I want to make wifi feature on arduino for a special project of mine
I am using arduino R3. and I am using arduino IDE 2.0.0-rc3. I use ESP8266 Economic Wifi Serial Transceiver Module for wifi. I have connected ESP8266 to arduino externally. and ESP8266 seems to be working. The red light is constantly on and sometimes the blue light flashes. I can see the name of ESP8266 in my phone's wifi network. but still, this is the first time I'm getting an electronic circuit. and I don't know what to do. After several failed attempts I found this site https://create.arduino.cc/projecthub/imjeffparedes/add-wifi-to-arduino-uno-663b9e. I did as it shows step by step here, but it tells me to enter the application (TCP Client) and says it could not connect to me there. The serial monitor in the IDE says the same. but as i said i can connect to wifi from my phone.
Arduino UNO & ESP8266 and control using smartphone - YouTube I connected it like here, only 12 and 13 cables are missing. I think it is not necessary. Here are the other places I've searched: GitHub - GeekWenWang/Arduino-control-lab GitHub - imjeffparedes/iot-esp8266-arduino-interface: ​Learn how to communicate with ESP8266 Wifi Module using Arduino UNO. https://create.arduino.cc/projecthub/neverofftheinternet/esp8266-setup-and-first-wifi-connection-76fc3c
I don't know where the documents are and I can't find them. As a last care, I ask you because it was very difficult for me.
all I want to do is give commands to my Arduino through the application on my phone. using an api.
last command I used: GitHub - imjeffparedes/iot-esp8266-arduino-interface: ​Learn how to communicate with ESP8266 Wifi Module using Arduino UNO.
my card looks like this
if you have used this card before please send your sample code or point me in the right direction
why don't you get an ESP8266 or ESP32 and stop messing around with the UNO and ESP 01 (for which you might have voltage issues as it's a 3.3V device)
but it is not the same as
i already have this ESP8266.
Are you saying that the order I set up is wrong?
you are missing the resistors @killzone_kid highlighted... they are not there just for the fun in the tutorial
