial but it is for converting a std::string to a "const char" not a "char":
So how do I convert a std::string to a cstring?
Thanks very much,
Zeb
.c_str()
There is no implemented method to return a char*
You need to make a copy of .c_str()
Sorry I don't quite get what I should do!
I take it that I should use the strcpy command?
Thanks,
Zeb
ZebH:
Thanks,
Zeb
char str[myString.length() + 1] = {};
strcpy(str, myString.c_str());
ZebH:
c_str() returns a const char*. by const, it means the value cannot be modified (you couldn't process it with strtok() for example.
but you could do char* s = (char*) myString.c_str();
Hi arduino_new,
What am I supposed to put inside of the brakets?
Thanks for your help,
Zeb
ZebH:
Hi arduino_new,
Zeb
Nothing, it is to initialize all element of the array to 0.
gcjr:
I would suggest against doing this. This would leave the object at inconsistent state.
Excellent it is working great!
Thank you all, for your help!
Thanks again,
Zeb
arduino_new:
what about
Serial.println (s.c_str());
gcjr:
what about
What about it?
In C++17, you can use string::data(): std::basic_string<CharT,Traits,Allocator>::data - cppreference.com
Some caveats:
  1. Modifying the character array accessed through the const overload of data has undefined behavior.
  2. Modifying the past-the-end null terminator stored at data()+size() to any value other than CharT() has undefined behavior.
If the compiler that comes with your board package is new enough, you can enable C++17 in the platform.txt file by changing -std=gnu++11 to -std=gnu++1z or -std=gnu++17.
Pieter
Excellent, thank you!
